I’m running into 2 issues with b2/b3. I had a SD Card crash while running v2 b2, so I reinstalled everything fresh. Everything was working fine before the crash, so I’m not sure what else has changed. After fixing the aiohttp issue (reverting to 1.2.x from 2.0.x), I’m now getting the following errors in any dash file that uses includes:
Include ERRORS:
2017-03-27 10:03:22.447088 INFO Compiling dashboard 'Jeremy'
2017-03-27 10:03:22.858633 WARNING Error while loading dashboard './conf/dashboards/./conf/dashboards/header_vertical.yaml'
2017-03-27 10:03:23.084873 WARNING Error while loading dashboard './conf/dashboards/./conf/dashboards/nav_vertical_main.yaml'
2017-03-27 10:03:23.342931 INFO function [compile_dash] finished in 910 ms
CSS ERRORS:
2017-03-27 10:15:03.427497 INFO Compiling dashboard 'Jeremy'
2017-03-27 10:15:03.736066 WARNING Error while loading dashboard './conf/dashboards/./conf/dashboards/header_vertical.yaml'
2017-03-27 10:15:03.771704 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:15:03.807662 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:15:03.849554 WARNING Variable definition not found in CSS Skin variables: $light_unit_style
2017-03-27 10:15:03.891987 WARNING Variable definition not found in CSS Skin variables: $light_unit_style
2017-03-27 10:15:03.928382 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:15:03.964281 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:15:03.965586 WARNING Error while loading dashboard './conf/dashboards/./conf/dashboards/nav_vertical_main.yaml'
2017-03-27 10:15:04.198140 INFO function [compile_dash] finished in 787 ms
2017-03-27 10:15:08.789678 INFO function [compile_dash] finished in 16 ms
2017-03-27 10:15:10.212608 INFO New dashboard connected: Jeremy's Dashboard
2017-03-27 10:32:10.176949 INFO Dashboard disconnected
2017-03-27 10:40:20.924264 INFO Compiling dashboard 'Lindsey'
2017-03-27 10:40:21.372975 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 10:40:21.396842 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 10:40:21.420791 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 10:40:21.444841 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 10:40:21.468637 WARNING Variable definition not found in CSS Skin variables: $sensor_text_style
2017-03-27 10:40:21.589733 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:40:21.626387 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:40:21.668513 WARNING Variable definition not found in CSS Skin variables: $light_unit_style
2017-03-27 10:40:21.710869 WARNING Variable definition not found in CSS Skin variables: $light_unit_style
2017-03-27 10:40:21.747386 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:40:21.783491 WARNING Variable definition not found in CSS Skin variables: $switch_state_text_style
2017-03-27 10:40:22.081538 INFO function [compile_dash] finished in 1173 ms
2017-03-27 10:40:23.694648 INFO New dashboard connected: Lindsey's Dashboard
Any dash that doesn’t use includes works fine, but still throws CSS errors.
~/appdaemon_dashboard/appdaemon/conf/dashboards/Jeremy.dash
# Main arguments, all optional
title: Jeremy's Dashboard
widget_dimensions: [100, 116]
widget_margins: [3, 3]
columns: 4
label:
widget_type: label
text: Jeremy
layout:
- include: header_vertical
- jeremy_bedside_lamp, lindsey_bedside_lamp, spacer, closet_light
- bathroom_light, bathroom_fan, spacer, porch_lights
- include: nav_vertical_main
bathroom_fan:
widget_type: switch
title: Bathroom Fan
entity: switch.bathroom_fan_switch_3_0
icon_on: mdi-fan
icon_off: mdi-fan
bathroom_light:
widget_type: light
title: Bathroom Light
entity: light.bathroom_light_level_2_0
icon_on: mdi-lightbulb
icon_off: mdi-lightbulb
on_level: 255
closet_light:
widget_type: light
title: Closet Light
entity: light.master_bedroom_c_level_4_0
on_level: 255
jeremy_bedside_lamp:
widget_type: switch
title: Jeremy's Bedside Lamp
entity: switch.zap1_shell_pilight
icon_on: mdi-lamp
icon_off: mdi-lamp
lindsey_bedside_lamp:
widget_type: switch
title: Lindsey's Bedside Lamp
entity: switch.zap2_shell_pilight
icon_on: mdi-lamp
icon_off: mdi-lamp
porch_lights:
widget_type: switch
title: Porch Lights
entity: switch.porch_outlet_switch_5_0
~/appdaemon_hadashboard/appdaemon/conf/dashboards/header_vertical.yaml
layout:
- clock(2x1), weather_high, weather_precipitation
- alarm_status(2x1), weather_low, weather_humidity
- jeremy_location, lindsey_location, sunrise, sunset
alarm_status:
widget_type: sensor
title: Alarm Status
entity: alarm_control_panel.house_alarm
icon_on: fa-lock
icon_off: fa-unlock-alt
clock:
widget_type: clock
jeremy_location:
widget_type: device_tracker
title: Jeremy's Location
device: jeremyoiphone
icon_on: fa-male
icon_off: fa-male
lindsey_location:
title: Lindsey's Location
device: lindseyowensiphone
icon_on: fa-female
icon_off: fa-female
sunrise:
widget_type: sensor
title: Sunrise
entity: sensor.sunrise_time
units: "AM"
sunset:
widget_type: sensor
title: Sunset
entity: sensor.sunset_time
units: "PM"
weather_high:
widget_type: sensor
title: Today's High
units: "°F"
precision: 0
entity: sensor.dark_sky_daily_high_temperature
weather_humidity:
widget_type: sensor
title: Humidity
units: "%"
precision: 0
entity: sensor.dark_sky_humidity
weather_low:
widget_type: sensor
title: Today's Low
units: "°F"
precision: 0
entity: sensor.dark_sky_daily_low_temperature
weather_precipitation:
widget_type: sensor
title: Chance of Precipitation
units: "%"
precision: 0
entity: sensor.dark_sky_precip_probability
~/appdaemon_dashboard/appdaemon/assets/css/jeremy/dashboard.css
html {
font-size:100%;
-webkit-text-size-adjust:100%;
-ms-text-size-adjust:100%;
padding:0;
body {
margin:0;
background:transparent url(/css/jeremy/img/jeremy-2.jpg) no-repeat 0 0 fixed;
background-size:cover;
font-size:14px;
color:#00aaff;
padding:0;
font-family:'Helvetica Neue','Helvetica','Open Sans','Arial';
b,strong {
font-weight:700;
a {
text-decoration:none;
color:inherit;
img {
border:0;
-ms-interpolation-mode:bicubic;
vertical-align:middle;
img,object {
max-width:100%;
iframe {
max-width:100%;
table {
border-collapse:collapse;
border-spacing:0;
width:100%;
td {
ul,ol {
padding:0;
margin:0;
h4,h5,p {
padding:0;
margin:0;
h1 {
padding:0;
margin:0;
margin-bottom:6px;
text-align:center;
font-size:100%;
font-weight:200;
h2 {
padding:0;
margin:0;
font-size:220%;
font-weight:400;
/* color:#fff; */
h3 {
padding:0;
margin:0;
font-size:125%;
font-weight:300;
color:#fff;
.dashboard_main {
margin:0 auto;
.gridster {
margin:0 auto;
.icon-background {
pointer-events:none;
width:100%!important;
height:100%;
position:absolute;
left:0;
top:0;
opacity:.1;
font-size:1375%;
text-align:center;
margin-top:82px;
.list-nostyle {
list-style:none;
.gridster ul {
list-style:none;
.gs-w {
width:100%;
display:table;
cursor:pointer;
.widget {
padding:0;
text-align:center;
width:100%;
display:table-cell;
background: hsla(33, 12%, 67%, 0.41);
# background-color:#444;
border: 1px groove yellow;
-webkit-border-radius: 10px;
-moz-border-radius: 10px;
.widget:before {
content: '';
position: absolute;
top: 0;
right: 0;
bottom: 0;
left: 0;
z-index: -15;
background: url(/css/jeremy/img/jeremy-2.jpg) 0 / cover fixed;
filter: blur(20px);
-webkit-filter: blur(20px);
-moz-filter: blur(20px);
-o-filter: blur(20px);
-ms-filter: blur(20px);
.widget:hover {
background: hsla(40, 69%, 40%, 0.81);
.title {
color:#fff;
.icon-inactive {
color:#00f;
font-size:300%;
.icon-active {
color:#ff0;
font-size:300%;
.icon
font-size: 300%;
#container {
padding-top:0;
.unit {
font-size:130%!important;
vertical-align:baseline!important;
.value
color: inherit;
.valueunit
top: 52px !important;
~/appdaemon_dashboard/appdaemon/assets/css/jeremy/variables.yaml
head_includes:
body_includes:
### Styles ###
blue: "#00aaff"
gray_very_dark: "#333"
gray_dark: "#444"
gray_medium: "#666"
gray_light: "#888"
green: "#aaff00"
orange: "#ffaa00"
purple: "#aa00ff"
red: "#ff0055"
white: "#fff"
white_medium: "#aaa"
yellow: "#ffff00"
red_background: "background-color: rgba(93, 65, 65, 0.7); color: wheat"
orange_background: "background-color: rgba(195, 99, 59, 0.5); color: wheat"
green_background: "background-color: rgba(61, 81, 61, 0.7); color: darkorange"
black_background: "background-color: rgba(0, 0, 0, 0.5)"
style_value: ""
style_unit: ""
### Page and widget defaults ###
background_style: "background-color: rgba(68,68,68,0.7); color: $blue;"
text_style: "font-size: 50%; color: #fff"
title: ""
### These are used for icons and indicators ###
style_inactive: "color: $gray_light"
style_active: "color: $yellow"
style_active_warn: "color: $red"
style_info: "color: $blue"
#style_title: "color: $white; font-weight: 400"
style_title: "color: $yellow; font-weight: 400"
style_title2: "color: $white; font-weight: 400"
### Widget Default Definitions ###
binary_sensor_icon_on: fa-bullseye
binary_sensor_icon_off: fa-minus
binary_sensor_icon_style_active: $style_active_warn
binary_sensor_icon_style_inactive: $style_inactive
binary_sensor_title_style: $style_title
binary_sensor_title2_style: $style_title2
binary_sensor_widget_style: $background_style
clock_date_style: "color: $yellow; font-weight: 400"
clock_time_style: "color: $blue"
clock_widget_style: $background_style
device_tracker_icon_on: fa-user
device_tracker_icon_off: fa-user
device_tracker_icon_style_active: $style_active
device_tracker_icon_style_inactive: $style_inactive
device_tracker_title_style: $style_title
device_tracker_title2_style: $style_title2
device_tracker_widget_style: $background_style
#device_tracker_state_text_style: "color: $white; font-weight: 400"
device_tracker_state_text_style: "color: $blue; font-weight: 400"
group_icon_on: fa-circle
group_icon_off: fa-circle-thin
group_icon_up: fa-plus
group_icon_down: fa-minus
group_title_style: $style_title
group_title2_style: $style_title2
group_icon_style_active: $style_active
#group_icon_style_inactive: "$style_inactive; color: antiquewhite"
group_icon_style_inactive: "$style_inactive; color: $yellow"
#group_state_text_style: "color: $white"
group_state_text_style: "color: $yellow"
group_level_style: "color: $gray_light"
group_level_up_style: "color: $gray_light"
group_level_down_style: "color: $gray_light"
group_widget_style: $background_style
input_boolean_icon_on: fa-sliders
input_boolean_icon_off: fa-sliders
input_boolean_icon_style_active: $style_active
input_boolean_icon_style_inactive: $style_inactive
input_boolean_title_style: $style_title
input_boolean_title2_style: $style_title2
input_boolean_widget_style: $background_style
input_slider_icon_up: fa-plus
input_slider_icon_down: fa-minus
input_slider_title_style: $style_title
input_slider_title2_style: $style_title2
input_slider_level_style: "color: $blue"
input_slider_unit_style: "color: $blue"
input_slider_level_up_style: "color: $gray_light"
input_slider_level_down_style: "color: $gray_light"
input_slider_widget_style: $background_style
label_title_style: $style_title
label_title2_style: $style_title2
#label_text_style: "color: $white"
label_text_style: "color: $yellow"
label_widget_style: $background_style
light_icon_on: fa-lightbulb-o
light_icon_off: fa-lightbulb-o
light_icon_up: fa-plus
light_icon_down: fa-minus
light_title_style: $style_title
light_title2_style: $style_title2
light_icon_style_active: "color: $yellow"
#light_icon_style_inactive: "$style_inactive; color: antiquewhite"
light_icon_style_inactive: "$style_inactive; color: $gray_medium"
#light_state_text_style: "color: $white"
light_state_text_style: "color: $yellow"
light_level_style: "color: $gray_light"
light_level_up_style: "color: $gray_light"
light_level_down_style: "color: $gray_light"
light_widget_style: $background_style
media_player_icon_on: fa-music
media_player_icon_off: fa-music
media_player_icon_up: fa-plus
media_player_icon_down: fa-minus
media_player_title_style: $style_title
media_player_title2_style: $style_title2
media_player_icon_style_active: $style_active
media_player_icon_style_inactive: $style_inactive
#media_player_state_text_style: "color: $white"
media_player_state_text_style: "color: $yellow"
media_player_level_style: "color: $gray_light"
media_player_level_up_style: "color: $gray_light"
media_player_level_down_style: "color: $gray_light"
media_player_widget_style: $background_style
mode_icon_on: fa-arrows-alt
mode_icon_off: fa-arrows-alt
mode_icon_style_active: $style_active
mode_icon_style_inactive: $style_inactive
mode_title_style: $style_title
mode_title2_style: $style_title2
mode_widget_style: $background_style
navigate_icon_active: fa-spinner fa-spin
navigate_icon_inactive: fa-gear
#navigate_icon_active_style: "color: $white"
navigate_icon_active_style: "color: $yellow"
#navigate_icon_inactive_style: "color: $white"
navigate_icon_inactive_style: "color: $yellow"
navigate_title_style: $style_title
navigate_title2_style: $style_title2
navigate_widget_style: $background_style
reload_icon_active: fa-spinner fa-spin
reload_icon_inactive: fa-refresh
#reload_icon_active_style: "color: $white"
reload_icon_active_style: "color: $yellow"
#reload_icon_inactive_style: "color: $white"
reload_icon_inactive_style: "color: $yellow"
reload_title_style: $style_title
reload_title2_style: $style_title2
reload_widget_style: $background_style
scene_icon_on: fa-square
scene_icon_off: fa-square
scene_icon_style_active: $style_active
scene_icon_style_inactive: $style_inactive
scene_title_style: $style_title
scene_title2_style: $style_title2
scene_widget_style: $background_style
sensor_value_style: $style_value
sensor_unit_style: $style_unit
switch_icon_on: fa-circle
switch_icon_off: fa-circle-thin
switch_icon_style_active: $style_active
#switch_icon_style_inactive: "$style_inactive; color: antiquewhite"
switch_icon_style_inactive: "$style_inactive; color: $gray_medium"
switch_title_style: $style_title
switch_title2_style: $style_title2
switch_widget_style: $background_style
text_sensor_title_style: $style_title
text_sensor_title2_style: $style_title2
#text_sensor_text_style: "color: $white"
text_sensor_text_style: "color: $yellow"
text_sensor_widget_style: $background_style
weather_main_style: "color: $orange"
weather_unit_style: "color: $orange"
weather_sub_style: "color: $blue"
weather_widget_style: $background_style
Any ideas?
