Annoying "Unable to connect to Home Assistant." issue after logging in
This has started in the past week. I am not sure what caused it, as I did not update HA before the issue started.
The web interface becomes unresponsive, so I go to the log in screen, it seems to accept my credentials but then says
Retrying in … seconds"
If I check the Web Developer tools, I can see that it’s a POST to /auth/token that results in 400 Bad Request:
This is logged at the same time
2024-05-06 22:04:21.023 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from localhost (127.0.0.1). Requested URL: '/auth/token'. (Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0)
I assume this is the cause of the issue.
I had this problem a few days ago and restarting the HA container didn’t fix it and it was about time for an update, so I just updated to the current version [whatever was current on 2023/05/03]. The issue seemed to go away, but now it is back again!
It looks like it’s this:
banning 127.0.0.1 due to some perceived infraction [I say “perceived” because I *know* I didn’t put the credentials in wrong, they’re saved in the password manager, so they’re never entered manually].
In the documentation it says “ip_ban_enabled boolean (Optional, default: false)”, so it’s off by default. I have no http: entry in my configuration.yaml, so why is it banning me?
This is really annoying. I am trying to get an old Fire tablet working as an HA “display” for the kitchen. I got the password wrong a few times, then got it right. Logged in. Messed about with dashboard. Tablet rebooted to install some updates. Now the tablet is banned. Doesn’t make any sense, if it was going to be banned it should be banned before I got the password right, not after!
Additionally, no ip_bans.yaml file is created, that I can find anywhere.
Even
http:
  ip_ban_enabled: false
in configuration.yaml doesn’t stop this from happening. What is this nonsense???
Even though the log message is identical apart from the IP address, the issue with the tablet is that it has an IPv6 address. This is “remote” by default, so the user needed “Can only log in from the local network” to be un-ticked.
Would be great if the log message actually said what the issue was here!
2024-05-30 22:48:46.297 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 2001:xx (2001:xx). Requested URL: '/auth/login_flow/902b2021d306a67f0b699365c042c5c9'. (Mozilla/5.0 (Linux; Android 5.1.1; KFFOWI Build/LVY48F; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/59.0.3071.125 Safari/537.36 Home Assistant/2024.4.1-12576 (Android 5.1.1; KFFOWI))
Looks like this issue or variations on it have been going on for some time:
I have started a feature request thread pleading for an improvement in the documentation and logging:
I receive the same message too. It seems this is a Firefox thing, what goes wrong at least when my HA container is updated while the HA tab is refreshing. But e.g. when i open an Edge browser, or when is was already opened, the same issue does not appear.
It’s solved for me… I’ve had this problem for a few days too.
Nginx Proxy Manager, which is where the problem came from.
I had to enable websockets support for the Homeassistant link in the Nginx Proxy Manager, then it worked again.
I feel like I would have spent too much time if it wasn’t for your comment.
Just migrated to Proxmox from a much simpler Docker setup with jwilder’s nginx-proxy, and I set up NPM. I would have never thought of this option.
It was enabling it, and within seconds the problem’s gone :muscle:
Thanks!
I had same problem, and:
How to Allow Local Connections by Adjusting Proxy Settings in macOS Sequoia:
1. Open System Settings and go to Network.
2. Select your active network connection (e.g., Wi-Fi or Ethernet).
3. Click Details next to the active connection and navigate to the Proxies tab.
4. Scroll down to the Bypass proxy settings for these Hosts & Domains field.
5. Add the following: *.local, 169.254/16, 192.168/16
This works if u have enabled Web Proxy (HTTP)
6. Click OK and Apply to save the changes.
This will allow local network connections, such as Home Assistant, to bypass the proxy settings.
Thank you for posting this!
Turning the phone off and on helped me.
Thank you so much! I’ve been struggling trying to figure out why our remote access suddenly stopped working a month ago. Same issue with Nginx Proxy Manager for me.
Worked for me too, after ages spent trying to diagnose the issue!
Hello HA community,
I’m new here and I wanted to tell how did I fix this issue.
The root cause of the problem was that I was connected with my desktop, in home and network where my HA is, but using a comercial VPN. After disconnecting, all worked fine.
It started one day but I don’t know why, because it worked all the time before. Previous day I had installed HACSadd-on, but I don’t know if this can be the cause.
Hope it can help to people with this problem caused by comercial VPN.
Just ran into the same problem, access via the app was fine, access via the browser gave the “Unable to connect to Home Assistant” issue. The app showed alerts for failed logins each time the browser retried, the fix was to switch from Firefox to Brave at which point everything worked fine again. So this matches robjacobsrijkevoort’s observation that it’s, at least in this case, something to do with Firefox.
Same here.
Only firefox has problem
For example MS Edge is OK
