Another Ikea z2m Styrbar Programmable Dimmer
Made this because there wasn’t one solution for my needs. Had to use several automations to dim lights or use Styrbar for different tasks.
Version 1.0
This blueprint integrates and controls the IKEA E2001/E2002 Styrbar remote control.
The primary light entity handles on/off and dim controls via the main buttons,
while a separate dimmable entity can be controlled using the hold functions of right
and left buttons. Customizable settings allow fine-tuning of button behavior.
blueprint:
  name: Another Styrbar Dimmer
  description: |
    **Version 1.0**
    The primary light entity handles on/off controls via the main buttons,
  source_url: https://github.com/Routout/Blueprints/blob/067db840e71c32d245a94d693968c6b0798eba16/another_styrbar_dimmer.yaml
  domain: automation
  input:
    light_entity:
      name: Primary Light Entity
      description: The main light to control for on/off controls.
      selector:
        entity:
          domain: light
          multiple: false
    enable_hold_dimming:
      name: Enable Hold Arrow Button Dimming
      description: Enable dimming functionality for hold buttons (left = dim down, right = dim up).
      default: true
      selector:
        boolean: {}
    dimmable_entity:
      name: Dimmable Light Entity
      description: The light to control when holding left/right buttons (can be same as primary light).
      selector:
        entity:
          domain: light
          multiple: false
    mqtt_device:
      name: Styrbar Remote Control
      description: The IKEA E2001/E2002 remote control.
      selector:
        device:
          integration: mqtt
    button_left_click:
      name: Left button - short press
      description: Action when SHORT press on LEFT arrow button
      default: []
      selector:
        action: {}
    button_left_hold:
      name: Left button - hold
      description: Action when HOLD press on LEFT arrow button (will be overridden if dimming is enabled)
      default: []
      selector:
        action: {}
    button_left_release:
      name: Left button - release
      description: Action when RELEASE press on LEFT arrow button
      default: []
      selector:
        action: {}
    button_right_click:
      name: Right button - short press
      description: Action when SHORT press on RIGHT arrow button
      default: []
      selector:
        action: {}
    button_right_hold:
      name: Right button - hold
      description: Action when HOLD press on RIGHT arrow button (will be overridden if dimming is enabled)
      default: []
      selector:
        action: {}
    button_right_release:
      name: Right button - release
      description: Action when RELEASE press on RIGHT arrow button
      default: []
      selector:
        action: {}
  - platform: device
    device_id: !input mqtt_device
    domain: mqtt
    type: action
    subtype: 'on'
  - platform: device
    domain: mqtt
    type: action
    subtype: 'off'
  - platform: device
    domain: mqtt
    type: action
    subtype: brightness_move_down
  - platform: device
    domain: mqtt
    type: action
    subtype: brightness_move_up
  - platform: device
    domain: mqtt
    type: action
    subtype: brightness_stop
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_left_click
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_left_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_left_release
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_right_click
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_right_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: arrow_right_release
variables:
  enable_hold_dimming: !input enable_hold_dimming
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: light.turn_on
              entity_id: !input light_entity
      - conditions:
        sequence:
          - service: light.turn_off
      # Brightness Adjustments for primary light
      - conditions:
        sequence:
          - repeat:
              sequence:
                    brightness_step_pct: -10
                - delay:
                    milliseconds: 500
              until:
      - conditions:
        sequence:
          - repeat:
              sequence:
                    brightness_step_pct: 10
                - delay:
                    milliseconds: 500
              until:
      # Left Button Actions
      - conditions:
        sequence: !input button_left_click
      - conditions:
          - condition: template
            value_template: "{{ enable_hold_dimming }}"
        sequence:
          - repeat:
              sequence:
                    entity_id: !input dimmable_entity
                - delay:
                    milliseconds: 500
              until:
      - conditions:
            value_template: "{{ not enable_hold_dimming }}"
        sequence: !input button_left_hold
      - conditions:
        sequence: !input button_left_release
      # Right Button Actions
      - conditions:
        sequence: !input button_right_click
      - conditions:
        sequence:
          - repeat:
              sequence:
                - delay:
                    milliseconds: 500
              until:
      - conditions:
        sequence: !input button_right_hold
      - conditions:
        sequence: !input button_right_release
mode: restart
Help needed if someone have an idea how to reduce delay for arrow button dimming and better behaviour. It works, but could be better.
