You canât expect an integration for a device that has no communication path (it accepts only SD card that printer no ?).
I have a Photon S from anycubic and itâs the same
Oke. I mean the Anycubic KOBRA 2. Not Kibra. Auto correction.
anycubic has his own cloud. The printer has wifi so you can check everything from the printer (like state, temperatures, etcâŚ) via app. Also Anycubic has his own slicer. When you are logged in, you could send the sliced files in the cloud and start the print by pc or mobile app.
There is an hacs integration which you can create via repositories which is insane but it has some struggles by logging in so i think an official integration is a lil bit better
Not sure to understand what you mean there ? problem to install the integration ? or to setup it ? Link to integration ?
Isnât it compatible with Repetier for example ? (Repetier has an integration that works very well with HA !
I have the Anycubic Kobra 2 Neo that do not have internet connection. I connected it to a raspberry Pi with Octoprint and I manage it in home assistant with Octoprint, that is quite good.
Should be working well with Kobra 2âs now. Does require you to connect your printer to an anycubic cloud account since LAN support is pretty limited. Basically replicates the Anycubic app functionality in homeassistant
