MyQ cover used to work but sometime yesterday (I think), it stopped working. I had upgraded the day before and im pretty sure it worked after that. I also made some other configuration changes so i restored from backup before the upgrade and it still did not work so i dont think its anything i did but i wanted to see if it was working for anyone else.
here is the logs
2019-05-01 09:07:21 ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform myq
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 416, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/myq/cover.py”, line 43, in async_setup_platform
myq = await login(username, password, brand, websession)
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 291, in login
await api.authenticate(username, password)
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 226, in authenticate
await self._get_security_token()
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 242, in _get_security_token
login_request=True,
File “/usr/local/lib/python3.7/site-packages/pymyq/api.py”, line 151, in _request
return await resp.json(content_type=None)
File “/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py”, line 1036, in json
return loads(stripped.decode(encoding))
File “/usr/local/lib/python3.7/json/init.py”, line 348, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/local/lib/python3.7/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Tue Aug 06 2019 11:42:24 GMT-0700 (Pacific Daylight Time)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/myq/cover.py", line 43, in async_setup_platform
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 293, in login
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 228, in authenticate
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 244, in _get_security_token
login_request=True,
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 153, in _request
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1036, in json
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
