did you restart your HASS today ?
I did a restart early this morning since Hassio quit responding. No other issues after that.
Weird its no longer working for me restarted 3 times already and nothingâŚ
MyQ with HA stopped working yesterday afternoon. Several restarts have not resolved the issue. Works fine with the MyQ app. I am afraid they may have finally deprecated the V4 API.
There was an error while logging in: 09:23:30.170126 Client Error while requesting data from api/v4/User/Validate: 400, message=âBad Requestâ, url='https://myqexternal.myqdevice.com/api/v4/User/Validate
9:23 AM components/myq/cover.py (ERROR)
Setup of platform myq is taking over 10 seconds.
9:23 AM main.py (WARNING)
09:23:30.170126 Error requesting from api/v4/User/Validate; retrying: 400, message=âBad Requestâ, url='https://myqexternal.myqdevice.com/api/v4/User/Validate
9:23 AM components/myq/cover.py (WARNING) - message first occured at 9:23 AM and shows up 2 times
Same errors here, myq broken
Appears the devs are working on it: https://github.com/arraylabs/pymyq/issues/25
Thank God I checked here before messing with my code, unlike the last several times the garage stopped working.
yup, glad I checked too!
I gave up on MyQ a long time ago due to reliability issues. I tried attaching an ESP8266 to the garage opener, but quickly realized that the terminal wasnât a simple on/off switch. The end result was hooking the ESP8266 with ESPHome up to a spare remote: itâs been over a year and Iâve had zero issues.
Is it just me, or is MyQ broken again? Iâm getting the following in the logs:
2019-10-31 07:46:11 ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform myq
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in_async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/myq/cover.py", line 53, in async_setup_platform
myq = await login(username, password, websession)
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 162, in login
await api.authenticate(username, password)
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 117, in authenticate
login_request=True,
File "/usr/local/lib/python3.7/site-packages/pymyq/api.py", line 85, in request
data = await resp.json(content_type=None)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1040, in json
return loads(stripped.decode(encoding))
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
I get the same with 0.100.3 and 0.101.0.
Yes mine too!
I donât believe the fix got into the 0.101.0 build, I think i saw something about it going into the 0.101.1 build. However in the meantime you may want to try the fix that worked for me posted by @bachya MYQ not working
Thanks! Every time I have a problem like this, I learn a little more about HA and Python. Changing the version in the manifest fixed it, and now I see 0.101.1 is out too.
My Q not working as of this morning @bachya
Yes, mine no longer works after updating to 109.4.
Also not working all of a sudden.
Mine too stopped working. Tried removing and re-adding, now integration throws up an unexpected error when giving it the username and password
Because itâs the API that broke. Nothing you do on your end, short of fixing the pymyq integration is going to do any good.
Same here. Glad I didnât get too deep into my troubleshooting where I destroy everything else in my config
Damn, I am glad I scrolled down on this one. I was going through a ton watching it connect for about a min and then drop again each time I restarted HA.
