Anyone have a good vacation lighting automation?
I’m looking for an automation that will turn on lights between certain times while I’m away on vacation. Heck, might even turn on the sonos and play some music. I have no problems figuring out how to turn on lights between certian times, but was looking for something a little more “fancy”. I’d like to be able to turn on 2 (or maybe selectable # from input_number) random lights for a period of time, maybe after 60 minutes, turn on 2 different random lights.
I used to have something similiar with Smartthings, I’d select the lights I wanted, how many to turn on at a time, and if I wanted to have them change throughout the evening, etc.
Anyone have anything similiar??
Take a look at @anon43302295, his GitHub has a pretty neat implementation, so neat in fact that I ‘borrowed’ it and made it better (suited for my purposes :slight_smile:)
Thanks for the pointer to the repo. Lots of good automations, scripts, ideas. I cannot seem to find one deailing with vacation lighting, or just random lighting. Can you point me to the yaml? Appreicate the help, thanks
I’ve got mine commented out at the minute 'cos it needs a bit of refining and I haven’t got back to it, but it’s here…
link removed
Looks amazing, and easy to understand, thanks for the great comments. I have only one dumb question. What to you use to trigger the script that starts this process. Is it turning on “Holiday Mode”?
Again, great stuff, thanks!
Yeah, I have an input_boolean called holiday mode - so you can switch it on manually and I think there’s an automation that automatically turns holiday mode on if nobody has been home for 48 hours in one of the other packages too.
Quick question, in your comments you mention something wrong with now() and kitchen? Is it the logic itself, or maybe you’ve changed some light names, etc. BTW, love the script, already got it mostly customized for me, but wanted to mostly make sure the now() was not something i had to fix,which I will if needed. :slight_smile:
Is there is an issue with now(), in the script, do you think this would work better? Just searching the community I came across this
    - wait_template: "{{ states.sensor.time.state >= '21:00' }}"
Ah yes! That’s why it’s commented out :slight_smile:
You need to swap out the now()'s in some places (maybe one, maybe all, haven’t looked yet) with templates that compare with sensor.time
I think my reference to kitchen is because I swapped out my kitchen light from a single Zwave unit to a group of hue bulbs, so I need to correct the entity ids in that file.
Yeah, you can use whatever you want to establish when it’s dark. Since I commented out that script I’ve developed an input_boolean that tells the system when it’s dark from various readings around the house, which I then use as triggers and conditions, so I need to swap that in to my version too.
So much to do, so little time :see_no_evil:
Great, thanks
Went with this
 # This package contains the scripts I use to #
 # simulate the house being occupied when the #
 # system is in Extended Away mode            #
# Automation I use to set the house to extended away
- alias: Mark house as extended away
  - platform: state
    entity_id: binary_sensor.people_home
    to: 'off'
    for:
      hours: 24
  - service: input_select.select_option
    entity_id: input_select.house_mode
      option: 'Extended Away'
input_selects:
  house_mode:
      options:
          - Home
          - Away
          - Night
          - Extended Away
 # This is used to set a random bedtime for our phantom house guest
 input_datetime:
   mockupancy_bedtime:
     has_date: false
     has_time: true
     initial: '23:00'
binary sensor:
   sensors:
     dark_outside:
       value_template: "{{ is_state('sun.sun', 'below_horizon') }}"
       friendly_name: "Dark Outside"
 # The main mockupancy script...
mockupancy:
  sequence:
    # Wait until it is after 6pm and dark to start the routine
    - wait_template: "{{ states.sensor.time.state >= '18:00' and is_state('binary_sensor.dark_outside' , 'on') }}"
    # Check that it Extended Away mode is still on
    - condition: state
      state: 'Extended Away'
    # Pick a random bedtime between 10pm and midnight.
    - service: input_datetime.set_time
      data_template:
        entity_id: input_datetime.mockupancy_bedtime
        time: "{{ (range(22, 23)|random|int) }}:{{ (range(0, 59)|random|int) }}:00"
    # Start the routine, switch on the 'usual' lights
    - service: homeassistant.turn_on
      entity_id:
        - scene.tv_lighting
    # Start scripts to randomise occasional lights
    - service: script.random_master_bedroom
    - service: script.random_kitchen
    # Start scripts to randomise kids' bedtime simulation
    - service: script.random_guest_room
    - service: script.random_ashleys_room
    # 1 hour before bedtime, change lighting as if TV was turned off
    - wait_template: "{{ states('sensor.time') == (((state_attr('input_datetime.mockupancy_bedtime' , 'timestamp')) - (60 * 60))|timestamp_custom('%H:%M', false)) }}"
      entity_id:
        - scene.casual_lighting
    # 20 minutes before bedtime, turn on kitchen lights only
    - wait_template: "{{ states('sensor.time') == (((state_attr('input_datetime.mockupancy_bedtime' , 'timestamp')) - (20 * 60))|timestamp_custom('%H:%M', false)) }}"
      entity_id:
        - scene.morning_lighting
    # Stop kitchen/master bedroom randomisation
    - service: homeassistant.turn_off
      entity_id:
        - script.random_master_bedroom
        - script.random_master_bedroom_loop
        - script.random_kitchen
        - script.random_kitchen_loop
    # At 'bedtime', turn on Master Bedroom for random time between 2 and 15 minutes
    # turn off kitchen, wait 20-30 seconds, turn off living room wait 30-59 seconds,
    # turn on bedroom.
    - wait_template: "{{ states('sensor.time') == (state_attr('input_datetime.mockupancy_bedtime' , 'timestamp')|int|timestamp_custom('%H:%M', False)) }}"
      entity_id: switch.stairwell_light
    - delay: "00:00:{{ (range(15, 59)|random|int) }}"
      entity_id: group.livingroom
    - delay: "00:00:{{ (range(20, 30)|random|int) }}"
      entity_id: group.kitchen
    - delay: "00:00{{ (range(20, 30)|random|int) }}"
      entity_id: light.bedroom_ceiling_light
        brightness: 80
    - delay: "00:{{ (range(2, 15)|random|int) }}:00"
    - delay: "00:{{ (range(15, 59)|random|int) }}:00"
#    # After a random time between 15 minutes and an hour, turn off the lights
    - delay: "00:{{ (range(15, 30)|random|int) }}:00"
      entity_id: input_boolean.goodnight_switch
    # If light before 7am, switch off lights, stop and loop, if not run a further script first
#    - wait_template: "{{ now().hour == 7 }}"
    - wait_template: "{{ states.sensor.time.state == '07:00' }}"
    - service_template: >
        {% if states('binary_sensor.dark_outside' , 'on') %} script.morning_mockupancy
        {% else %} script.mockupancy_loop {% endif %}
# A further script for if it is still dark in the morning
morning_mockupancy:
  sequence:
    - condition: state
    # Wait a random nmber of minutes between 1 and 30 and switch on the morning lights
    - delay: "00:{{ (range(1, 30)|random|int) }}:00"
      entity_id: scene.morning_lighting
    # Wait until it is light, switch off lights and loop
    - wait_template: "{{ is_state('binary_sensor.dark_outside' , 'off') }}"
    - service: script.mockupancy_loop
# Randomising beditmes for the upstairs rooms
random_guest_room:
  sequence:
    # Wait until after 8pm, and create a random delay up to 30 minutes and check if it is dark
#    - wait_template: "{{ now().hour >= 20 }}"
    - wait_template: "{{ states.sensor.time.state >= '20:00' }}"
    - condition: state
      entity_id: binary_sensor.dark_outside
      state: 'on'
    # Switch light on for between 10 and 30 minutes
      entity_id: light.guest_bedroom_lamp
    - delay: "00:{{ (range(10, 30)|random|int) }}:00"
random_ashleys_room:
  sequence:
    # Wait until after 9pm, and create a random delay up to 30 minutes and check if it is dark
#    - wait_template: "{{ now().hour >= 21 }}"
    - condition: state
      state: 'on'
      entity_id: light.ashleys_room_lamp
# Randomising rooms we're in and out off
random_master_bedroom:
  sequence:
    - condition: state
    # Wait a random nmber of minutes between 15 and 90 and switch on
    - delay: "00:{{ (range(15, 90)|random|int) }}:00"
        brightness: 100
    # Wait for between 3 minutes and 9 minutes and switch off
    - delay: "00:{{ (range(3, 9)|random|int) }}:00"
    # Loop the script for next time.
    - service: script.random_master_bedroom_loop
random_kitchen:
  sequence:
    - condition: state
      entity_id: light.kitchen_island_light
        brightness: 100
    - service: script.random_kitchen_loop
# Scripts that loop the ones above that need looping
mockupancy_loop:
  sequence:
    # Switch off the lights, and make sure the calling scripts have stopped
      entity_id:
        - group.all_lights
        - script.mockupancy
    - delay: 00:05:00
    # Check that it Extended Away mode is still on and restart the script for a new day
    - condition: state
random_master_bedroom_loop:
  sequence:
    # Stop the calling script
      entity_id: script.random_master_bedroom
    - delay: 00:05:00
    # Check that Extended Away mode is on and restart the script
    - condition: state
random_kitchen_loop:
  sequence:
      entity_id: script.random_kitchen
    - delay: 00:05:00
    - condition: state
The very first template in the mockupancy script needs now() swapping out, the entity id in your template sensor doesn’t need to be there as it is contained within the value_template already, and the value template needs double quotes at either end.
But other than that on a quick glance you’re looking pretty good :slight_smile:
The main problem with this kind of script is how long it takes to test if its working properly, hence how mine has ended up commented out and stuck on the back burner. Hope it works well for you :+1:
Awesome thanks for quick review. I updated the changes above. You know I went back and forth on the value template and the Quotes. When I put in in the template test tab, If it had Quotes, the result was “true” or “false” without quotes it returned true or false. Was not sure if the quotes would be an issue.
Thanks Again
Yeah, basically whatever you put in the template editor will start with the brackets, then for uniformity any quotes that you need inside those brackets use single quotes, for example
{{ is_state('device_tracker.john_doe' , 'home') }}
Then when you’re happy with your template and you put it in to your configuration.yaml (or linked one) add double quotes to either end if it is a one liner, so the above one would be
value_template: "{{ is_state('device_tracker.john_doe' , 'home') }}"
But if it’s multiline, like
 {% for state in states.media_player -%}
   {% if state.state == 'playing' %}
     {{ state.name | lower }} is {{state.attributes.media_content_id}}
   {% else %}
     {{state.name | lower }} is 0
   {% endif %}
 {%- endfor %}
Then you use a > character and indent the template below without quotes, so that one would be
service: notify.telegram
data_template:
  message: >
      {% else %}
      {% endif %}
    {%- endfor %}
Hope that makes sense.
@xbmcnut - this post might help you get your head around single/multiline templates too.
:+1:
forgive me digging up an old topic, but I guess there’s no sense of making a new one - first of all - @anon43302295, great script! I’m working on a similar one [leaving home next week and thought it would be cool to simulate occupancy ;)] and figured out most of the things, but I have a question about looping.
when you’re running scripts: random_master_bedroom, random_kitchen, random_guest_room, random_ashleys_room from within mockupancy script, do they run parallel to mockupancy in the same time and mockupancy can do other stuff then, or they just wait for each others’ turn and mockupancy is stopped until other scripts are done?
They run in parallel. So the kids lights go on and then off at their (random) set time, the kitchen and bathroom randomly pop on and off throughout and they all wind down towards ‘bedtime’.
Hope this helps.
perfect! thank you! it helps big time :slight_smile: now I’m sure my lamp-randomizer won’t interfere with random tv on-off schedule :slight_smile:
I’m still searching for a nice working vacation mode. The idea of auto enabling it when the house is 48 hours not occupied is very nice btw
However. I don’t see the script on @anon43302295 's GIT anymore, correct? What’s the best way to start at this moment?
It doesn’t look like the morning_mockupancy ever runs. Is that correct or am I missing something?
Anyone? Please =)
