My configuration keeps throwing up this error message when restarting, I have disabled each package where automations exist to try and isolate the cause, none of them resulted in the error going away.
The error in the logs is:
Logger: homeassistant.config
Source: config.py:415
First occurred: 1:48:45 PM (2 occurrences)
Last logged: 1:48:45 PM
Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->action->0->data. (See ?, line ?).
Invalid config for [automation]: [event] is an invalid option for [automation]. Check: automation->event. (See ?, line ?).
As far as I can tell none of my automations is failing so its really only bugging me that it exists at all.
It has been there for at least two updates to home assistant and I am currently running 2021.1.5
Hi, unfortunately, a bit difficult. The automation is split across 10 package files, each one for a specific area e.g. lights, security etc. Each of the files was removed from the packages folder to try and isolate where the problem may originate. None resolved the error.
Ha - and in my case, saving the file I just edited to make a change helps, too. I don’t know how many times I couldn’t figure something out only to (finally) find that I didn’t save the darn file… And I’ve been bitten by the “forgot to reload the automations” bug, too…
