I’m on Hassio 0.100.1 and I only used it to turn on/off devices, such as the TV or AC via broadlink. But now with the errors popping up on amazons end where did everyone move to?
My problems:
- Alexa saying device is malfunctioning when telling Alexa to turn on TV
- Turning on the aircon triggers the switch on then immediately switches back off.
I did a little work around but not sure if it’s too much just to turn on or off a device but this is what I have anyways.
My solution:
configuration.yaml:
emulated_hue:
listen_port: 80
expose_by_default: false
entities:
input_boolean.alexa_trigger_air_con:
name: "Alexa Trigger Air-con"
hidden: false
input_boolean.alexa_trigger_tv:
name: "Alexa Trigger TV"
hidden: false
input_boolean:
alexa_trigger_tv:
name: Alexa Trigger TV
initial: off
name: Alexa Trigger Air Con
initial: off
in automations.yaml
# Alexa, Turn on the Air Con
- id: alexa_turn_on_the_air_con
alias: Alexa, Turn on the Air Con
- platform: state
entity_id: input_boolean.alexa_trigger_air_con
condition:
- condition: state
entity_id: switch.aircon
state: 'off'
- data:
service: switch.turn_on
# Alexa, Turn off the Air Con
- id: alexa_turn_off_the_air_con
alias: Alexa, Turn off the Air Con
- platform: state
condition:
- condition: state
state: 'on'
- data:
service: switch.turn_off
Restart Home Assistant, then log into https://alexa.amazon.com, go to smart home > devices > discover
Once the input_booleans are found go to the app, create a routine with alexa says. I just chose:
- Alexa, turn on the air con
- Alexa, turn off the air con
In each of these routines, for the action select the input_booleans that was discovered earlier: smart home > Alexa Trigger Air Con
The automation config will do the rest based on current state of the switch.aircon
This works for me whether its overkill or not lol I’m just hoping it gets fixed soon
