This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that.
If your Home Assistant instance is only accessible from your local network, you can still protect the communication between your browsers and the frontend with SSL/TLS.
Let’s Encrypt will only work if you have a DNS entry and remote access is allowed.
The solution is to use a self-signed certificate. Please note, however, that after you have completed these steps, your browser will complain about the security of the certificate as it was not issued by a trusted authority.
This is due to self-signed certificates having not been issued by a certification authority (
CA). If you have your own CA, then this will not be an issue. -
A fantastic workaround for this, while keeping your instance isolated securely off the Internet, is to use a
Certificate for SSL/TLS via domain ownership.
If you don’t mind the browser warnings and simply want SSL/TLS encryption and therefore have decided to use a self-signed certificate permanently or temporarily, read on!
If you use Chrome browser version 58 or above and/or don’t want to have issues regarding a non-trusted CA or CN (Common Name), follow this full tutorial: Create Root Certificate Authority and self-signed certificate for your Home Assistant. Compatible with Chrome browser > version 58. Otherwise, follow this:
To create a certificate locally, you need the OpenSSL command-line tool.
Change to your Home Assistant configuration directory like ~/.homeassistant. This will make it easier to backup your certificate and the key. Run the command shown below.
The certificate must be .pem extension.
openssl req -sha256 -addext "subjectAltName = IP:X.X.X.X" -newkey rsa:4096 -nodes -keyout privkey.pem -x509 -days 730 -out fullchain.pem
Where the X.X.X.X must be replaced with the IP address of your local machine running Home Assistant (e.g., 192.168.1.20).
For details about the parameters, please check the OpenSSL documentation. Provide the requested information during the generation process.
At the end you will have two files called privkey.pem and fullchain.pem. The key and the certificate.
Update the http: entry in your configuration.yaml file and let it point to your created files.
Home Assistant & Home Assistant Supervised:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Home Assistant Core:
http:
ssl_certificate: /home/your_user/.homeassistant/fullchain.pem
ssl_key: /home/your_user/.homeassistant/privkey.pem
Home Assistant Core on Docker:
http:
ssl_certificate: /config/fullchain.pem
ssl_key: /config/privkey.pem
A restart of Home Assistant is required for the new certificate to take effect.
If you get any log error about ssl_key or ssl_certificate that is not a file for dictionary value when run Home Assistant, you need to change owner or access permission of the .pem files as following:
Home Assistant (through console or SSH add-on):
chown root:root fullchain.pem privkey.pem
chmod 600 fullchain.pem privkey.pem
sudo chown homeassistant:homeassistant fullchain.pem privkey.pem
sudo chmod 600 fullchain.pem privkey.pem
A tutorial “Working with SSL Certificates, Private Keys and CSRs” could give you some insight about special cases.
iOS and macOS Specific Requirements
iOS
If you are going to use this certificate with the iOS app, you need to ensure you complete all fields during the certificate creation process, then:
- Send only the
fullchain.pemfile to the iOS device, using airdrop or other transfer method. - Open the
.pemfile on the iOS device, follow the prompts to trust and install it. - If you are using iOS 10.3 or newer then additional steps are needed.
iOS 13 and macOS 10.15
There are new security requirements for TLS server certificates in iOS 13 and macOS 10.15. To summarize:
- The key size must be greater than or equal to 2048 bits.
- A hash algorithm from the SHA-2 family is required. SHA-1 signed certificates are no longer trusted for TLS.
- The DNS name of the server must be included in the Subject Alternative Name extension of the certificate.
- For certificates issued after July 1, 2019:
- Certificates must contain an ExtendedKeyUsage (EKU) extension containing the id-kp-serverAuth OID.
- Certificates must have a validity period of 825 days or fewer.
