You’re asking in the wrong place. The developer is not here.
Try asking here Issues · MindFreeze/ha-sankey-chart · GitHub
Also how are your external loads not powered from one of your three phases?
I’m using Sheely 3EM to measure energy consumption, but unfortunatelly I did not have enough space to install it next to main grid connection (or rather I have not enough space to install clamps), instead it is installed in main fuses box inside the house. That means that connection to garage (which is other building) is made before place where I can make measurements. So external represents everything that is installed in garage or powered from garage building. Technically it is one of these 3 phases, but Im just not capturing consumption on this part of installation. As such I’m using Powercalc to estimate consumption there.
Just installed the card and I have an issue with the child entities:
The code used is as follows:
- type: custom:sankey-chart
show_names: true
sections:
- entities:
- entity_id: sensor.counter_appt_overall_power_l2
children:
- sensor.bw_br_washer_power
- sensor.bw_corridor_meas_power
- entities:
- sensor.bw_kitchen_coffeemachine_power
- sensor.bw_kitchen_dishwasher_power
What is shows is only the parent entity like on screenshot, others are ignored. Maybe somebody can advice what can cause this?
@tom_I Would you like to share your code for your card? It looks really nice.
Because your level 2 section entities are different than one specified as children in section 1…
Though it is a biot strange, as they SHOULD show, but disconnected from section one sensor…
I use the Sidebar view option for the extra width and I also use the Sankey chart card inside an entities card (using custom hui-element) so that the theme matches my other cards. Otherwise the native title option of the Sankey card would require extensive card-mod work as it does not follow the same structure as the core cards.
Power:
type: entities
title: Power Distribution
entities:
- type: custom:hui-element
card_type: custom:sankey-chart
show_names: true
height: 300
round: 2
unit_prefix: k
wide: true
sections:
- entities:
- entity_id: sensor.grid_power
color: '#e0b400'
children:
- sensor.metering_power_supplied
- sensor.solar_power_consumed
- entities:
- entity_id: sensor.solar_power_consumed
name: Solar Power Consumption
color: '#e0b400'
children:
- sensor.total_power_consumed
- entity_id: sensor.metering_power_supplied
name: Solar Power to Grid
color: '#8353d1'
- entity_id: sensor.metering_power_absorbed
name: Grid Power Consumption
children:
color: '#e45e65'
- entities:
- entity_id: sensor.total_power_consumed
name: Total Power Consumption
remaining:
children:
- sensor.known_loads
color: '#ff8000'
- entities:
- entity_id: sensor.known_loads
children:
- sensor.bar_fridge_power
- sensor.cinema_av_power
- sensor.cinema_subwoofer_power
- sensor.comms_rack_power
- sensor.dishwasher_power
- sensor.downstairs_heat_pump_power
- sensor.electric_blanket_power
- sensor.electronics_bench_power
- sensor.fridge_power
- sensor.hot_water_power
- sensor.led_table_power
- sensor.lounge_av_power
- sensor.lounge_dehumidifier_power
- sensor.mechanical_bench_power
- sensor.pc_monitor_power
- sensor.pi3b_power
- sensor.rack_fan_power
- sensor.rumpus_dehumidifier_power
- sensor.spb_electric_blanket_power
- sensor.upstairs_heat_pump_power
- sensor.washing_machine_power
- sensor.workshop_chargers_power
color: '#039BE5'
- entities:
- sensor.pi3b_power
Energy:
type: entities
title: Daily Energy Distribution
entities:
show_names: true
height: 300
round: 2
unit_prefix: k
wide: true
sections:
- entities:
- entity_id: sensor.energy_from_grid_daily_peak
name: Grid Peak Energy Used
color: '#488fc2'
children:
- sensor.energy_imported_daily_total
- entity_id: sensor.energy_from_grid_daily_offpeak
name: Grid Offpeak Energy Used
color: '#2f5f82'
children:
- entity_id: sensor.energy_inverter_daily
name: Solar Energy Produced
color: '#ff9800'
children:
- sensor.energy_to_grid_daily
- sensor.self_solar_consumption_daily
- entities:
- entity_id: sensor.energy_imported_daily_total
name: Daily Imported Total
children:
- sensor.energy_consumed_daily_total
- entity_id: sensor.self_solar_consumption_daily
name: Self Consumed Solar
color: '#ff9800'
children:
- entity_id: sensor.energy_to_grid_daily
name: Solar Energy Exported
color: '#8353d1'
- entities:
- entity_id: sensor.energy_consumed_daily_total
name: Total Energy Used
color: '#488FC2'
remaining:
children:
- sensor.bar_fridge_daily_energy
- sensor.cinema_av_daily_energy
- sensor.comms_rack_daily_energy
- sensor.dishwasher_daily_energy
- sensor.electronics_bench_daily_energy
- sensor.fridge_daily_energy
- sensor.energy_downstairs_heat_pump_daily
- sensor.energy_hot_water_daily_peak
- sensor.energy_hot_water_daily_offpeak
- sensor.led_table_daily_energy
- sensor.lounge_av_daily_energy
- sensor.lounge_dehumidifier_daily_energy
- sensor.electric_blanket_daily_energy
- sensor.mechanical_bench_daily_energy
- sensor.pc_monitor_daily_energy
- sensor.rack_fan_daily_energy
- sensor.rumpus_dehumidifier_daily_energy
- sensor.spb_electric_blanket_daily_energy
- sensor.cinema_subwoofer_daily_energy
- sensor.energy_upstairs_heat_pump_daily_peak
- sensor.energy_upstairs_heat_pump_daily_offpeak
- sensor.washing_machine_daily_energy
- sensor.workshop_chargers_daily_energy
- entities:
- entity_id: sensor.bar_fridge_daily_energy
color: '#039BE5'
- entity_id: sensor.cinema_av_daily_energy
name: Cinema AV Gear
color: '#039BE5'
- entity_id: sensor.comms_rack_daily_energy
color: '#039BE5'
- entity_id: sensor.dishwasher_daily_energy
color: '#039BE5'
- entity_id: sensor.electronics_bench_daily_energy
color: '#039BE5'
- entity_id: sensor.fridge_daily_energy
color: '#039BE5'
- entity_id: sensor.energy_downstairs_heat_pump_daily
name: Downstairs Heat Pump
color: '#039BE5'
- entity_id: sensor.energy_hot_water_daily_peak
name: Hot Water (Peak)
color: '#039BE5'
- entity_id: sensor.energy_hot_water_daily_offpeak
name: Hot Water (Offpeak)
color: '#039BE5'
- entity_id: sensor.led_table_daily_energy
color: '#039BE5'
- entity_id: sensor.lounge_av_daily_energy
name: Lounge AV Gear
color: '#039BE5'
- entity_id: sensor.lounge_dehumidifier_daily_energy
name: Lounge Dehumidifier
color: '#039BE5'
- entity_id: sensor.electric_blanket_daily_energy
name: Master Bedroom Elect Blanket
color: '#039BE5'
- entity_id: sensor.mechanical_bench_daily_energy
color: '#039BE5'
- entity_id: sensor.pc_monitor_daily_energy
color: '#039BE5'
- entity_id: sensor.rack_fan_daily_energy
color: '#039BE5'
- entity_id: sensor.rumpus_dehumidifier_daily_energy
name: Rumpus Dehumidifier
color: '#039BE5'
- entity_id: sensor.spb_electric_blanket_daily_energy
name: Spare Bedroom Elec Blanket
color: '#039BE5'
- entity_id: sensor.cinema_subwoofer_daily_energy
color: '#039BE5'
- entity_id: sensor.energy_upstairs_heat_pump_daily_peak
name: Upstairs Heat Pump (Peak)
color: '#039BE5'
- entity_id: sensor.energy_upstairs_heat_pump_daily_offpeak
name: Upstairs Heat Pump (Offpeak)
color: '#039BE5'
- entity_id: sensor.washing_machine_daily_energy
color: '#039BE5'
- entity_id: sensor.workshop_chargers_daily_energy
color: '#039BE5'
Thanks, that provided sufficient clues on the card code structure. Now it works!
2 new questions:
show_names: true
height: 400
round: 2
wide: true
sections:
- entities:
- entity_id: sensor.shelly_3em_power_total
remaining:
children:
- sensor.espressomaschine_power
- sensor.server_power
- sensor.heizung_strom_power
- sensor.studio_power_2
- sensor.kuhlmess_power
- sensor.freezer_power
- sensor.tv_power
- sensor.trockner_power
- sensor.spulmaschine_power
- sensor.wallbox_watt
- entities:
- entity_id: sensor.server_power
remaining:
children:
- sensor.ups_watt
- entities:
- sensor.tv_power
works fine in general, but not the children part. sensor.ups_watt should be a child of sensor.server_power, but the “remaining” “other” part is never shown. Instead it looks like this
Is it because sensor.ups_watt is not a sensor, but a template? (excuse me if using the wrong nomenclature). Everywhere else sensor.ups_watt works fine.
in configuration.yaml it is defines like this:
- sensor:
- name: "UPS_Watt"
unique_id: UPS_Watt
state: >-
{{ (states('sensor.myups_output_voltage')|float(0) * states('sensor.myups_output_current')|float(0))}}
unit_of_measurement: W
device_class: power
state_class: measurement
I think everything that is listed under children
needs to also be listed again later under an - entities
. That should also let you name the children.
Really like this card as well!
Only thing I am struggling is with the coulouring scheme. Could anyone give me a hint how to use it?
I am used to Hex, RGB or CMYK, but never encountered this (var--xyz)
scheme…
You don’t have to use that format for the color - you can stick to the simpler color: blue
type settings. If you want a more specific color or only colors in certain circumstances then you can get fancier with it.
Those are color variables defined in the theme.yaml. Here is example f this file content:
dark-background: "#1C1E2E" #var(--dark-background)
medium-background: "#242635" #var(--medium-background)
light-background: "#2C2E3C" #var(--light-background)
components-background: "#242635" #var(--components-background)
bright-text: "#ffffff" #var(--bright-text)
dimmed-text: "#A4A7B4" #var(--dimmed-text)
dark-text: "#444856" #var(--dark-text)
cyan-text: "#1bbfff" #var(--cyan-text)
alert-text: "#CD1015" #var(--alert-text)
The first column shows actual definitions of different interface components, the second one displays as comment variable to be used to use specific color in the UI. For this matter you can define in your theme additional colors, that are not specific to UI elements, but also can be used same way. Here is sample of color palette I’m using in my theme:
orange1: "#F5A624"
orange2: "#DBBC09"
orange3: "#AB6D09"
orange4: "#784E07"
orange5: "#452F05"
orange6: "#121003"
Please note that not all cards accpt variables as color definition, though…
Thanks a lot! Now I understand the sysstem.
Did anyone got it working with the children naming?
Tried it with different options via the children part or in the entities part, but nothing seems to work (or is miss something).
For example:
children:
- sensor.shellyplug01_power
- sensor.shellyplug02_power
- sensor.shellyplug03_power
- sensor.shellyplug04_power
- sensor.shellyplug05_power
- entities:
The names will always go under the - entity_id: sensor.my_sensor
Here’s my current config, hopefully it’ll be a bit clearer:
title: Realtime Power
show_names: true
min_box_height: 8
sections:
- entities:
- entity_id: sensor.breaker_panel_electric_consumption_w
children:
- sensor.network_rack_electric_consumption_w
- sensor.cam_plug_power
- sensor.washer_electric_consumption_w
- sensor.smart_bulbs_power
remaining:
- entities:
- entity_id: sensor.washer_electric_consumption_w
- entity_id: sensor.network_rack_electric_consumption_w
children:
- sensor.idrac_host1_powerconsumption
- sensor.idrac_host2_powerconsumption
- sensor.idrac_host3_powerconsumption
remaining:
- entity_id: sensor.cam_plug_power
- entity_id: sensor.smart_bulbs_power
- entities:
- entity_id: sensor.idrac_host1_powerconsumption
- entity_id: sensor.idrac_host2_powerconsumption
- entity_id: sensor.idrac_host3_powerconsumption
Awesome! thx. its working now.
Just starting to play with this amazing looking card, but not getting the fill in effect and flow displaying. I’ve tweaked my sensors so that they’re all in a similar range of each other, in case the line couldn’t be drawn because of huge variation in value, but I can’t get it to display the flows.
show_names: true
unit_prefix: k
round: 1
wide: true
sections:
- entities:
- entity_id: sensor.givtcp_ce2209g009_pv_power
color: var(--warning-color)
children:
- sensor.givtcp_ce2209g009_pv_energy_today_kwh
- entity_id: sensor.givtcp_ce2209g009_grid_power
children:
- sensor.givtcp_ce2209g009_import_energy_today_kwh
- entity_id: sensor.givtcp_ce2209g009_battery_power
colora: var(--success-color)
children:
- sensor.givtcp_ce2209g009_battery_throughput_today_kw
- entities:
- entity_id: sensor.kitchen_fridge_current_energy
- entity_id: sensor.garage_fridge_current_energy
@Fayrewood wherever you have a sensor listed as a child, you also have to list it again under a subsequent -entities
and - entity_id:
. Also, it doesn’t look like you have your fridges listed as children anywhere, so you’ll need to add those in as children under one of the other entities.
Hi Tom.
This is a fantastic (!) layout and exactly what I’m trying to establish. Are each of the cards in the screenshot above a separate sankey card in the dashboard view, or is it a single sankey card with code?
