Awesome! thx. its working now.
Just starting to play with this amazing looking card, but not getting the fill in effect and flow displaying. I’ve tweaked my sensors so that they’re all in a similar range of each other, in case the line couldn’t be drawn because of huge variation in value, but I can’t get it to display the flows.
type: custom:sankey-chart
show_names: true
unit_prefix: k
round: 1
wide: true
sections:
- entities:
- entity_id: sensor.givtcp_ce2209g009_pv_power
color: var(--warning-color)
children:
- sensor.givtcp_ce2209g009_pv_energy_today_kwh
- entity_id: sensor.givtcp_ce2209g009_grid_power
children:
- sensor.givtcp_ce2209g009_import_energy_today_kwh
- entity_id: sensor.givtcp_ce2209g009_battery_power
colora: var(--success-color)
children:
- sensor.givtcp_ce2209g009_battery_throughput_today_kw
- entities:
- entity_id: sensor.kitchen_fridge_current_energy
- entity_id: sensor.garage_fridge_current_energy
@Fayrewood wherever you have a sensor listed as a child, you also have to list it again under a subsequent -entities
and - entity_id:
. Also, it doesn’t look like you have your fridges listed as children anywhere, so you’ll need to add those in as children under one of the other entities.
Hi Tom.
This is a fantastic (!) layout and exactly what I’m trying to establish. Are each of the cards in the screenshot above a separate sankey card in the dashboard view, or is it a single sankey card with code?
One Sankey card and the others are mini-graph cards.
Has anyone worded out how to use the remaining_child/parent options in the recent update?
I’ve been banging my head against it for hours getting nowhere.
This used to work (3rd section):
type: entities
title: Daily Energy Distribution
entities:
- type: custom:hui-element
card_type: custom:sankey-chart
show_names: true
height: 300
round: 2
unit_prefix: k
wide: true
sections:
- entities:
- entity_id: sensor.energy_from_grid_daily_peak
name: Grid Peak Energy Used
color: '#488fc2'
children:
- sensor.energy_imported_daily_total
- entity_id: sensor.energy_from_grid_daily_offpeak
name: Grid Offpeak Energy Used
color: '#2f5f82'
children:
- entity_id: sensor.energy_inverter_daily
name: Solar Energy Produced
color: '#ff9800'
children:
- sensor.self_solar_consumption_daily
- sensor.energy_to_grid_daily
- entities:
- entity_id: sensor.energy_imported_daily_total
name: Daily Imported Total
children:
- sensor.energy_consumed_daily_total
- entity_id: sensor.self_solar_consumption_daily
name: Self Consumed Solar
color: '#ff9800'
children:
- entity_id: sensor.energy_to_grid_daily
name: Solar Energy Exported
color: '#8353d1'
- entities:
- entity_id: sensor.energy_consumed_daily_total
name: Total Energy Used
color: '#488FC2'
remaining:
children:
- sensor.bar_fridge_daily_energy
- sensor.cinema_av_daily_energy
- sensor.comms_rack_daily_energy
- sensor.dishwasher_daily_energy
- sensor.electronics_bench_daily_energy
- sensor.fridge_daily_energy
- sensor.energy_downstairs_heat_pump_daily
- sensor.energy_hot_water_daily_peak
- sensor.energy_hot_water_daily_offpeak
- sensor.led_table_daily_energy
- sensor.lounge_av_daily_energy
- sensor.lounge_dehumidifier_daily_energy
- sensor.electric_blanket_daily_energy
- sensor.mechanical_bench_daily_energy
- sensor.pc_monitor_daily_energy
- sensor.rack_fan_daily_energy
- sensor.rumpus_dehumidifier_daily_energy
- sensor.spb_electric_blanket_daily_energy
- sensor.cinema_subwoofer_daily_energy
- sensor.energy_upstairs_heat_pump_daily_peak
- sensor.energy_upstairs_heat_pump_daily_offpeak
- sensor.washing_machine_daily_energy
- sensor.workshop_chargers_daily_energy
- entities:
- entity_id: sensor.bar_fridge_daily_energy
color: '#039BE5'
- entity_id: sensor.cinema_av_daily_energy
name: Cinema AV Gear
color: '#039BE5'
- entity_id: sensor.comms_rack_daily_energy
color: '#039BE5'
- entity_id: sensor.dishwasher_daily_energy
color: '#039BE5'
- entity_id: sensor.electronics_bench_daily_energy
color: '#039BE5'
- entity_id: sensor.fridge_daily_energy
color: '#039BE5'
- entity_id: sensor.energy_downstairs_heat_pump_daily
name: Downstairs Heat Pump
color: '#039BE5'
- entity_id: sensor.energy_hot_water_daily_peak
name: Hot Water (Peak)
color: '#039BE5'
- entity_id: sensor.energy_hot_water_daily_offpeak
name: Hot Water (Offpeak)
color: '#039BE5'
- entity_id: sensor.led_table_daily_energy
color: '#039BE5'
- entity_id: sensor.lounge_av_daily_energy
name: Lounge AV Gear
color: '#039BE5'
- entity_id: sensor.lounge_dehumidifier_daily_energy
name: Lounge Dehumidifier
color: '#039BE5'
- entity_id: sensor.electric_blanket_daily_energy
name: Master Bedroom Elect Blanket
color: '#039BE5'
- entity_id: sensor.mechanical_bench_daily_energy
color: '#039BE5'
- entity_id: sensor.pc_monitor_daily_energy
color: '#039BE5'
- entity_id: sensor.rack_fan_daily_energy
color: '#039BE5'
- entity_id: sensor.rumpus_dehumidifier_daily_energy
name: Rumpus Dehumidifier
color: '#039BE5'
- entity_id: sensor.spb_electric_blanket_daily_energy
name: Spare Bedroom Elec Blanket
color: '#039BE5'
- entity_id: sensor.cinema_subwoofer_daily_energy
color: '#039BE5'
- entity_id: sensor.energy_upstairs_heat_pump_daily_peak
name: Upstairs Heat Pump (Peak)
color: '#039BE5'
- entity_id: sensor.energy_upstairs_heat_pump_daily_offpeak
name: Upstairs Heat Pump (Offpeak)
color: '#039BE5'
- entity_id: sensor.washing_machine_daily_energy
color: '#039BE5'
- entity_id: sensor.workshop_chargers_daily_energy
color: '#039BE5'
I found that I had to add the remaining_parent_state as an entity:
title: Strømforbruk denne måned
show_names: true
show_icons: false
unit_prefix: k
round: 1
wide: true
height: 300
min_box_height: 10
sections:
- entities:
- entity_id: sensor.monthly_net_consumption
children:
- sensor.vvb_manedsforbruk
- sensor.avfukter_manedsforbruk
- sensor.vp_maned_kwh
- sensor.elbillading_manedsforbruk
- sensor.varmekabel_bad_maned
- sensor.nettverk_manedsforbruk
- sensor.tv_manedsforbruk
- sensor.servere_manedsforbruk
- Annet
- entities:
- entity_id: sensor.vvb_manedsforbruk
- entity_id: sensor.avfukter_manedsforbruk
- entity_id: sensor.vp_maned_kwh
- entity_id: sensor.elbillading_manedsforbruk
- entity_id: sensor.varmekabel_bad_maned
- entity_id: sensor.nettverk_manedsforbruk
- entity_id: sensor.tv_manedsforbruk
- entity_id: sensor.servere_manedsforbruk
- entity_id: Annet
type: remaining_parent_state
BTW, “Annet” is just Norwegian for “Other”
1.0.0 Live power consumption - remaining not working?
Hi, the new way of using “Other” is working fine for me in the Sankey charts where I use data mainly from Utility Meters.
However, I have one chart with live consumption where the remaining is always redicculously low. It’s the one named “Annet” in the attachment.
I have noticed the one from VP (heatpump) is in kWh/h while the rest are in kW, but I tried removing it and it did not change the others (“Annet”) bit.
title: Strømforbruk live
show_names: true
show_icons: false
unit_prefix: k
round: 1
wide: true
height: 200
min_box_height: 10
sections:
- entities:
- entity_id: sensor.power
children:
- sensor.varmtvannsbereder_switch_0_power
- sensor.shellyplug_XXXX_power
- sensor.varmepumpe_watt
- sensor.YYYYY_power
- sensor.bad_power
- sensor.shellyplug_ZZZZZ_power
- sensor.shellyplug_s_XYXY_power
- sensor.shellyplug_s_XYZXYZ_power
- Annet
- entities:
- entity_id: sensor.varmtvannsbereder_switch_0_power
- entity_id: sensor.shellyplug_XXXX_power
- entity_id: sensor.varmepumpe_watt
- entity_id: sensor.YYYYY_power
- entity_id: sensor.bad_power
- entity_id: sensor.shellyplug_ZZZZZ_power
- entity_id: sensor.shellyplug_s_XYXY_power
- entity_id: sensor.shellyplug_s_XYZXYZ_power
- entity_id: Annet
Actually, yeah that is what I am seeing too. I thought it was that only the last section worked but the common factor seems to be power:
Hi everyone. I am the creator of the card and just discovered this thread.
As expected there is some problem with the new calculations since v1 . I am working on reproducing it
Lovely card Peter. Thanks for it and your continued support!
Bug has been fixed in v1.1.1
Hi, since the latest update to 1.1.11 I have following Problem. Was working fine until now. Can anybody help please…
Missing child entity sensor.energy_consumption_monthly
title: Monthly
show_names: false
unit_prefix: k
round: 1
wide: true
sections:
- entities:
- entity_id: sensor.energy_import_monthly
children:
- sensor.energy_import_monthly
color: orange
- entity_id: sensor.solarh_98050_month_eq
children:
- sensor.solarexportminusmonthly
- sensor.energy_export_monthly
color: purple
- entities:
children:
- sensor.energy_consumption_monthly
color: orange
- entity_id: sensor.solarexportminusmonthly
children:
color: null
- entity_id: sensor.energy_export_monthly
children:
color: red
- entities:
- entity_id: sensor.energy_consumption_monthly
children:
color: var(--success-color)
color: null
children:
color: red
I have successfully set up a Sankey dash. Is there a trick to forcing the first level ‘Solar’ to show its entire supply to the second level ‘Grid’? It seems that if the previous entity (battery) is supplying the full load, that the solar entity doesn’t link its supply
The ‘excess’ Due to conversion loss of AC/DC is showing as flowing elsewhere and not going to the grid. Here you can see 0.19kw going to ‘rounding’ which is an entity under the ‘remaining’ tag.
type: entities
title: Power Distribution
entities:
show_names: true
height: 450
round: 2
unit_prefix: k
wide: true
sections:
- entities:
remaining: Rounding
color: lightgreen
children:
- sensor.givtcp_ce2209g009_load_power
remaining: Rounding
color: darkgreen
children:
- sensor.givtcp_ce2209g009_solar_to_battery
remaining: Rounding
color: red
children:
- entities:
- entity_id: sensor.givtcp_ce2209g009_load_power
remaining: unmonitored
color: blue
children:
- sensor.ups_cupboard_current_energy
- sensor.shellyem3_485519c9a766_channel_a_power
- sensor.dishwasher_power
- sensor.all_computers_power
- sensor.all_tvs_power
- sensor.kettle_smart_plug_power
- sensor.microwave_smart_plug_2_power
- entity_id: sensor.givtcp_ce2209g009_solar_to_battery
- entities:
You can’t squeeze 1.41kW into 1.2kW. There will always be some leftover. You can rearrange Battery and Solar if you want Solar to fill House Load first. Or you can just remove the Rounding entity.
There is a feature planned to reconcile such inconsistencies but that would force Solar+Battery to 1.2kW or House Load to 1.41k . I could just leave the old labels when this is done but not sure if this would make any sense. Reconcile parent and children state inconsistency · Issue #37 · MindFreeze/ha-sankey-chart · GitHub
@ragman11 Figured it out. I don’t know why you have all these entities that are children of themselves but, as stated in the README, all children must exist in subsequent sections. This means the last section can’t have any children.
Thank you for taking the time to reply and explain. Very much appreciated.
thank you for your help, I guess I have it like this cause this was the only way with the outcome I liked .
