Anyone using the Sankey Chart Card?
A card can only show data that home assistant has, and HA doesn’t track that per device
I don’t seem to be able to get the chart to show all the connections it should.
There should be a flow of power from Grid to the battery and from the Battery Use to Export. I think I’ve got those included in the config, but they don’t seem to work. The data is from a Telsa Powerwall and SolarEdge Inverter.
Can anyone spot what I’m doing wrong?
height: 200
unit_prefix: k
round: 1
min_box_height: 10
min_box_distance: 5
show_states: true
show_units: true
sections:
  - entities:
      - name: Solar
        type: entity
        children:
          - sensor.powerwall_battery_import
          - sensor.powerwall_site_export
          - sensor.powerwall_load_import
        entity_id: sensor.solaredge_lifetime_energy
        color: var(--warning-color)
        color_on_state: false
      - name: Grid
        type: entity
        children:
        entity_id: sensor.powerwall_site_import
        color: brown
  - entities:
      - name: Battery Charging
        type: entity
        children:
          - sensor.powerwall_battery_export
        entity_id: sensor.powerwall_battery_import
        color: var(--success-color)
      - type: passthrough
        children:
        entity_id: sensor.powerwall_site_export
      - type: passthrough
        children:
        entity_id: sensor.powerwall_load_import
  - entities:
      - name: Battery Use
        type: entity
        children:
        entity_id: sensor.powerwall_battery_export
        color: purple
      - type: passthrough
        children:
      - type: passthrough
        children:
  - entities:
      - type: entity
        children: []
      - type: entity
        children: []
energy_date_selection: true
type: custom:sankey-chart
min_state: 0
show_names: true
show_icons: false
wide: true
title: Power flow
Try changing the order in the config. The card doesn’t know how big each connection is yet (it is a planned feature) so it tries to guess based on the order.
I think the difficulty is the size of each connection changes depending on the time of day and conditions (eg if there’s much solar). I’ve re-ordered a couple of things and it’s helped. Thanks
I’m experiencing a weird problem. Sankey chart with 3 sections seems to work just fine, but adding 4th section breaks the card. Here is my working config with 3 sections:
show_names: true
wide: true
sections:
  - entities:
      - entity_id: sensor.ginlong_solis_inverter_active_power
        icon: mdi:sun-wireless-outline
        children:
          - sensor.gavazzi_esp32_total_power
          - sensor.power_to_grid
      - entity_id: sensor.power_from_grid
        color: red
        icon: mdi:transmission-tower-import
        children:
  - entities:
      - entity_id: sensor.gavazzi_esp32_total_power
        name: Total consumption
        icon: mdi:home
        children:
          - sensor.gavazzi_esp32_power_l1
          - sensor.gavazzi_esp32_power_l2
          - sensor.gavazzi_esp32_power_l3
      - entity_id: sensor.power_to_grid
        color: green
        icon: mdi:transmission-tower-export
        children:
          - sensor.ginlong_solis_inverter_active_power
  - entities:
      - entity_id: sensor.gavazzi_esp32_power_l1
      - entity_id: sensor.gavazzi_esp32_power_l2
      - entity_id: sensor.gavazzi_esp32_power_l3
As soon as I add 4th section like this:
show_names: true
wide: true
sections:
  - entities:
        children:
        color: red
        children:
  - entities:
        icon: mdi:home
        children:
        color: green
        children:
  - entities:
        children:
          - sensor.shellyplug_s_7c87ceba9f60_power
  - entities:
      - entity_id: sensor.shellyplug_s_7c87ceba9f60_power
I get this:
Error: Missing connection: sensor.gavazzi_esp32_power_l3 - sensor.shellyplug_s_7c87ceba9f60_power
Any ideas what I might be doing wrong here? If I split 4 section card into two separate cards with 2 sections they both work just fine.
The error msg is not right but you have sensor.ginlong_solis_inverter_active_power as child in the second section and it doesn’t exist in the third or fourth. Try removing that from children.
Removed sensor.ginlong_solis_inverter_active_power from children, it works now, thank you! The error message really blinded me.
I have this same problem for a while now, but only for daily and weekly views. It indeed happens to entities that become unavailable during certain times. In my case e.g. solar energy sensors that are not reported during night time.
I am trying to transfer my values ​​from the energy dashboard. However, it doesn’t work and I don’t understand why. I have an fronius enegry meter.
I use the same sensors as the energy dashboard.
- type: custom:sankey-chart
  show_names: true
  unit_prefix: k
  round: 1
  wide: true
  sections:
    - entities:
        - entity_id: sensor.solarnet_power_photovoltaics
          children:
            - sensor.symo_8_2_3_m_1_energy_total
        - entity_id: sensor.solarnet_power_grid
          children:
Here are my sensors:
Does anyone know which sensors to use exactly with Fronius?
You only have 1 section. At the very least, you have to add another one containing sensor.symo_8_2_3_m_1_energy_total
Thats not my point in the picture you see 4,8 kW in sankey and in the energy dashboard you see 12,8 kwh and 2 kWH consumption.
The 4,8 kW ist the current solar grid power. I would expect that I see the same in sankey chart like in the energy dashboard.
Also 2 sections with 12,8 kWh orange and 2 kWh with default color
I think you are mixing kW and kWh. Your energy dash board shows energy in kWh while you have configured sankey with the kW entities that show power. Sankey chart supports both so you have to set it up with ones you want.
You can also try autoconfig for energy but it doesn’t work for everyone.
Yes it seem so, but how I said I just use my Fronius Sensor - the same like in the energy dashboard ;). I shared all my sensors, I don’t see which I should use instead.
So thats my question which Fronius sensor should I use that I have the same information like in the energy dashboard for solar and consumption.
@MindFreeze do you have an idea which sensor I need?
Is anyone happy with the Sankey using it as a power distribution card? If so, would be happy to see the yaml code. I have done several attempts, but always failed using this card. I have a pretty simple
configuration:
  • power from solar
  • power from grid
  • several consumptions, some of them with “childs” others not
woudl be great to see some really running solutions. Thanks JJ
I’m happy one :slight_smile: But be careful what you wish for :slight_smile: Here is how my setup looks right now:
And here is working code:
show_names: true
round: 1
wide: true
height: 900
show_icons: false
show_states: true
min_box_height: 5
min_box_distance: 10
sections:
  - entities:
      - entity_id: sensor.phase_a_power
        color: var(--red5)
        children:
          - sensor.power_total
      - entity_id: sensor.phase_b_power
        color: var(--red4)
        children:
      - entity_id: sensor.phase_c_power
        color: var(--red3)
        children:
      - entity_id: sensor.external_power_total
        color: var(--red2)
        children:
  - entities:
      - entity_id: sensor.power_total
        color: var(--magenta3)
        children:
          - sensor.attic_power_total
          - sensor.first_floor_power_total
          - sensor.ground_floor_power_total
          - sensor.basement_power_total
          - sensor.garden_power_total
        remaining:
          color: var(--orange3)
  - entities:
      - entity_id: sensor.attic_power_total
        color: var(--lightblue1)
        children:
          - sensor.tv_room_power_total
          - sensor.wardrobe_power_total
      - entity_id: sensor.first_floor_power_total
        color: var(--lightblue2)
        children:
          - sensor.dorota_office_power_total
          - sensor.mirek_office_power_total
          - sensor.library_power_total
      - entity_id: sensor.ground_floor_power_total
        color: var(--lightblue3)
        children:
          - sensor.living_room_power_total
          - sensor.toilet_power_total
          - sensor.kitchen_power_total
          - sensor.hall_power_total
      - entity_id: sensor.basement_power_total
        color: var(--lightblue4)
        children:
          - sensor.basement_main_power
          - sensor.my_it_rack
          - sensor.basement_equipment_power
      - entity_id: sensor.garden_power_total
        color: var(--green2)
        children:
          - sensor.garden_light_power
          - sensor.driveway_lights_power
          - sensor.external_stairway_lights_power
          - sensor.automover_power
          - sensor.garage_equipment_power
          - sensor.front_christmas_lights_power
          - sensor.balcony_christmas_lights_power
  - entities:
      - entity_id: sensor.tv_room_power_total
        color: var(--green3)
        children:
          - sensor.tv_room_main_light_total
          - sensor.desk_lamp_power
          - sensor.tv_shelf_illumination_power
          - sensor.tv_illumination_power
          - sensor.sony_bravia_tv_power
          - sensor.denon_avr_s750h_power
          - sensor.apple_tv_power
          - sensor.tv_room_equipment_power
          - sensor.stairway_lights_channel_4_power
      - entity_id: sensor.wardrobe_power_total
        children:
          - sensor.iron_power
      - entity_id: sensor.dorota_office_power_total
        color: var(--green1)
        children:
          - sensor.dorota_main_light_power_total
          - sensor.dorota_floor_lamp_power
          - sensor.dorota_office_equipment_power
          - sensor.dorota_imac_power
      - entity_id: sensor.mirek_office_power_total
        color: var(--lemon1)
        children:
          - sensor.mirek_ceiling_power
          - sensor.mirek_desk_lamp_power
          - sensor.mirek_mac_pro_power
          - sensor.mirek_work_laptop_power
          - sensor.mirek_office_equipment_power
      - entity_id: sensor.library_power_total
        color: var(--lemon2)
        children:
          - sensor.library_light_total
      - entity_id: sensor.living_room_power_total
        color: var(--lemon3)
        children:
          - sensor.living_room_ceiling_total
          - sensor.living_room_dinning_table_total
          - sensor.coffe_table_light_electric_consumption_w
          - sensor.living_room_table_lamp_power
          - sensor.marantz_model_30_power
          - sensor.living_room_equipment_power
      - entity_id: sensor.toilet_power_total
        color: var(--yellow2)
        children:
          - sensor.toilet_light_power
          - sensor.toilet_equipment_power
      - entity_id: sensor.kitchen_power_total
        color: var(--yellow3)
        children:
          - sensor.kitchen_main_lights_power
          - sensor.kitchen_table_power
          - sensor.induction_owen_power_total
          - sensor.shelly_coffee_machine_power
          - sensor.shelly_dishwasher_power
          - sensor.microwave_owen_power_total
          - sensor.shelly_washing_machine_power
          - sensor.pantry_power
          - sensor.ground_floor_equipment_power
      - entity_id: sensor.hall_power_total
        color: var(--yellow4)
        children:
          - sensor.stairways_power_total
          - sensor.hall_lights_power
  - entities:
      - entity_id: sensor.tv_room_main_light_total
        color: var(--orange1)
        name: TV Room Main Light
      - entity_id: sensor.desk_lamp_power
        name: TV Room Lamp
      - entity_id: sensor.tv_shelf_illumination_power
        name: Shelf Illumination
      - entity_id: sensor.tv_illumination_power
        name: TV Illumination
      - entity_id: sensor.sony_bravia_tv_power
        color: var(--cyan1)
        name: Sony Bravia AG9
      - entity_id: sensor.denon_avr_s750h_power
        color: var(--cyan1)
        name: Denon AVR-S750H
      - entity_id: sensor.apple_tv_power
        color: var(--cyan1)
      - entity_id: sensor.tv_room_equipment_power
        color: var(--magenta1)
        name: TV Room Devices
      - entity_id: sensor.stairway_lights_channel_4_power
        name: Attic Stairways Illumination
      - entity_id: sensor.iron_power
      - entity_id: sensor.dorota_main_light_power_total
        name: Dorota Main Lights
      - entity_id: sensor.dorota_floor_lamp_power
        name: Dorota Floor Lamp
      - entity_id: sensor.dorota_office_equipment_power
        name: Dorota Office Devices
      - entity_id: sensor.dorota_imac_power
        color: var(--cyan1)
      - entity_id: sensor.mirek_ceiling_power
        name: Mirek Main Lights
      - entity_id: sensor.mirek_desk_lamp_power
        name: Mirek Desk Lamp
      - entity_id: sensor.mirek_mac_pro_power
        color: var(--cyan1)
        name: Mirek Mac Pro
      - entity_id: sensor.mirek_work_laptop_power
        color: var(--cyan1)
      - entity_id: sensor.mirek_office_equipment_power
        name: Mirek Office Devices
      - entity_id: sensor.library_light_total
        name: Library Main Lights
      - entity_id: sensor.living_room_ceiling_total
        name: Living Room Ceiling Lights
      - entity_id: sensor.living_room_dinning_table_total
        name: Living Room Dinning Table
      - entity_id: sensor.coffe_table_light_electric_consumption_w
        name: Living Room Coffee Table
      - entity_id: sensor.living_room_table_lamp_power
        name: Living Room Lamp
      - entity_id: sensor.marantz_model_30_power
        color: var(--cyan1)
      - entity_id: sensor.living_room_equipment_power
        color: var(--cyan1)
        name: Other Equipment
      - entity_id: sensor.toilet_light_power
      - entity_id: sensor.toilet_equipment_power
        name: Toilet Equipment
      - entity_id: sensor.kitchen_main_lights_power
        name: Kitchen Main Lights
      - entity_id: sensor.kitchen_table_power
        name: Kitchen Table Lights
      - entity_id: sensor.induction_owen_power_total
        color: var(--cyan1)
      - entity_id: sensor.shelly_coffee_machine_power
        color: var(--cyan1)
      - entity_id: sensor.shelly_dishwasher_power
        color: var(--cyan1)
      - entity_id: sensor.microwave_owen_power_total
        color: var(--cyan1)
      - entity_id: sensor.shelly_washing_machine_power
        color: var(--cyan1)
      - entity_id: sensor.pantry_power
      - entity_id: sensor.ground_floor_equipment_power
        name: Ground Floor Devices
      - entity_id: sensor.stairways_power_total
      - entity_id: sensor.hall_lights_power
      - entity_id: sensor.basement_main_power
      - entity_id: sensor.my_it_rack
        color: var(--cyan1)
      - entity_id: sensor.basement_equipment_power
      - entity_id: sensor.garden_light_power
      - entity_id: sensor.driveway_lights_power
      - entity_id: sensor.external_stairway_lights_power
      - entity_id: sensor.automover_power
      - entity_id: sensor.garage_equipment_power
      - entity_id: sensor.front_christmas_lights_power
        name: Front Christmas Lights
      - entity_id: sensor.balcony_christmas_lights_power
        name: Balcony Christmas Lights
As yopu can see I do not have solars or so, but as External there is estimated power consumption that is not measured by my my main meter (Shelly 3EM). So same way it could be replaced by solar.
Here’s mine:
Code here. I have had to create a few custom sensors to get the right data out of Solarnet so the data makes sense.
type: custom:vertical-stack-in-card
cards:
    title: Live Power
    show_names: true
    round: 0
    wide: true
    height: 120
    style: |
      ha-card {
        border: solid 0px ;
    sections:
      - entities:
            icon: mdi:solar-power-variant
            children:
              - sensor.electricity_grid_export_current
              - sensor.electricity_load_current
          - entity_id: sensor.electricity_grid_import_current
            color: maroon
            children:
      - entities:
          - entity_id: sensor.electricity_load_current
            icon: mdi:power-plug
          - entity_id: sensor.electricity_grid_export_current
            color: rgb(0, 128, 0)
    title: Today's Energy
    show_names: true
    unit_prefix: k
    round: 2
    wide: true
    height: 120
    style: |
      ha-card {
        border: solid 0px ;
    sections:
      - entities:
          - entity_id: sensor.primo_8_2_1_1_energy_day
            color: rgb(255, 166, 0)
            children:
              - sensor.electricity_solar_export_daily
              - consumed
          - entity_id: sensor.electricty_grid_import_daily
            color: maroon
            children:
              - consumed
      - entities:
          - entity_id: sensor.electricity_solar_export_daily
            color: green
          - entity_id: consumed
            type: remaining_parent_state
Senor.yaml
    # Current Grid Import and Export
    electricity_grid_export_current:
      friendly_name: Current Grid Export
      unit_of_measurement: "W"
      value_template: >
        {% if states('sensor.solarnet_power_grid') < '0' -%}
          {{ states('sensor.solarnet_power_grid')|float * -1 }}
        {%- else -%}
          0
        {%- endif %}
    electricity_grid_import_current:
      friendly_name: Current Grid Import
      value_template: >
        {% if states('sensor.solarnet_power_grid') > '0' -%}
          {{ states('sensor.solarnet_power_grid')}}
        {%- else -%}
          0
        {%- endif %}
Can someone please help me?
I had the sankey-chart working for a while and recently I added some more monitoring devices and I’m not able to integrate them in the way I want in the sankey chart.
What I want to achieve is the following.
The sensor.energy_monitoring_meterkast_2_keuken_energy is monitoring ALL energy usage in the kitchen. I want to use that one as the state giver for the 'Keuken'
sensor.beneden_plug_koelkast_energy, sensor.beneden_plug_vriezer_energy and sensor.beneden_plug_keuken_vaatwasser_energy
are measuring the power usage of the Freezer, Fridge and Dishwasher.
All remaining power measured by sensor.energy_monitoring_meterkast_2_keuken_energy should show as Overige Keuken
With the YAML below the following is generated
As you can see there is a loose branch created.
YAML
height: 250
unit_prefix: k
round: 1
min_box_height: 5
min_box_distance: 8
show_states: true
show_units: true
sections:
  - entities:
      - type: entity
        children:
          - sensor.p1_meter_3c39e724af30_total_power_export_t2
          - sensor.p1_meter_3c39e724af30_total_power_export_t1
          - total
        color: yellow
        icon: mdi:solar-power-variant-outline
      - type: entity
        children:
          - total
        entity_id: sensor.p1_meter_3c39e724af30_total_power_import_t1
        add_entities:
          - sensor.p1_meter_3c39e724af30_total_power_import_t2
        subtract_entities:
        name: Import vanaf het net
        color: lightsteelblue
  - entities:
      - type: entity
        children: []
        entity_id: sensor.p1_meter_3c39e724af30_total_power_export_t2
        subtract_entities:
          - sensor.p1_meter_3c39e724af30_total_power_import_t1
        color: green
      - type: entity
        children: []
        entity_id: sensor.p1_meter_3c39e724af30_total_power_export_t1
        subtract_entities:
        color: green
      - type: remaining_parent_state
        children:
          - unknown
          - sensor.energy_monitoring_meterkast_2_keuken_energy
          - werkkamer
          - zolder
          - kelder
          - badkamer
        entity_id: total
        icon: mdi:home-lightning-bolt
  - entities:
        children: []
        entity_id: unknown
        color: grey
        icon: mdi:help-network
      - entity_id: sensor.energy_monitoring_meterkast_2_keuken_energy
        icon: mdi:countertop
        color: purple
        children:
          - overige_keuken
          - sensor.beneden_plug_koelkast_energy
          - sensor.beneden_plug_vriezer_energy
          - sensor.beneden_plug_keuken_vaatwasser_energy
      - type: remaining_child_state
        children:
          - sensor.beneden_plug_server_energy
          - sensor.beneden_plug_3d_printer_energy
          - sensor.beneden_plug_pc_bart_energy
        entity_id: werkkamer
        icon: mdi:hammer-wrench
        color: orange
        children:
          - sensor.boven_plug_zolder_wasmachine_energy
        entity_id: zolder
        color: red
        icon: mdi:home-roof
        children:
          - sensor.energy_monitoring_meterkast_2_boiler_energy
        entity_id: badkamer
        icon: mdi:bathtub
        color: aqua
        children:
          - sensor.beneden_plug_taxidermie_vriezer_energy
        entity_id: kelder
        color: yellow
        icon: phu:rooms-storage
  - entities:
        entity_id: overige_keuken
        children:
  - entities:
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_koelkast_energy
        icon: mdi:fridge
        color: purple
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_vriezer_energy
        icon: mdi:fridge-industrial
        color: purple
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_keuken_vaatwasser_energy
        icon: mdi:dishwasher
        color: purple
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_server_energy
        icon: mdi:server-network
        color: orange
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_pc_bart_energy
        icon: mdi:desktop-classic
        color: orange
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_3d_printer_energy
        icon: mdi:printer-3d
        color: orange
      - type: entity
        children: []
        entity_id: sensor.boven_plug_zolder_wasmachine_energy
        icon: mdi:washing-machine
        color: red
      - type: entity
        children: []
        entity_id: sensor.energy_monitoring_meterkast_2_boiler_energy
        icon: mdi:water-boiler
        color: aqua
      - type: entity
        children: []
        entity_id: sensor.beneden_plug_taxidermie_vriezer_energy
        color: yellow
wide: true
show_names: true
show_icons: true
min_state: 0
Hi all,
This is what I got so far, after fiddling around with the Sankey diagram. One image shows a day where we used more energy than the solar panels produced, the other image shows a day where we produced more than we used.
Usage > production:
Usage < production:
I’m pretty happy with the result so far. The only thing I don’t like is how the icons are rendered. The bars are a bit too narrow for the icons to nicely fit. I couldn’t find a setting to make the bars wider. Or is there a setting for that? To be honest, I think it would be better if the icons were rendered as part of the label. That would also work with bars that are not that high, such as those of my lightbulbs.
YAML
type: vertical-stack
cards:
  - type: energy-date-selection
  - height: 500
    unit_prefix: k
    round: 1
    min_box_height: 3
    show_states: true
    show_units: true
    sections:
      - entities:
          - type: entity
            children:
              - sensor.electricity_meter_energieproductie_tarief_2
              - sensor.electricity_meter_energieproductie_tarief_1
              - total
            entity_id: sensor.solarpanels_energy_production
          - type: entity
            children:
              - total
            entity_id: sensor.electricity_meter_energieverbruik_tarief_1
            add_entities:
              - sensor.electricity_meter_energieverbruik_tarief_2
            subtract_entities:
            color: var(--error-color)
      - entities:
          - type: entity
            children: []
            entity_id: sensor.electricity_meter_energieproductie_tarief_2
            subtract_entities:
              - sensor.electricity_meter_energieverbruik_tarief_1
          - type: entity
            children: []
            entity_id: sensor.electricity_meter_energieproductie_tarief_1
            subtract_entities:
            children:
              - no_area
              - unknown
            entity_id: total
      - entities:
            children:
              - verlichting
              - overig
            entity_id: no_area
            name: Apparaten met verbruikmeter
            icon: mdi:meter-electric
            children: []
            entity_id: unknown
            name: Apparaten zonder verbruikmeter
            icon: mdi:lightbulb-question-outline
      - entities:
            children:
              - sensor.eettafel_energy
              - sensor.lamp_berging_zolder_energy
              - sensor.lotek_1_energy
              - sensor.lotek_2_energy
            entity_id: verlichting
            icon: mdi:lightbulb-group-outline
            children:
              - sensor.stekker_droger_summation_delivered
              - sensor.stekker_wasmachine_summation_delivered
            entity_id: overig
      - entities:
          - type: entity
            children: []
            entity_id: sensor.eettafel_energy
            icon: mdi:ceiling-light
          - type: entity
            children: []
            entity_id: sensor.lamp_berging_zolder_energy
            name: Verlichting berging zolder
            icon: mdi:lightbulb
          - type: entity
            children: []
            entity_id: sensor.lotek_1_energy
            icon: mdi:floor-lamp-outline
          - type: entity
            children: []
            entity_id: sensor.lotek_2_energy
          - type: entity
            children: []
            entity_id: sensor.stekker_droger_summation_delivered
            icono: mdi:tumble-dryer
          - type: entity
            children: []
            entity_id: sensor.stekker_wasmachine_summation_delivered
    min_state: 0
    show_names: true
    show_icons: true
    wide: true
is your heat pump cycling too often?
No. It’s a ducted heat pump, not a mini-split.
