ikke-t
(Ilkka Tengvall)
December 23, 2023, 3:58pm
1
I’ve had this “problem” for about a year now. I thought to ask for help. The apex chart shows today (24h) and tomorrow (24h) series of electricity prices. The setup is copied from here. I don’t get why the area doesn’t get filled for the hour 23:00-24:00. Any ideas?
See how there is gap where the measurement from time 23 doesn’t fill the following our like the other hours do?
There is the black gap between today’s and tomorrow’s series. I have tried all I can come up with to fiddle with series settings, but no help.For every other hour it fills the rest of the hour with the proper level, but not 23:00-24:00. Why?
Here is the config:
type: custom:apexcharts-card
graph_span: 48h
span:
start: day
offset: +0H
header:
title: Sähkön tuntihinta
show: true
show_states: false
colorize_states: true
hours_12: false
stacked: false
experimental:
color_threshold: true
all_series_config:
show:
legend_value: false
datalabels: false
extremas: true
in_brush: true
float_precision: 3
type: area
invert: false
fill_raw: zero
color_threshold:
- value: -1
color: 1E90FF
- value: 6
color: '008000'
- value: 12
color: DAA520
- value: 25
color: FF0000
opacity: 0.7
now:
show: true
label: Now
color: red
series:
- entity: sensor.nordpool_kwh_fi_eur_1_100_024
extend_to: false
data_generator: |
return entity.attributes.raw_today.map((start, index) => {
return [new Date(start["start"]).getTime(), entity.attributes.raw_today[index]["value"]];
data_generator: |
return entity.attributes.raw_tomorrow.map((start, index) => {
return [new Date(start["start"]).getTime(), entity.attributes.raw_tomorrow[index]["value"]];
apex_config:
chart:
height: 400px
animations:
enabled: true
easing: easeinout
speed: 800
animateGradually:
enabled: true
delay: 150
zoom:
enabled: true
type: x
autoScaleYaxis: true
zoomedArea:
fill:
color: '#90CAF9'
opacity: 0.4
stroke:
color: '#0D47A1'
opacity: 0.4
width: 1
legend:
show: false
floating: true
offsetY: 25
yaxis:
opposite: false
reversed: false
logarithmic: false
decimalsInFloat: 2
labels:
show: true
tooltip:
enabled: true
crosshairs:
show: true
xaxis:
labels:
show: true
rotate: -45
rotateAlways: true
logarithmic: true
stroke:
show: true
curve: stepline
lineCap: butt
colors: undefined
plotOptions:
candlestick:
colors:
upward: '#00B746'
downward: '#EF403C'
wick:
useFillColor: true
markers:
grid:
show: true
strokeDashArray: 1
position: front
xaxis:
lines:
show: true
All values are ok, it’s just the damned black gap of area in middle that makes me crazy…
Suggest to ask apexcharts-related questions in the dedicated thread .
ikke-t
(Ilkka Tengvall)
December 28, 2023, 5:50pm
3
Thanks, I was considering it. But such mega thread is against any forum logic. 3k+ messages in one thread makes it impossible to find any solutions from the endless wall of text. Forum questions should have clear topic and answers to given question. Next questions in different topic.
Instead you suggest to create 3k posts about same.
Not a better way.
honkkkis
(Honkkis)
January 31, 2024, 5:13am
5
Having exactly same problem, probably many other people too.
I have noticed, that this behavior has something to do with daylight saving, it seems to be there during winter, but not summer. Of course, winter time is by definition official time, at least here in Finland.
When reading raw hourly values from Nordpool (I have both Entso-E and Nordpool HACS), they are correct, it’s easy to add numeric entity to dashboard and check the value. Compared to Apex charts, chart is shifted one hour. Obviously, “the shift” has something to do with handling of timestamps and/or DST mechanism, that Apex charts doesn’t understand with commonly used config examples.
And yes, I have to agree with @ikke-t , 3k answers / questions-threads are PITA to read and search. And after that, parse all the differences between changes between versions etc.
NO, this was exactly NOT his suggestion.
So I had the same problem and found this post when googling. Figured I should share the solution i am using.
So the solution (or perhaps workaround) is to concatenate the two series to one with this function. I found it somewhere on the internet (i cant find it with google anymore)
data_generator: |
.concat(entity.attributes.raw_tomorrow).map((p) => {
return [new Date(p.start), p.value];
and as I am writing this I realise that I do not know what happens after midnight
viriol
December 27, 2024, 6:17pm
8
I’m having the exact same problem. Did you ever come up with a solution?
Here’s my code:
type: custom:config-template-card
variables:
getPriceState: |
temp => {
if (temp >= ((states[this._config.entities[0]].attributes.max - states[this._config.entities[0]].attributes.average) * 0.4 + states[this._config.entities[0]].attributes.average)) {
return "red";
} else if (temp >= ((states[this._config.entities[0]].attributes.average - states[this._config.entities[0]].attributes.min) * 0.4 + states[this._config.entities[0]].attributes.min)) {
return "orange"
return "green";
entities:
- sensor.nordpool
card:
now:
show: true
label: Nu
color: >-
${getPriceState(states[this._config.entities[0]].attributes.current_price)}
experimental:
graph_span: "${states[this._config.entities[0]].attributes.tomorrow_valid ? '2d' : '1d'}"
apex_config:
dataLabels:
enabled: true
dropShadow:
enabled: true
plotOptions:
bar:
rangeBarOverlap: true
borderRadius: 0
columnWidth: 70%
chart:
height: 300px
legend:
showForSingleSeries: false
yaxis:
min: 0
decimalsInFloat: 0
tickAmount: 3
forceNiceScale: true
xaxis:
labels:
format: HH
markers:
style: hollow
all_series_config:
show:
offset_in_name: true
header:
show: true
show_states: true
span:
start: day
series:
- entity: ${this._config.entities[0]}
type: line
unit: öre/kWh
float_precision: 1
extend_to: false
stroke_width: 3
show:
in_header: false
legend_value: false
extremas: false
data_generator: |
return entity.attributes.today.map((price, index) => {
return [new Date(Date.now()).setHours(index,0,0), price];
color_threshold:
- value: 0
color: green
- value: >-
${(states[this._config.entities[0]].attributes.average -
states[this._config.entities[0]].attributes.min}
color: orange
- value: >-
${(states[this._config.entities[0]].attributes.max -
states[this._config.entities[0]].attributes.average}
color: red
type: line
unit: öre/kWh
float_precision: 1
extend_to: false
stroke_width: 3
show:
in_chart: >-
${states[this._config.entities[0]].attributes.tomorrow_valid ? true :
false}
in_header: false
legend_value: false
extremas: false
data_generator: |
return entity.attributes.tomorrow.map((price, index) => {
return [new Date(Date.now() + ( 3600 * 1000 * 24)).setHours(index,0,0), price];
color_threshold:
- value: 0
color: green
- value: >-
color: orange
- value: >-
color: red
attribute: min
type: line
color: green
float_precision: 1
unit: " öre"
group_by:
duration: 1d
show:
in_chart: false
legend_value: false
attribute: average
type: line
color: orange
float_precision: 1
unit: " öre"
group_by:
duration: 1d
show:
in_chart: false
legend_value: false
in_header: false
unit: " öre"
color: >-
type: line
show:
in_chart: false
float_precision: 1
attribute: max
type: line
color: red
float_precision: 1
unit: " öre"
group_by:
duration: 1d
show:
in_chart: false
legend_value: false
My solution works. Se above.
viriol
December 28, 2024, 12:16am
10
Got it, thanks! Works after some help with ChatGPT
