You are missing
group_by:
start_with_last: true
I made a separate post about a dynamic statistics graph here:
You are missing
group_by:
Would love to see your whole dashboard, this page looks great, I imagine the others are just as impressive!
Thanks a lot for the help and sharing how you do it! I’ll look into it and try to get Apex and long term statistics to work as good as it can. As I udnerstand it the problem right now is if I want a graph starting 1/1 2022 displaying one bar per month, that is still not doable?
Yes, it is not possible right now.
It seems thou that it just takes very long to query and aggregate yearly data on a monthly level.
However it is possible to aggregate the same data on a daily level.
Not sure why the former would be more ressource intensive though. It should be the other way around.
I’m trying to get the radial gauge render similar to the apex example found here (the blue gauge in the screenshot)
https://apexcharts.com/javascript-chart-demos/radialbar-charts/stroked-gauge/
I’m not offsetting gauge rotation like the apex sample. I just want to use the alternating strokes for the fill. Is the stroke / dashArray supported yet? My results are the orange in the screenshot.
I tried using apex_config: to mirror the example and have tried various values for the dashArray value. If I use 100 for the dashArray value it looks like it does try to render but I can’t figure out how to config to get a similar look. Any ideas or suggestions?
type: custom:apexcharts-card
header:
show: false
chart_type: radialBar
apex_config:
plotOptions:
radialBar:
hollow:
fill:
type: gradient
gradient:
shade: dark
shadeIntensity: 0.15
inverseColors: false
opacityFrom: 1
opacityTo: 1
stopps:
- 0
- 50
- 65
- 91
stroke:
dashArray: 4
legend:
show: false
series:
- entity: sensor.outside_temperature
SOLVED:
I needed to add “lineCap: flat”
to the stroke section
stroke:
dashArray: 4
lineCap: flat
Will you share your code ? I want to see the example of as_duration.
Has anyone found a way to set the width of the radial bars? As seen below, the width of the lines are different depending on if I have 2 or 3 sensors displayed. Would have been nice to have them look the same:
Hello, does anyone know how to align xaxis to have shared tooltip?
I have this:
and want to have this:
According to docs, times of series must be aligned which is what I thought group_by
is made for:
series:
- entity: sensor.loznice_temperature
color: '#b33dc6'
group_by:
func: avg
duration: 5m
- entity: sensor.koupelna_teplomer_termostat_320
color: '#27aeef'
group_by:
func: avg
duration: 5m
- entity: sensor.sauna_teplomer_termostat_315
color: '#ea5545'
group_by:
func: avg
duration: 5m
- entity: sensor.obyvak_temperature
color: '#f46a9b'
group_by:
func: avg
duration: 5m
- entity: sensor.jidelna_temperature
color: '#edbf33'
group_by:
func: avg
duration: 5m
- entity: sensor.zimni_zahrada_teplomer_termostat_265
color: '#87bc45'
group_by:
func: avg
duration: 5m
- entity: sensor.hutch_temperature
color: gray
group_by:
func: avg
duration: 5m
graph_span: 24h
all_series_config:
stroke_width: 2
fill_raw: last
header:
title: Teplota
standard_format: true
apex_config:
legend:
position: top
view_layout:
grid-area: chart-temperature
Is there a way to lock the timezone in the graphs?
I’m travelling and am quite a few timezone away from my data which is misrepresenting the results.
Local graph (the correct one, EST timezone):
Graph while on travel (different computer time)
Current code:
series:
- entity: sensor.history_pump_today
type: column
group_by:
func: last
duration: 1d
- entity: sensor.history_heater_today
type: column
group_by:
func: last
duration: 1d
graph_span: 10d
stacked: true
span:
end: day
Hi Guys,
Im still hoping that soeone can advise me on the pop up infoirmation when hovering over the graph…?
But in the meantime I have has a few requests for the graph configuration so here it is:
graph_span: 24h
span:
start: day
stacked: true
header:
show: true
title: Solar Prod
all_series_config:
show:
extremas: false
series:
- entity: sensor.envoy_1220xxxxxxxx_current_energy_consumption
transform: return x *-1 ;
type: column
color: '#f37320'
group_by:
func: avg
duration: 5min
- entity: sensor.envoy_1220xxxxxxxx_current_energy_production
type: column
color: '#20a0f3'
group_by:
func: avg
duration: 5min
- entity: sensor.inst_energy_difference
type: column
name: Import (+) or Export (-)
color: '#646466'
group_by:
func: avg
duration: 5min
And for the sensor.instant_energy_difference:
# Displays the difference between Solar production and Grid import
sensors:
inst_energy_difference:
friendly_name: Instant Energy Difference
icon_template: >
{% if (states("sensor.inst_energy_difference") | int(default=0) > 0) -%}
mdi:solar-panel
{%- elif (states("sensor.inst_energy_difference") | int(default=0) < 0) -%}
mdi:transmission-tower
{%- else -%}
mdi:power-off
{%- endif %}
friendly_name_template: >
Currently Exporting
Currently Importing
{%- else -%}
Balanced
{%- endif %}
unit_of_measurement: "W"
device_class: power
value_template: >
{{ '%0.1f' | format(states('sensor.envoy_1220xxxxxxxx_current_energy_production') | float(default=0) - states('sensor.envoy_1220xxxxxxxx_current_energy_consumption') | float(default=0)) }}
I want to migrate from the great mini-graph-card to this more advanced card. But I’m stuck with using non-numerical sensors. The repository readme states that those are supported, but I cannot find how. I currently have this in mini-graph-card:
Where I have the relative and absolute humidity plotted in the graph and using thermal comfort I can also display the current humidity. Can anyone elaborate on that or provide an example on how to do this?
hi all,
is there a way to increase the curve smoothness to something similar than minigraph
Try the following:
- entity: sensor.whatever
group_by:
func: avg
duration: 20min
thanks , it worked with a very high value in duration
I just wanted to say thanks! I implemented the “group_by” section of code and it works great!
Is there a way to reduce the offset from the edge of the card to the yaxis labels?
I want to graph/labels to cover the entire card
I am using a sensor.day_night in my apex-chart, it works fine but the columns are only in the past.
Can I use the night values also for the future?
Example:
- entity: sensor.day_night
curve: stepline
type: area
transform: 'return x === ''Day'' ? 0 : 30 ;'
color: grey
stroke_width: 0
opacity: 0.3
show:
in_header: false
legend_value: false
Could you please share your code for the layout you have created so far?
