Hi! Bit of a late reply but did you ever get this figured out? The radial bar size.
Hello here! I’ve got a chart with two series. For one of the two (Buienradar in the images below), if I set the type to either line
or area
, the line is not visible. On hover it is confirmed that the the data point does exist. Also, for the column
type it shows just fine.
The other serries does not show this behavior and displays the line correctly. Does anyone know what is going on?
type: column
type: line
Dear Arnault,
Any chances to see code for it?
I have weird problem with weeks.
In the end I am trying to explore my long term statistics similar to the energy-dashboard.
But i can’t figure out how to deal with different time spans.
This problem only seems to affect statistics-data, not the regular recorder/history.
Here is what works as expected:
type: custom:apexcharts-card
graph_span: 1month
span:
start: month
offset: -30d
series:
- entity: sensor.home_meter_grid_energy
type: column
statistics:
type: sum
period: day
align: end
group_by:
func: diff
duration: 1d
fill: last
start_with_last: true
float_precision: 2
When I change the graph_span, the span start and offset to week, I don’t get any data:
The scale of the x-axis adjusts, but no data.
Am I doing something wrong? Is this a bug?
I have the same issues and I’m also trying to display the long term statistics just like the energy dashboard but in the beautiful Apex way A few weeks ago it sounded like RomRider har an idea on how to change this so hopefully there will be a fix for this. Please share if you find a work-around
Beautiful layout! Would you mind sharing some code showing how you got the small graph cards and the orange button?
Sorry for the delay @filikun, @Airyphyla, @alexreddy78 and @Lunkobelix .
I’m at the begining to create my own card with custom:button-card and I’m sure there are much cleaner ways of doing things than me. But here is the yaml of my card :
card_pool:
styles:
card:
- padding: "0px"
grid:
- grid-template-areas: "'cam overlay' 'measures measures'"
- grid-template-columns: "1fr 0"
- grid-template-rows: "180px min-content"
custom_fields:
overlay:
- height: 180px
- background: linear-gradient(180deg, rgba(var(--rgb-card-background-color),0) 45%, rgba(var(--rgb-card-background-color),1) 100%)
- opacity: 1
- padding: 0
custom_fields:
cam:
card:
type: picture-glance
camera_image: camera.poolcamera
entities: []
card_mod:
style:
hui-image:
div img {
height: 180px;
object-fit: cover;
object-position: center -25px;
hui-image {
height: calc(100% - 0px);
ha-card {
border-bottom-left-radius: 0px;
border-bottom-right-radius: 0px;
box-shadow: none;
ha-card .box {
display: none;
overlay: <div></div>
measures:
card:
type: custom:button-card
name: Analyses de l'eau
label: "[[[ return states['sensor.pool_analysed_at'].state; ]]]"
show_name: true
show_label: true
styles:
card:
- padding: 4%
- border-radius: 0px
- box-shadow: "none"
grid:
- grid-template-areas: "'n tmp . ph . redox . sel' 'l tmp . ph . redox . sel' 'graph graph graph graph graph graph graph graph' 'actions actions actions actions actions actions actions actions' 'infos infos infos infos infos infos infos infos'"
- grid-template-columns: "1fr 45px 5px 45px 5px 45px 5px 45px"
- grid-template-rows: "min-content min-content min-content"
name:
- font-weight: "bold"
- font-size: "14px"
- place-self: end left
label:
- font-size: "10px"
- place-self: start
- filter: "opacity(40%)"
custom_fields:
tmp:
card:
template: button_pool_measure
label: "[[[ return states['sensor.pool_temperature'].state + '°C'; ]]]"
variables:
color: "blue"
select_value: "Temperature"
ph:
card:
label: "[[[ return states['sensor.pool_ph'].state; ]]]"
variables:
color: "green"
select_value: "PH"
alert: >
let ph = states['sensor.pool_ph'].state;
if (ph < 7.1 || ph > 7.5) return true;
return false;
redox:
card:
label: "[[[ return states['sensor.pool_orp'].state + 'mV'; ]]]"
variables:
color: "yellow"
select_value: "ORP"
alert: >
let orp = states['sensor.pool_orp'].state;
if (orp < 600 || orp > 800) return true;
return false;
sel:
card:
label: "[[[ return states['sensor.pool_salinity'].state + 'g/l'; ]]]"
variables:
color: "red"
select_value: "Sel"
alert: >
let salinity = states['sensor.pool_salinity'].state;
if (salinity < 3 || salinity > 3.4) return true;
return false;
graph:
card:
entity: input_select.ui_pool_select_measure
show_icon: false
state:
- name: Température de l'eau
value: Temperature
- name: pH de l'eau
value: PH
- name: Rédox de l'eau
value: ORP
- name: Salinité de l'eau
value: Sel
styles:
card:
- padding-bottom: 0
name:
- font-weight: "normal"
- font-size: "12px"
- place-self: center left
grid:
- grid-template-areas: "'n i1 . i2 . i3' 'graph graph graph graph graph graph'"
- grid-template-columns: "1fr 61px 6px 61px 6px 61px"
- grid-template-rows: "min-content min-content"
custom_fields:
i1:
card:
template: button_pool_period
variables:
period: Jour
i2:
card:
variables:
period: Semaine
i3:
card:
variables:
period: Mois
graph:
card:
type: grid
square: false
columns: 1
cards:
- type: conditional
conditions:
- entity: input_select.ui_pool_select_measure
state: 'Temperature'
card:
template: graph_pool_measure
variables:
entity: sensor.pool_temperature
color: "blue"
decimal: 0
- type: conditional
conditions:
state: 'PH'
card:
variables:
entity: sensor.pool_ph
color: "green"
decimal: 1
yaxis:
min: 6.9
max: 7.7
annotations:
min:
value: 7.1
text: "7.1"
max:
value: 7.5
text: "7.5"
- type: conditional
conditions:
state: 'ORP'
card:
variables:
entity: sensor.pool_orp
color: "yellow"
decimal: 0
yaxis:
min: 500
max: 800
annotations:
min:
value: 650
text: "650mv"
max:
value: 750
text: "750mv"
- type: conditional
conditions:
state: 'Sel'
card:
variables:
entity: sensor.pool_salinity
color: "red"
decimal: 1
curve: "stepline"
yaxis:
min: 2.9
max: 3.4
actions:
card:
styles:
card:
- padding-top: 0
grid:
- grid-template-areas: " 'a1 . a2 . a3'"
- grid-template-columns: "1fr 10px 1fr 10px 1fr"
- grid-template-rows: "min-content"
custom_fields:
a1:
card:
template: button_pool_action
entity: switch.piscine_filtration
icon: mdi:engine
label: "[[[ return states['sensor.pool_pump_duration'].state; ]]]"
variables:
schedules: "[[[ return states['sensor.pool_pump_hours'].state; ]]]"
a2:
card:
entity: switch.piscine_surpresseur
icon: mdi:robot-mower
label: "[[[ return states['sensor.robot_duration'].state; ]]]"
variables:
schedules: "[[[ return states['input_text.robot_hours'].state; ]]]"
a3:
card:
entity: switch.piscine_electrolyseur_sel
icon: mdi:electron-framework
label: "[[[ return states['sensor.electrolyseur_sel_duration'].state; ]]]"
variables:
schedules: "-"
infos:
card:
styles:
card:
- padding-top: 0
grid:
- grid-template-areas: " 'i1 . i2 . i3 . i4'"
- grid-template-columns: "1fr 10px 1fr 10px 1fr 10px 1fr"
custom_fields:
i1:
card:
template: button_pool_info
icon: mdi:lightbulb
i2:
card:
label: "[[[ return states['input_select.pool_pump'].state; ]]]"
tap_action:
action: 'fire-dom-event'
browser_mod:
command: "popup"
large: true
hide_header: true
card:
type: "custom:button-card"
template: "popup_pool_pump"
style:
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
box-shadow: none;
border-radius: 0px;
background-color: var(--main-background-color);
i3:
card:
label: Il y a 10 jours
variables:
alert: false
i4:
card:
label: Il y a 25 jours
variables:
alert: true
graph_pool_measure:
variables:
entity : ""
color: ""
decimal: 0
curve: "smooth"
annotations:
min:
value: -100
text: ""
max:
value: -100
text: ""
yaxis:
min: auto
max: auto
styles:
card:
- padding: 0px
grid:
- grid-template-areas: "'graph'"
- grid-template-columns: "1fr"
custom_fields:
graph:
card:
header:
show: false
graph_span: >
switch (states['input_select.ui_pool_select_measure_period'].state) {
case "Mois":
return "4w";
break
case "Semaine":
return "1w";
break;
case "Jour":
return "1d";
break;
series:
- entity: "[[[ return variables.entity; ]]]"
stroke_width: 3
color: "[[[ return `var(--google-${variables.color})`; ]]]"
fill_raw: last
type: area
yaxis:
- decimals: "[[[ return variables.decimal; ]]]"
min: "[[[ return variables.yaxis.min; ]]]"
max: "[[[ return variables.yaxis.max; ]]]"
apex_config:
tickAmount: 5
forceNiceScale: true
labels:
offsetX: -15
apex_config:
chart:
height: 200px
grid:
padding:
left: 0
right: 0
fill:
type: 'gradient'
gradient:
shade: "light"
type: "vertical"
opacityFrom: 0.7
opacityTo: 0.1
stops: [0, 100]
stroke:
curve: "[[[ return variables.curve; ]]]"
annotations:
position: 'front'
yaxis:
- y: "[[[ return variables.annotations.min.value; ]]]"
y2: "[[[ return variables.annotations.max.value; ]]]"
opacity: 0.2
- y: "[[[ return variables.annotations.max.value; ]]]"
strokeDashArray: 0
label:
text: "[[[ return variables.annotations.max.text; ]]]"
offsetX: -5
offsetY: -1
style:
fontSize: 8px
strokeDashArray: 0
label:
text: "[[[ return variables.annotations.min.text; ]]]"
offsetX: -5
offsetY: -1
style:
fontSize: 8px
card_mod:
style: |
ha-card {
border-radius: 0px;
box-shadow: none;
padding: 0;
margin: 0;
#state__name, .apexcharts-xaxis-label, .apexcharts-yaxis-label {
font-size: 10px !important;
button_pool_measure:
variables:
color: "blue"
alert: false
show_name: true
show_label: true
aspect_ratio: 1/1
styles:
card:
- padding: "0px"
- box-shadow: none
- background-color: var(--primary-background-color)
- background-image: >
let theme = hass.themes.themes[hass.themes.theme].modes[(hass.themes.darkMode ? "dark" : "light")];
let color_bckg = theme[`google-${variables.color}`].replace('#', '%23');
let opacity = theme['opacity-bg'];
return "url(\"data:image/svg+xml;utf8,<svg xmlns='http://www.w3.org/2000/svg' xmlns:xlink='http://www.w3.org/1999/xlink' viewBox='0 0 1440 1440'><path fill='"+color_bckg+"' fill-opacity='"+opacity+"' d='m 0,566 48,26.7 C 96,619 192,673 288,699.3 384,726 480,726 576,710 c 96,-16 192,-48 288,-42.7 96,5.7 192,47.7 288,58.7 96,11 192,-11 240,-21.3 l 48,-10.7 v 754 H 1392 1152 864 576 288 48 0 Z'></path></svg>\")";
- background-size: 100%
grid:
- grid-template-areas: "'n' 'l'"
- grid-template-rows: "auto auto"
name:
- font-size: "10px"
label:
- font-size: "10px"
- color: >
if (hass.themes.darkMode){
return "#FFFFFF";
} else {
return `rgba(var(--color-${variables.color}), 1)`;
custom_fields:
notification:
- border-radius: "50%"
- position: "absolute"
- right: "2px"
- top: "14px"
- height: "12px"
- width: "12px"
- border: "1px solid var(--card-background-color)"
- font-size: "6px"
- line-height: "12px"
- background-color: >
return "rgba(var(--color-red),1)";
custom_fields:
notification: >
if (variables.alert) {
return `<ha-icon icon="mdi:exclamation" style="width: 9px; height: 9px; color: var(--primary-background-color);"></ha-icon>`
tap_action:
action: call-service
service: input_select.select_option
service_data:
entity_id: input_select.ui_pool_select_measure
option: "[[[ return `${variables.select_value}`; ]]]"
button_pool_period:
variables:
period: "Semaine"
show_name: true
styles:
card:
- padding: "5px 0px"
- box-shadow: none
if (states['input_select.ui_pool_select_measure_period'].state == variables.period) {
switch (states['input_select.ui_pool_select_measure'].state) {
case "Temperature":
return "var(--google-blue)";
case "PH":
return "var(--google-green)";
case "ORP":
return "var(--google-yellow)";
case "Sel":
return "var(--google-red)";
default:
return "var(--primary-background-color)";
} else {
name:
- font-size: "10px"
- color: >
return "white";
} else {
return "var(--primary-text-color)";
tap_action:
service_data:
entity_id: input_select.ui_pool_select_measure_period
option: "[[[ return `${variables.period}`; ]]]"
button_pool_action:
variables:
schedules: "-"
show_name: true
show_label: true
show_icon: true
styles:
card:
- box-shadow: none
grid:
- grid-template-areas: "'n' 'l' 'i' 'schedules'"
- grid-template-rows: "min-content min-content min-content min-content"
name:
- font-size: "12px"
label:
- font-size: "10px"
custom_fields:
schedules:
- font-size: "10px"
custom_fields:
schedules: "[[[ return `${variables.schedules}`; ]]]"
button_pool_info:
variables:
alert: false
show_name: true
show_label: true
show_icon: true
styles:
card:
- padding: "5px 10px"
- box-shadow: none
- height: 55px
grid:
- grid-template-areas: "'n' 'l' 'i'"
name:
- font-size: "10px"
label:
- font-size: "10px"
- padding-top: 5px
icon:
- padding-top: 3px
custom_fields:
notification:
- right: "2px"
- top: "2px"
- height: "16px"
- width: "16px"
- border: "2px solid var(--card-background-color)"
- font-size: "12px"
- line-height: "14px"
custom_fields:
notification: >
return `<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: var(--primary-background-color);"></ha-icon>`
For the question :
It’s both at the same time
For the choice of temperature, redox,… it’s an input_select with a conditional card and a unique chart template.
For the choice of the period it is also an input_select that I process in my chart template on the attribute graph_span
Wow! Thanks
this made me want to rebuild my own card (see above) that uses the config-template-card to do just that, adapt the graph_span based on an input_select.apex_span. Why use an extra card, if we can template directly (I wasnt aware)?
but, using
graph_span: >
[[[ return states['input_select.apex_span'].state; ]]]
throws the error
making me think templates aren’t supported on that field…
and the docs dont mention templates being supported either:
obviously my input_selects holds only valid options
now why would that be? How did you make the templates a valid graph_span input…
for now, back to:
type: custom:config-template-card
entities:
- input_select.apex_span
variables:
span: states['input_select.apex_span'].state
card:
graph_span: ${span}
if I enter the template you use, and adapt with my options, the card is displayed alright, but changing a selection does not update the graph at all. So a bit of a mystery here…
just in case: FR: allow template on graph_span · Issue #344 · RomRider/apexcharts-card · GitHub
I am seeking some help as I have spent hours fiddling can not see the forest from the trees now.
My Card is loading blank… annoying. I have other apex cards, working with no issue. This particular entity (actually group of entities) just will not work.
You can see its consuming some level of data, as it nows the timeline and scales on the axis’s. Legend also shows max values for the period.
Card:
span:
start: minute
header:
show: true
title: EMHASS Forecasts
show_states: true
colorize_states: true
now:
show: true
label: now
series:
- entity: sensor.p_pv_forecast
curve: stepline
show:
in_header: before_now
stroke_width: 1
data_generator: |
return entity.attributes.forecasts.map((entry) => {
return [new Date(entry.date), entry.p_pv_forecast];
- entity: sensor.p_batt_forecast
curve: stepline
show:
stroke_width: 1
data_generator: |
return [new Date(entry.date), entry.p_batt_forecast];
- entity: sensor.p_load_forecast
curve: stepline
show:
stroke_width: 1
data_generator: |
return [new Date(entry.date), entry.p_load_forecast];
Entity Attributes:
unit_of_measurement: W
friendly_name: Battery Power Forecast
forecasts:
- date: '2022-06-03 20:30:00+10:00'
p_batt_forecast: -7899
- date: '2022-06-03 21:00:00+10:00'
p_batt_forecast: -4320
- date: '2022-06-03 21:30:00+10:00'
p_batt_forecast: -7015
- date: '2022-06-03 22:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-03 22:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-03 23:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-03 23:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 00:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 00:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 01:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 01:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 02:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 02:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 03:00:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 03:30:00+10:00'
p_batt_forecast: 669
- date: '2022-06-04 04:00:00+10:00'
p_batt_forecast: -669
- date: '2022-06-04 04:30:00+10:00'
p_batt_forecast: 0
- date: '2022-06-04 05:00:00+10:00'
p_batt_forecast: 699
- date: '2022-06-04 05:30:00+10:00'
p_batt_forecast: 2643
- date: '2022-06-04 06:00:00+10:00'
p_batt_forecast: -4988
- date: '2022-06-04 06:30:00+10:00'
p_batt_forecast: 3653
- date: '2022-06-04 07:00:00+10:00'
p_batt_forecast: 2346
- date: '2022-06-04 07:30:00+10:00'
p_batt_forecast: 2268
- date: '2022-06-04 08:00:00+10:00'
p_batt_forecast: 1289
- date: '2022-06-04 08:30:00+10:00'
p_batt_forecast: 882
- date: '2022-06-04 09:00:00+10:00'
p_batt_forecast: -944
- date: '2022-06-04 09:30:00+10:00'
p_batt_forecast: -1528
- date: '2022-06-04 10:00:00+10:00'
p_batt_forecast: -2063
- date: '2022-06-04 10:30:00+10:00'
p_batt_forecast: -2357
- date: '2022-06-04 11:00:00+10:00'
p_batt_forecast: -2568
- date: '2022-06-04 11:30:00+10:00'
p_batt_forecast: -2674
- date: '2022-06-04 12:00:00+10:00'
p_batt_forecast: -2649
- date: '2022-06-04 12:30:00+10:00'
p_batt_forecast: -5000
- date: '2022-06-04 13:00:00+10:00'
- date: '2022-06-04 13:30:00+10:00'
- date: '2022-06-04 14:00:00+10:00'
- date: '2022-06-04 14:30:00+10:00'
p_batt_forecast: -1661
- date: '2022-06-04 15:00:00+10:00'
p_batt_forecast: 2157
- date: '2022-06-04 15:30:00+10:00'
p_batt_forecast: 4782
- date: '2022-06-04 16:00:00+10:00'
p_batt_forecast: 2131
- date: '2022-06-04 16:30:00+10:00'
p_batt_forecast: 5000
- date: '2022-06-04 17:00:00+10:00'
p_batt_forecast: -1152
- date: '2022-06-04 17:30:00+10:00'
- date: '2022-06-04 18:00:00+10:00'
- date: '2022-06-04 18:30:00+10:00'
- date: '2022-06-04 19:00:00+10:00'
- date: '2022-06-04 19:30:00+10:00'
- date: '2022-06-04 20:00:00+10:00'
Any help would be appreciated as I am starting to lose my marbles.
Maybe you are missing the graph_span
Try adding:
graph_span: 24h
span:
start: minute
I’m trying to learn how to setup these charts - is it possible (think I’ve seen it) to take a sensor and plot a graph over several days, lets say yesterday and today and have those in different colors or in some way divided so I can see clearly the different days?
Hi all,
Just found this ApexCharts card in HA, now looking if I can do an XY chart.
I want to make a chart where the X axis is not a datetime but a value from sensor history.
Idea is to make a hysteresis diagram for some temp/rh sensors.
Basically something like this:
https://apexcharts.com/javascript-chart-demos/scatter-charts/basic/
How would I do that in HA ?
There are still some other problems, but I solved this one.
You can not use span:start or span:end, then weeks work:
graph_span: 7day
span:
offset: +1d
series:
type: column
statistics:
type: sum
period: day
align: middle
group_by:
func: diff
duration: 1d
fill: last
float_precision: 2
show:
legend_value: false
I’m creating an Status page to show all tech related numbers.
I also want to replicate the Adguard DNS Queries and blocked queries stats, and stack them in 1 graph.
With the energy meter i spliced them to give me daily numbers (and tested first omn 15 min numbers.)
How it looks in adguard.
- i would keep the tekst style of 3.103.658 DNS Queries (Blocked total - sensor.adguard_dns_queries)
- i want to show the current total average percentage on the top right in the combined stats. (sensor.adguard_dns_queries_blocked_ratio)
- want want the hover to show the same as adguard do’s. number and date. but with the numbers blocked added between the date and total dns queries.
Look i want (photo-shopped):
How i made it so far. Almost, except some details.
Code:
graph_span: 6h #< will go to 60d
brush:
selection_span: 1h #< will go to 24h
header:
show: true
show_states: true
series:
- entity: sensor.dns_queries
stroke_width: 1.5
type: area
opacity: 0.1
- entity: sensor.dns_queries_blocked
stroke_width: 1.5
type: area
opacity: 0.1
cache: true
layout: minimal
color_list:
- blue
- red
Any help/direction is appreciated.
Hello. I’m trying to duplicate the mystical history chart that shows one sensor and then shades the area under the graph based on another sensor. (picture example attached) The example shows the thermostat current temperature and shades under the graph when the thermostat is in the ‘cooling’ state (actively running the AC).
It seems that this should be doable using this apex charts card by transforming the cooling state data and plotting it as an area curve.
- I need to get all of the data for the thermostat temperature and the thermostat cooling state (I have a template sensor for the cooling state)
- I need to transform the values of the cooling state sensor data into numbers: either the value of the thermostat temperature at the given time or 0. Thus, an area graph of the thermostat state will shade under the corresponding temperature value.
I’m trying to use the transform option but I’m having trouble with hass.states['sensor.thermostat_temperature']
. It is only returning the same value for every thermostat cooling data point (I think it’s the current value), instead of returning the value of the thermostat temperature at each thermostat cooling state data point.
Not working code:
transform: "
return x === 'idle' ? 0 : hass.states['sensor.thermostat_temperature'].state;
Maybe a feature could be added for shading an area graph based on a binary value from a different sensor?
Maybe this isn’t the correct way to approach the problem. Has anyone else tried to do this? Any advice?
Thanks.
Okay, at the end of writing this I realized that I could just make the thermostat cooling template sensor equal to the thermostat temperature when cooling or 0 when not, instead of trying to get apex charts to do a transform. I still would like to know how to use the hass.states['sensor.other']
in a transformation though.
In an area chart, is there a way to stack the area of positive curves together and negative curves together? I have electricity producers (solar+grid) and consumers (house, EV, grid, they all have the “invert: true” setting). If I just enable “stacked: true” it looks terrible wrong. I would like the producers to stack on the positive Y axis and the consumers to stack on the negative Y axis.
Any hint is appreciated (and thanks for the marvelous tool!)
I would love to patch that functionality - especially the select time period, but…
…where to put the code? If I simply put that as a card, I get a no card type defined
So I assumed to put that code into the ui-locelace.yaml
, but what to do then?
Might someone please give some hints?
Hi Guys,
When I move my finger or mouse over the Apex Graph there is a pop up showing data. Is there anyway to stop that action so not to block the chart with additional data that I dont want to see? Ideally at most I would only like to see the time line and values below the chart as I mouse or move across the chart.
