Does this work
transform: "return ((Math.round(x/1000))*1000) ;"
Does this work
Yes it did, thank you!
But I just realized that the group_by functionen messes it up anyway so I have to figure out how to get a smooth curve but also rounded values in the header.
group_by:
func: avg
duration: 10min
I am trying to integrate a few graphs into a dashboard and would like to make the entire background transparent. Is this possible for apex charts? I did nto find any option in the github docs.
Hi guys
I use garmin connection and related integration to record my daily steps data to hass.
Both garmin connection and integration has big update delay, which makes the correct daily data updated to the next day
In apexcharts-card, it looks like this
Has anyone found a way to control the width of the radialbar’s bar? Compare the two charts below and the left radialbar has thicker bars because only using one series:
Is there a way to set stacked: true
for specific entities only?
As you can see from the image, I’ve got whole of house ‘consumption’ but also showing key appliances individually. I’d like to just stack those appliances only without stacking the total consumption.
Yes, you can do it with hollow: size: like this:
type: horizontal-stack
cards:
- type: custom:apexcharts-card
chart_type: radialBar
series:
- entity: sensor.cpu_temperature
color: rgb(255, 87, 34)
max: 90
show:
legend_value: false
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: -108
endAngle: 108
hollow:
dataLabels:
name:
show: false
value:
show: false
track:
strokeWidth: 80%
margin: 0
legend:
show: false
chart:
height: 200
grid:
padding:
left: 10
right: 10
bottom: 0
series:
max: 90
show:
legend_value: false
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: -108
endAngle: 108
hollow:
dataLabels:
name:
show: false
value:
show: false
track:
strokeWidth: 80%
margin: 0
legend:
show: false
chart:
height: 200
grid:
padding:
left: 0
right: 0
bottom: 20
Ah, of course! Tanks for sharing!
Has anyone found a way to force 1 or 2 decimals in ApexCharts? On the axis I believe it is possible but not in header or labels in the chart. Would look a lot better if it was consistent.
I tried having two axis but a) I couldn’t seem to make only one axis stacked and b) I couldn’t get the two axis to have the same range.
Any ways around this?
Hey! I use this code down here to track the daily usage of my smart plug. I guess I got it right?
I have 2 questions, is there some way to change where the info “energy use today” in the header is? Can I have that info below everything?
And I would like a chart below this showing the average energy use and min/max per week and month. How would that code look like?
Thank you!
type: vertical-stack
cards:
apex_config:
chart:
stacked: true
graph_span: 14d
span:
end: day
show:
last_updated: true
header:
show: true
show_states: true
colorize_states: true
title: Energy-use today =
yaxis:
- min: 0
decimals: 3
apex_config:
tickAmount: 5
series:
- entity: sensor.smartplug_energi_dator_dag
name: Energy-use per day
type: column
color: fc7703
float_precision: 3
group_by:
func: last
duration: 1d
show:
datalabels: true
I would like to share some data_generator
that I wrote because I think it might be of interest for some of you: I wanted to have local extrema instead of just a single one. Since I use long-term statistics, with the hourly values, I decided that a local extremum was a value that was as extreme as its two neighboring hours and more extreme than the hours h±2.
The trick here is that I want to have access to the whole list of values so tranform
is not going to cut it. I thus (ab)used data_generator
- entity: sensor.temperature_exterieure
stroke_width: 0
show:
datalabels: true
legend_value: false
data_generator: |
const statistics = await hass.callWS({
type: 'history/statistics_during_period',
start_time: new Date(start).toISOString(),
end_time: new Date(end).toISOString(),
statistic_ids: [entity.entity_id],
period: "hour",
const stats = statistics[entity.entity_id];
var result = [];
var window = [];
stats.forEach( (item) => {
window.push([item, parseFloat(item.mean)]);
if (window.length < 5)
return;
if (window.length > 5)
window = window.slice(1)
var [mid, val] = window[2]
if ((val >= window[1][1] &&
val >= window[3][1] &&
val > window[0][1] &&
val > window[4][1]) ||
(val <= window[1][1] &&
val <= window[3][1] &&
val < window[0][1] &&
val < window[4][1])) {
result.push([
((new Date(mid.start).getTime()) + (new Date(mid.end).getTime()))/2,
val
return result;
The result looks like this:
The only downside is that since there are only as many values as extrema, apexcharts
detects that the different series do not have synchronized dates and thus only shows a single series in the popup. I didn’t try, but a way to mitigate that may be to produce null
values instead of outright skipping the datapoint.
Do you mind sharing your config settings for this graph?
Hi Guys,
Is it possible to have a mushroom template card (with a lightgroup) represent the colors of the light(s) in the icon?
Happy to share
header:
title: ''
show: false
show_states: true
colorize_states: false
graph_span: 24h
apex_config:
tooltip:
enabled: false
annotations:
position: back
yaxis:
- 'y': 0
strokeDashArray: 0
borderColor: '#303030'
borderWidth: 0
yaxis:
- seriesName: Grader
min: 0
forceNiceScale: true
decimalsInFloat: 0
opposite: true
labels:
style:
fontSize: 10px
fontFamily: Segoe UI Light
- seriesName: Procent
decimalsInFloat: 0
labels:
style:
fontSize: 10px
xaxis:
axisBorder:
show: false
labels:
style:
fontSize: 10px
legend:
show: false
chart:
height: 225
grid:
show: true
borderColor: '#EDEDED'
strokeDashArray: 4
position: back
dataLabels:
enabled: false
stroke:
width: 1
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0
inverseColors: false
opacityFrom: 0.3
opacityTo: 0.05
stops:
- 0
series:
- entity: sensor.mb_humidity
type: area
curve: smooth
fill_raw: last
color: b0e4ff
float_precision: 1
show:
extremas: false
group_by:
func: avg
duration: 20min
- entity: sensor.nibe_105703_40004
type: area
curve: smooth
fill_raw: last
color: fc7703
float_precision: 1
transform: return x + 1;
show:
extremas: true
- entity: sensor.nibe_105703_43084
type: column
color: orange
fill_raw: last
show:
in_chart: false
in_header: false
group_by:
func: avg
duration: 20min
style: |
ha-card {
--ha-card-background: rgba(0, 0, 0, 0);
box-shadow: none;
margin: 10px -10px 20px 5px;
font-size: 15px;
font-family: 'Segoe UI Light";
text-align: center
div#header__title {
font-size: 20px;
font-weight: 300;
font-color: #ff0000
header:
title: ''
show: true
show_states: true
graph_span: 12h
apex_config:
tooltip:
enabled: false
annotations:
position: back
yaxis:
- 'y': 10
strokeDashArray: 5
borderColor: '#f7a6af'
borderWidth: 1
xaxis:
axisBorder:
show: false
labels:
style:
fontSize: 10px
chart:
height: 175
grid:
show: false
borderColor: '#404040'
strokeDashArray: 10
position: back
legend:
show: false
dataLabels:
enabled: false
stroke:
width: 1
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0
opacityFrom: 0.4
opacityTo: 0
stops:
- 0
yaxis:
- min: 0
max: ~10
apex_config:
decimalsInFloat: 0
labels:
style:
fontSize: 10px
series:
- entity: sensor.mb_wind_speed
type: area
color: 3ca358
float_precision: 0
fill_raw: last
- entity: sensor.mb_wind_speed_max
type: area
curve: smooth
color: fc7703
fill_raw: last
show:
extremas: true
style: |
ha-card {
box-shadow: none;
margin: 28px 0px 38px 8px;
font-size: 15px;
text-align: center
div#header__title {
font-size: 20px;
font-weight: 300;
font-color: #ff0000
Hi all,
I currently have the following to show my car’s battery and range:
Is there a way to show the range within the dial, instead of the EV battery value?
So I want to use the battery percentage to fill the dial, but show the range value as text within the dial instead of on top in the header.
Below is my code:
style: |
ha-card {
border: 0px solid green;
background-color: var(--dwains-theme-primary);
box-shadow: none;
font-size: 15px;
color: rgb(148,148,148);
height: 400px;
apex_config:
chart:
height: 355px
plotOptions:
radialBar:
startAngle: -135
endAngle: 135
hollow:
margin: 0
background: '#fff'
image: undefined
imageOffsetX: 0
imageOffsetY: 0
position: front
dropShadow:
enabled: true
top: 3
left: 0
blur: 4
opacity: 0.24
track:
background: '#fff'
strokeWidth: 67%
margin: 0, // margin is in pixels
dropShadow:
enabled: true
top: '-3,'
left: 0,
blur: 4,
opacity: 0.35
legend:
show: false
fill:
type: gradient
gradient:
shade: dark
type: horizontal
shadeIntensity: 0.5
gradientToColors: '#ABE5A1'
opacityFrom: 1
opacityTo: 1
stops:
- 0
- 100
stroke:
dashArray: 4
lineCap: flat
header:
show: true
title: Hyundai Ioniq 5
show_states: true
series:
- entity: sensor.ioniq_5_ev_battery
show:
in_chart: true
in_header: false
datalabels: false
- entity: sensor.ioniq_5_range_by_ev
show:
in_chart: false
in_header: true
datalabels: false
I have created a chart with the greenly component, there are a few examples and mine looks like this right now:
Two questions:
header:
show: true
show_states: true
apex_config:
legend:
show: false
chart:
height: 120px
extremas: true
update_interval: 30min
graph_span: 24h
now:
show: true
span:
start: day
series:
- entity: sensor.greenely_prices
type: area
stroke_width: 5
color: '#03c03c'
float_precision: 3
show:
datalabels: false
data_generator: |
// REMOVE ME
return entity.attributes.current_day.map((entry) => {
return [new Date(entry.date + 'T' + entry.time), entry.price];
My data looks like this for the sensor:
- date: '2022-08-05'
time: '00:00'
price: 0.0212
time: '01:00'
price: 0.019
time: '02:00'
price: 0.0203
time: '03:00'
price: 0.0256
time: '04:00'
price: 0.0298
time: '05:00'
price: 0.04
time: '06:00'
price: 0.0643
time: '07:00'
price: 0.149
time: '08:00'
price: 0.2307
time: '09:00'
price: 0.454
time: '10:00'
price: 0.6473
time: '11:00'
price: 0.4537
time: '12:00'
price: 0.3166
time: '13:00'
price: 0.3291
time: '14:00'
price: 0.5096
time: '15:00'
price: 0.324
time: '16:00'
price: 0.3623
time: '17:00'
price: 0.4537
time: '18:00'
price: 0.3403
time: '19:00'
price: 0.2722
time: '20:00'
price: 0.199
time: '21:00'
price: 0.14
time: '22:00'
price: 0.1048
time: '23:00'
price: 0.0644
Thanks for any suggestions!
I don’t suppose someone could give me a hand getting a power usage donut working?
I have a good chuck working easily enough but now I’m trying to achieve the following…
I don’t have every device monitored in my house so Ideally I need the donut to represent everything as a fraction of the current total home power usage. So if my total usage is currently 2 kwatts and my fridge is 150w I’d like the fridge to be shown as (150/2000) percent so actually just 7.5% of the donut.
I suspect I need to calculate some kind of “Other” amount which is everything that does not have a power meter on it to report it’s usage.
And ideally any device using 0w should not show in the legend at the bottom.
I tried “showForZeroSeries: false” but maybe it’s not supported cause my entire chart vanishes?
chart_type: donut
update_interval: 15s
header:
show: true
title: Power Usage
show_states: true
series:
- entity: sensor.electricity_usage
show:
in_chart: false
in_header: true
- entity: sensor.athom_plug_v2_01_energy_power
show:
in_header: false
- entity: sensor.athom_plug_v2_02_energy_power
show:
in_header: false
- entity: sensor.athom_plug_v2_03_energy_power
show:
in_header: false
- entity: sensor.athom_plug_v2_04_energy_power
show:
in_header: false
- entity: sensor.athom_plug_v2_05_energy_power
show:
in_header: false
- entity: sensor.athom_plug_v2_06_energy_power
show:
in_header: false
I try to align the xaxis ticks with the values. How is this possible?
And how can I start the diagram more to the left, at the yaxis instead of in the middle of the chart?
(Now is only there for reference, to make clear it is a forecast. I dont need that in the final version)
This is the config for this card:
graph_span: 6d
span:
start: hour
offset: '-0h'
apex_config:
xaxis:
labels:
format: ddd
tooltip:
x:
format: ddd dd. MMM.
now:
show: true
label: now
yaxis:
- id: temp
min: ~0
max: ~30
decimals: 0
series:
- entity: weather.home
yaxis_id: temp
unit: °C
type: line
color: red
data_generator: |
return entity.attributes.forecast.map((entry) =>
var date = new Date(entry.datetime);
return [date, entry.temperature];
yaxis_id: mm
unit: mm
type: column
color: blue
data_generator: |
return [date, entry.precipitation];
show:
datalabels: true
