I did some more adjustments.
It seems that the unit of measurement cannot be pulled into tooltip.custom
Changes:
- Unit of measurement is now hardcoded
- Data series names and corresponding values are aligned in a table (names with left alignment and values with right alignment)
Now it looks as follows:
Here’s some code-p*rn (as this workaround is slightly pervert):
type: custom:apexcharts-card
graph_span: 1d
span:
end: day
all_series_config:
fill_raw: last
extend_to: false
show:
legend_value: false
header:
show: false
apex_config:
stroke:
show: true
width: 1
dashArray:
- 2
- 0
dataLabels:
enabled: true
chart:
height: 560px
legend:
showForZeroSeries: true
tooltip:
enabled: true
custom: |
EVAL:function({ series, seriesIndex, dataPointIndex, w }) {
const hoverXaxis = w.globals.seriesX[seriesIndex][dataPointIndex];
const seriesX = w.globals.seriesX.map(seriesX => seriesX.findIndex(x => x >= hoverXaxis));
function formatNumber(value) {
value = Number(value);
if (isNaN(value)) return 'n/a';
const [integerPart, decimalPart] = value.toFixed(1).split('.');
return integerPart.replace(/\B(?=(\d{3})+(?!\d))/g, '.') + ',' + decimalPart;
const formattedDate = new Date(hoverXaxis).toLocaleDateString('en-GB', {
day: '2-digit',
month: 'short',
year: 'numeric'
const formattedTime = new Date(hoverXaxis).toLocaleTimeString('en-GB', {
hour: '2-digit',
minute: '2-digit'
const hoverList = `<table style="width: 100%; border-collapse: collapse; font-family: Helvetica, Arial, sans-serif; font-size: 12px;">
${w.globals.seriesNames.map((seriesName, i) => {
const data = series[i];
const index = seriesX[i];
const value = (index >= 0 && index < data.length && w.globals.seriesX[i][index] >= hoverXaxis)
? formatNumber(data[index]) + ' W'
: 'n/a';
return `<tr>
<td style="padding: 2px 5px; text-align: left; vertical-align: middle; max-width: 50%; overflow: hidden; text-overflow: ellipsis; white-space: nowrap;">
<span class="apexcharts-tooltip-marker" style="background-color: ${w.globals.markers.colors[i]}; width: 8px; height: 8px; display: inline-block; border-radius: 50%; margin-right: 5px;"></span>
${seriesName}:
</td>
<td style="padding: 2px 5px; text-align: right; vertical-align: middle; max-width: 50%; overflow: hidden; text-overflow: ellipsis; white-space: nowrap;">
<strong>${value}</strong>
</td>
</tr>`;
}).join('')}
</table>`;
return `<div class="apexcharts-tooltip-title" style="font-family: Helvetica, Arial, sans-serif; font-size: 12px; padding-bottom: 5px;">
${formattedDate}, ${formattedTime}
</div>${hoverList}`;
series:
- entity: sensor.solcast_pv_forecast_prognose_heute
data_generator: >
return entity.attributes.detailedForecast.map(entry => [new
Date(entry.period_start), entry.pv_estimate * 1000]);
color: lightgrey
group_by:
func: avg
duration: 1min
- entity: sensor.inverter_pv_leistung
type: area
color: '#37872D'
opacity: 0.2
group_by:
func: avg
duration: 1min
- entity: sensor.inverter_eingangsleistung_verlustkorrigiert
color: '#73BF69'
name: PV-Eingangsleistung (verlustkorr.)
group_by:
func: avg
duration: 1min
- entity: sensor.hausverbrauchsleistung
type: area
color: '#B877D9'
opacity: 0.2
group_by:
func: avg
duration: 1min
- entity: sensor.power_meter_netzbezug
type: area
color: '#F2495C'
opacity: 0.2
group_by:
func: avg
duration: 1min
- entity: sensor.battery_lade_entladeleistung_verlustkorrigiert
type: area
color: '#5794F2'
opacity: 0.2
name: Akku Ladung/Entladung
group_by:
func: avg
duration: 1min
- entity: sensor.power_meter_netzeinspeisung
type: area
invert: true
color: '#FF9830'
opacity: 0.2
group_by:
func: avg
duration: 1min
view_layout:
grid-area: pvchart
card_mod:
style: |
ha-card {
height: 572px !important;
