ApexCharts card - A highly customizable graph card
In reference to Frank question there :
https://community.home-assistant.io/t/apexcharts-card-a-highly-customizable-graph-card/272877/296?u=formicro
  - type: 'custom:apexcharts-card'
    graph_span: 24h
    cache: true
    span:
      start: day
    chart_type: donut
    apex_config:
      plotOptions:
        pie:
          donut:
            total:
              show: true
              showAlways: true
              formatter: null
Is it possible to display a sensor value, right in the center of a donut ?
Thanks for suggestions, regards, Thomas.
Now, i have 2 elements with current value: legend and header. Header looks better, but him not have function hide series. I try hide header and up legend, but him looks bad. How i may add click function to header or make a legend view like header
The line can be removed by setting stroke_width=0
For example for a binary sensor:
  - entity: binary_sensor.night
    curve: stepline
    opacity: 0.2
    stroke_width: 0
    show:
      in_header: false
    transform: 'return x === ''on'' ? 1 : 0;'
Is there a mechanism to create an axis annotation at a timestamp contained in a sensor? From what I’ve read above Jinja templates are not supported.
In my case X axis annotations for sunrise and sunset, eg:
apex_config:
  annotations:
    xaxis:
      - x: states.sensor.sunrise
        label:
          text: Sunrise
You can use config-template-card to build that for now :blush:
Thanks for the hint. Works great…
Card config
type: 'custom:config-template-card'
entities:
  - sensor.sunrise
  - sensor.sunset
  - sensor.zappi_generation
  - sensor.harvi
card:
  header:
    show: true
    show_states: true
    colorize_states: true
    title: Solar generation
  span:
    start: day
  graph_span: 24h
  all_series_config:
    stroke_width: 2
    type: area
    extend_to_end: false
    float_precision: 0
  color_list:
    - yellow
    - yellow
    - green
    - grey
  series:
    - entity: sensor.zappi_generation
      name: Solar on house
      group_by:
        func: avg
        duration: 20min
      offset: '-24h'
      type: line
      opacity: 0.2
      group_by:
        func: avg
        duration: 20min
      show:
        in_header: false
    - entity: sensor.harvi
      name: Solar on shed
      group_by:
        func: avg
        duration: 20min
  y_axis_precision: 0
  apex_config:
    annotations:
      xaxis:
        - x: '${new Date(states[''sensor.sunrise''].state).getTime()}'
          label:
            text: ☼
            borderWidth: 0
            style:
              background: '#0000'
        - x: '${new Date(states[''sensor.sunset''].state).getTime()}'
          label:
            text: ☾
            borderWidth: 0
            style:
              background: '#0000'
    yaxis:
      - seriesName: Solar on house
        decimalsInFloat: 0
        show: false
      - seriesName: Solar on shed
        show: false
      - seriesName: Night time
        opposite: true
        show: false
    tooltip:
      x:
        format: 'ddd dd MMM - HH:mm'
    xaxis:
      tooltip:
        enabled: false
    legend:
      show: false
    grid:
      borderColor: '#7B7B7B'
    chart:
      foreColor: '#7B7B7B'
      zoom:
        type: x
        enabled: true
        autoScaleYaxis: true
      toolbar:
        show: true
        autoSelected: zoom
        tools:
          zoom: true
          zoomin: false
          zoomout: false
          pan: false
          reset: true
Love it :slight_smile:
Any ideas why the x - axis hides the dates with a column graph? …changing the graph to line type seems to kind of work, but still it is not displaying all the 7 days.
So the Y-axis is showing fractions when the only possible result is a whole number… can I make it only show whole numbers (seconds here)? Only just happened…
@markcocker That looks great. Can you show me how you made sensor.sunrise and sensor.sunset?
I tried it with the sun.sun atrributes directly but that’s not working.
Yeah using 1.9.0.dev1 it looks good again :slight_smile:
thank you!
However my history is gone from february i think, will look into it
Hi all. I’m lost with y-axis configuration.
I’d like to have Temperature IN (blue) and Temperature OUT (red) on the same y-axis, but sun.elevation (gray) and sun.sun (area) obviously not.
I don’t know why, but despite my code I have always 4 different axes:
  graph_span: 1w
  all_series_config:
    color: '#ff8c00'
    stroke_width: 2
    fill_raw: last
    show:
      in_header: true
      legend_value: false
      extremas: true
  header:
    show: true
    show_states: true
    title: Temperatura 1w
  apex_config:
    legend:
      show: false
    yaxis:
      - seriesname: IN
        title:
          text: Temperatura
        decimalsInFloat: 1
        forceNiceScale: true
      - seriesname: elevazione
        show: false
  series:
    - entity: sensor.T_IN
      color: BLUE
    - entity: sensor.T_OUT
      color: RED
    - entity: sensor.sun_elevation
      color: gray
      show:
        in_header: false
        extremas: false
      stroke_width: 1
    - entity: sun.sun
      type: area
      transform: 'return x === ''above_horizon'' ? 100 : 0;'
      curve: stepline
      show:
        in_header: false
        extremas: false
      stroke_width: 0
      opacity: 0.05
I think there is a bug, anyway, because if I change my code:
- seriesname: 'IN'
  title:
    text: Temperatura
  decimalsInFloat: 1
- seriesname: 'elevazione'
  title:
    text: elev
  #show: false
I have this result:
despite the seriesname the y-axis takes the second entity in the bottom list to create the axis itself. If I change the order of the bottom entities, also the axis changes.
Can you help me to understand if I am wrong? Is there a way to force 2 graphs on the same y-axis?
Thank you.
I solved… seriesName and I understood that I have to create a seriesName=IN also for OUT, putting in 2nd position:
yaxis:
  - seriesName: IN
    title:
      text: Temperatura
    decimalsInFloat: 1
  - seriesName: IN
    show: false
  - seriesName: elevazione
    show: false
Maybe can help someone else…
i have this code, and i would like to calculate the weekly, and daily increase of corona infections. Can someone help me out?
type: 'custom:vertical-stack-in-card'
cards:
  - type: 'custom:mini-graph-card'
    animate: true
    entities:
      - entity: sensor.netherlands_coronavirus_confirmed
        index: 0
    font_size_header: 16
    hours_to_show: 192
    points_per_hour: 0.1
    line_color: red
    icon: 'mdi:virus'
    name: COVID-19 Netherlands (1w)
    show:
      extrema: true
      icon: true
  - type: entities
    show_header_toggle: false
    entities:
        icon: 'mdi:account-switch'
      - entity: sensor.netherlands_coronavirus_recovered
        icon: 'mdi:pill'
      - entity: sensor.netherlands_coronavirus_deaths
        icon: 'mdi:skull'
@bacco007 is this still working for you (Amber Forecasting)? Mine has stopped forecasting as of yesterday. My Amber forecasting sensor appears to have not changed as I am using the data elsewhere.
@RomRider Any ideas? I have tried y_axis_precision and the float_precision in the series as well but I still get decimals in the y axis.
I’ve found its a bit flakey, reporting shorter time periods and sometimes reporting nothing - but this seems to be consistent with what the sensor is reporting, so I’m not sure what’s going on there.
tried setting decimalsInFloat to 0?
No I haven’t… will try.
OK tried in 3 places and just get a red screen in 2 and under apex_config it is either being ignored or no effect
Also tried:
yaxis:
  decimalsInFloat: 0
Under apex_charts… nothing
@DavidFW1960 here is the code that works for me to eliminate decimals:
    apex_config:
      yaxis:
        decimalsInFloat: 0
But please note that there are other functions that might prohibit this from working properly:
forceNiceScale: Boolean
If set to true , the y-axis scales are forced to generate nice looking rounded numbers even when min/max are provided. Turn this off if you manually set min/max and want it to be unchanged.
decimalsInFloat: Number
Number of fractions to display when there are floating values in y-axis.
Note : If you have defined a custom formatter function in yaxis.labels.formatter , this won’t have any effect.
