So the Y-axis is showing fractions when the only possible result is a whole number… can I make it only show whole numbers (seconds here)? Only just happened…
@markcocker That looks great. Can you show me how you made sensor.sunrise
and sensor.sunset
I tried it with the sun.sun
atrributes directly but that’s not working.
Yeah using 1.9.0.dev1 it looks good again
thank you!
However my history is gone from february i think, will look into it
Hi all. I’m lost with y-axis configuration.
I’d like to have Temperature IN (blue) and Temperature OUT (red) on the same y-axis, but sun.elevation (gray) and sun.sun (area) obviously not.
I don’t know why, but despite my code I have always 4 different axes:
- type: 'custom:apexcharts-card'
graph_span: 1w
all_series_config:
color: '#ff8c00'
stroke_width: 2
fill_raw: last
show:
in_header: true
legend_value: false
extremas: true
header:
show: true
show_states: true
title: Temperatura 1w
apex_config:
legend:
show: false
yaxis:
- seriesname: IN
title:
text: Temperatura
decimalsInFloat: 1
forceNiceScale: true
- seriesname: elevazione
show: false
series:
- entity: sensor.T_IN
color: BLUE
- entity: sensor.T_OUT
color: RED
- entity: sensor.sun_elevation
color: gray
show:
in_header: false
extremas: false
stroke_width: 1
- entity: sun.sun
type: area
transform: 'return x === ''above_horizon'' ? 100 : 0;'
curve: stepline
show:
in_header: false
extremas: false
stroke_width: 0
opacity: 0.05
I think there is a bug, anyway, because if I change my code:
- seriesname: 'IN'
title:
text: Temperatura
decimalsInFloat: 1
- seriesname: 'elevazione'
title:
text: elev
#show: false
I have this result:
despite the seriesname the y-axis takes the second entity in the bottom list to create the axis itself. If I change the order of the bottom entities, also the axis changes.
Can you help me to understand if I am wrong? Is there a way to force 2 graphs on the same y-axis?
Thank you.
I solved… seriesName and I understood that I have to create a seriesName=IN also for OUT, putting in 2nd position:
yaxis:
- seriesName: IN
title:
text: Temperatura
decimalsInFloat: 1
- seriesName: IN
show: false
- seriesName: elevazione
show: false
Maybe can help someone else…
i have this code, and i would like to calculate the weekly, and daily increase of corona infections. Can someone help me out?
type: 'custom:vertical-stack-in-card'
cards:
- type: 'custom:mini-graph-card'
animate: true
entities:
- entity: sensor.netherlands_coronavirus_confirmed
index: 0
font_size_header: 16
hours_to_show: 192
points_per_hour: 0.1
line_color: red
icon: 'mdi:virus'
name: COVID-19 Netherlands (1w)
show:
extrema: true
icon: true
- type: entities
show_header_toggle: false
entities:
icon: 'mdi:account-switch'
- entity: sensor.netherlands_coronavirus_recovered
icon: 'mdi:pill'
- entity: sensor.netherlands_coronavirus_deaths
icon: 'mdi:skull'
@bacco007 is this still working for you (Amber Forecasting)? Mine has stopped forecasting as of yesterday. My Amber forecasting sensor appears to have not changed as I am using the data elsewhere.
@RomRider Any ideas? I have tried y_axis_precision and the float_precision in the series as well but I still get decimals in the y axis.
I’ve found its a bit flakey, reporting shorter time periods and sometimes reporting nothing - but this seems to be consistent with what the sensor is reporting, so I’m not sure what’s going on there.
tried setting decimalsInFloat to 0?
No I haven’t… will try.
OK tried in 3 places and just get a red screen in 2 and under apex_config it is either being ignored or no effect
Also tried:
yaxis:
decimalsInFloat: 0
Under apex_charts… nothing
@DavidFW1960 here is the code that works for me to eliminate decimals:
apex_config:
yaxis:
decimalsInFloat: 0
But please note that there are other functions that might prohibit this from working properly:
forceNiceScale: Boolean
If set to true
, the y-axis scales are forced to generate nice looking rounded numbers even when min/max are provided. Turn this off if you manually set min/max and want it to be unchanged.
decimalsInFloat: Number
Number of fractions to display when there are floating values in y-axis.
Note : If you have defined a custom formatter function in yaxis.labels.formatter
, this won’t have any effect.
The Sun2 integration installed via HACS > Custom repository, then add GitHub - pnbruckner/ha-sun2: Home Assistant Sun2 Sensor then added the following to configuration.yaml
and restarted HA.
# Sun2
# https://github.com/pnbruckner/ha-sun2
- platform: sun2
monitored_conditions:
- sunrise
- sunset
Thanks. Can you share the state of one of these sensors? Then i can try to make a template sensor for it instead of installing the custom integration (bit of an overkill for only this graph).
Hello everybody,
how can I show the exact time of the solar pump (binary_sensor) when it goes on and off.
At the moment I only found out over certain time intervals.
However, these are not identical to the switch-on and switch-off times of the pump.
Is there a way to solve this?
I absolutely need the group_by options.
header:
title: Verhalten Solarladepumpe
show: true
show_states: true
colorize_states: true
update_interval: 10min
graph_span: 24h
span:
end: hour
apex_config:
tooltip:
enabled: true
yaxis:
- show: true
decimalsInFloat: 0
labels:
style:
colors: '#bd9b35'
fontSize: 12px
fontWeight: bold
fontFamily: null
- show: true
decimalsInFloat: 0
opposite: true
labels:
style:
colors: '#bf5e5e'
fontSize: 12px
fontWeight: bold
fontFamily: null
- show: true
decimalsInFloat: 0
opposite: true
labels:
style:
colors: '#428bca'
fontSize: 12px
fontWeight: bold
fontFamily: null
xaxis:
axisBorder:
show: false
labels:
style:
fontSize: 14px
fontFamily: null
chart:
height: auto
grid:
show: false
legend:
fontSize: 12px
fontFamily: null
height: 40
dataLabels:
enabled: false
stroke:
width: 2
curve: smooth
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.8
inverseColors: false
opacityFrom: 0.5
opacityTo: 0
stops:
- - 0
- 50
- 100
series:
- entity: luxtronik.id_web_temperatur_tss
unit: C°
show:
extremas: true
type: area
color: '#bd9b35'
fill_raw: last
float_precision: 0
group_by:
duration: 1min
func: avg
- entity: luxtronik.id_web_temperatur_tsk
unit: C°
type: area
color: '#bf5e5e'
fill_raw: last
float_precision: 0
show:
extremas: true
group_by:
duration: 1min
func: avg
- entity: binary_sensor.solar_pumpe
transform: 'return x === ''on'' ? 1 : 0;'
type: area
color: '#428bca'
fill_raw: last
float_precision: 0
show:
extremas: false
group_by:
duration: 1min
func: avg
group_by
means it groups by time interval so you can’t keep the precision because that’s exactly the goal of group_by . But you can remove group_by from just the binary_sensor. You can also use curve: stepline
to make it a staircase-like line in the binary_sensor series (which is probably what you you are trying to simulate using group_by )
I have an issue with the x-axis time. It appears to be one hour behind both my HA history graphs and my Grafana graphs. My TZ is Stockholm/Brussels and it’s working for all other parts of HA.
ApexCharts has the data for the current hour, it just displays it as one hour to early (e.g., 19:00 becomes 18:00 in the chart).
Is this a setting I’ve missed?
That should be only today because of the daylight saving time change.
