I am trying to build a graph spanning over three days but the x-axis doesnt show any number except the first/last every day. What am I doing wrong? Would have liked to have at least every three hour shown on x-axis.
hi @cvester , not sure if you question from 21 Jun 2021 was solved somehow satisfactory… did you find some solution of showing a 12 month graph?
thx. Willy
hi @fhopley , I am curious about setting the data generator to show the monthly graphs of energy production and consumption, as I can read these values from the WattRouter device with the multi-scrape integration (data from the XML source).
I saw at your graphs using also monthly values, but I guess these are always 4 weeks within the month?)
I would need just one monthly value - so the graph can maybe be fixed to categories like:
Jan, Feb, Mar, … , Dec on the X-axis, and at the Y-axis there could be the values readed from the multiscrape sensor (from the XML).
Could you plz share your code for the graph setting what you have achieved?
or - could you plz help with the code - just to show 12 months (not 12*4 values in columns?)
When I do zoom or pan I only get data for the period the graph was in in any case. In other words if it shows 24h of data and I zoom out (or pan), I still only see that original 24h of data. How did you get it to show more?
It doesn’t show more than the set time span. But the problem is that I have it set to 2h but when I zoom to e.g. 10 minutes period inside that 2h, it changes back to 2h full view right after new data appears. And it’s getting almost realtime data (power measurement) with 5 sec update rate.
I could of course change update rate to slower but I’d like to keep fast updates.
This seems to work better when I enable brush, then also zoom and pan buttons work correctly. Zoom reset doesn’t work, it just does “something”. To reset zoom I have to move brush to the end of the chart and then next chart value update resets zoom to default brush span value.
Do someone know how to only enable tooltip on specific series?
I currently have this (code) but if i hover on the two other graphs then it still shows the value
Team,
Can I use an entity value in the data_generator?
example:
Where I take the value of an entity and add that to the ‘entry.price’. The code below does not work.
