Is there a way to specify the name of the entities via a template? I have already tried many variants, but without success.
Final result! I’m really happy!
If somebody wants to replicate:
Prerequisites:
- apex.chart card (graph)
- config-template card (change hours)
- mushroom card (layout of hour picker)
- template sensor (creating the darker heating area)
Full apex chart code here:
type: vertical-stack
cards:
- type: custom:mushroom-chips-card
chips:
- type: template
double_tap_action:
action: none
icon: mdi:minus
tap_action:
action: call-service
service: counter.decrement
data: {}
entity_id: counter.grafici_temperatura_ore
hold_action:
service: counter.reset
data: {}
target: {}
- type: template
icon: mdi:chart-box-outline
content: >-
{{ states('counter.grafici_temperatura_ore') }}
{% if states('counter.grafici_temperatura_ore') | int == 1 %} ora nei
grafici
{% else %} ore nei grafici
{% endif %}
tap_action:
action: more-info
entity: counter.grafici_temperatura_ore
- type: template
icon: mdi:plus
content: ''
tap_action:
service: counter.increment
data: {}
double_tap_action:
action: none
hold_action:
data: {}
alignment: center
- type: custom:config-template-card
entities:
- counter.grafici_temperatura_ore
card:
type: custom:apexcharts-card
update_interval: 1m
graph_span: ${{states['counter.grafici_temperatura_ore'].state+'h'}}
header:
show: true
title: Temperatura bagno
show_states: true
colorize_states: false
series:
- entity: sensor.grafico_riscaldamento_bagno_sta_riscaldando
name: Sta riscaldando
stroke_width: 0
type: column
color: '#F5B041'
opacity: 0.3
show:
in_header: false
legend_value: false
group_by:
func: avg
duration: 2m
- entity: sensor.tado_riscaldamento_bagno_temperature
stroke_width: 3
type: area
color: '#f8e07d'
opacity: 0.25
unit: °C
show:
extremas: true
name_in_header: false
in_header: true
group_by:
func: avg
duration: 2m
- entity: climate.tado_riscaldamento_bagno
attribute: temperature
name: Temp desiderata
stroke_width: 1.5
type: line
color: '#CC3333'
opacity: 1
unit: °C
show:
extremas: false
in_header: false
group_by:
func: avg
duration: 2m
entities:
card:
update_interval: 1m
header:
show: true
title: Umidità bagno
show_states: true
series:
- entity: sensor.tado_riscaldamento_bagno_humidity
stroke_width: 3
type: area
color: '#7AB7FF'
opacity: 0.15
show:
extremas: true
in_header: true
How I’ve created the darker “heating area” here:
In order to achieve that result, I’ve created a new template sensor in configuration.yaml that
- when it’s heating → gives me current temperature
- when it’s not heating → is empty or null ( when it’s not heating I don’t want a 0 value, since this will interfere with y-axis min value in my chart)
So I’ve created in my configuration.yaml the following sensor:
template:
- sensor:
- name: Grafico riscaldamento soggiorno - sta riscaldando ## In English it's heating
state: "{{ states('sensor.tado_riscaldamento_bagno_temperature') | float }}" ## the value of the sensor is equal to current temperature
availability: "{{ states('sensor.tado_riscaldamento_bagno_heating') | int}}" ## when it's not heating, availability is 0, so the value of the sensor is null
Pay attention to “availability”:
- when heating is 0 → availability is false, so the value of the sensor is null
- when it’s heating (heating is not 0) → availability is true and the value of the sensor is current temperature
Finally I’ve added the template sensor to my apex chart as a third orange series.
Special thanks
Special thanks to @Kertz1954 for his precious help during the process!
Hello! Don’t share the code?
Is anyone showing (long term) statistic sensors in Apex?
It works good but for some reason, the date on the tooltip is one day behind. Below it says January 12 when it’s actually data from January 13 that is shown. The data for the last bar in the chart is also for the 13th.
Any ideas?
statistics:
type: sum
period: day
align: middle
group_by:
func: diff
duration: 1d
fill: last
start_with_last: true
First of all thanks for this amazing card. It’s absolutely fabulous.
Does anyone know how to change the decimal number notification for the y-axis label from decimal point to decimal comma (5,7 instead of 5.7)?
It’s not in your localization settings. I tried changing date formats to Danish, dit not work either. Simple fix is to remove decimals
Is it possible to cut a line?
I have a value that is only valid for three hours a day.
The red line is all the way through, I’d like it to only be displayed between 17 and 20h. I’ve tried this to no avail:
let pr =[entity.attributes.gasday,entity.attributes.gasday,entity.attributes.gasday];
console.log(pr);
return [...entity.attributes.gasday].reverse().map((entry)
const lNow = now;
console.log(entry);
now -= 30 * 60 * 1000;
return [lNow, entry];
}).reverse();
Btw thanks to Romrider, I have 10k+ views of my spot price prognosis per day, and it’s Apexchart-card that is the business end of visuals.
Henrik
Does anybody know how to use a sensor value to set a horizontal line in the chart?
This doesn’t work:
apex_config:
annotations:
yaxis:
- 'y': hass.states['sensor.mysensor'].state
Yes I solved it.
I created a sensor (in my sensors.yaml):
sensors:
medelpris_el_kr:
friendly_name: Medelpris på el idag
entity_id:
- sensor.nordpool_kwh_se3_sek_3_095_025
value_template: '{{ states.sensor.nordpool_kwh_se3_sek_3_095_025.attributes.mean }}'
Then I added this to the apexchart:
- entity: sensor.medelpris_el_kr
type: line
transform: return x * 100
group_by:
func: avg
duration: 24h
Hopefully that helps.
/Fanan
Here’s two snippets of code that will work for you. Your choice which one you choose.
yaxis:
- id: electric
decimals: 3
apex_config:
title:
text: Electric kWh
style:
fontSize: 16px
forceNiceScale: 'no'
labels:
show: true
formatter: |
EVAL:function(value) {
let text = parseFloat(value).toFixed(3);
let result = text.replace(".", ",");
return result;
style:
colors: '#ffffff'
fontSize: 14px
series:
or
apex_config:
yaxis:
show: true
labels:
show: true
formatter: |
return result;
style:
colors: '#ffffff'
fontSize: 16px
Many thanks for the support! Working great.
Thanks for your post. This is something I would like to have to! Unfortunally the code for the config.yaml doesn’t work:
template:
- sensor:
I have the 2022.1.1 version of HA. Most yaml code is written as this in my HA:
sensors:
energy_gas_en_elektriciteit_maandelijks_eur:
friendly_name: 'Totale netto maand kosten energie'
value_template: "{{ (states('sensor.gas_maandelijks_eur')|float + states('sensor.energy_import_total_maandelijks_eur')|float)|round(2) }}"
unit_of_measurement: "€"
How can I get this to work?
Hi! I’ll try to help you, if I can (even though I’m not an expert in template sensors).
I suggest you to proceed step by step
1) Check in developer tools the result of your value
{{ ( states('sensor.gas_maandelijks_eur') | float + states('sensor.energy_import_total_maandelijks_eur') | float) | round(2) }}
If you obtain the right value, go on.
2) Create a really simple template sensor in configuration.yaml
template:
- sensor:
- name: Totale netto maand kosten energie
state: "{{ ( states('sensor.gas_maandelijks_eur') | float + states('sensor.energy_import_total_maandelijks_eur') | float) | round(2) }}"
Restart home assistant and check if you see your template sensor (go to entities and search for “Totale netto maand kosten energie”)
3) Play with availability, units, etc
Then you can come back to configuration.yaml and add more complexity to your sensor (unit of measurement, availability, etc)
Maybe this approach could help you creating your template sensor. Otherwise I suggest you to search videos / post about creating a template sensor!
Are there any examples on how to modify the header?
This is with a floating header:
I would like to put the header in the middle of the card.
@Rubbervdh When you have created your template sensor, if you want to play with availability, keep in mind that:
- when availability is 0 (int) → the sensors is not available in home assistant and its value in the chart is null
- when availability is different from 0 → the sensor is available in home assistant and its value is the value you have assigned to it in configuration.yaml
So if you want that your sensor is unavailable when {{ states(‘sensor.my_sensor’) }} is 0, you should write something like this:
template:
- sensor:
availability: "{{ states('sensor.my_sensor') | int }}"
Short answer No. As per the HA Apex Chart documentation, Positioning will be supported later. Note, the HEADER is an HA option and is not part of the official Apex Chart system.
However, you could make use of the legend option within the apex_config.
Much neater and takes up less vertical space (depending on fontsize), plus an optional title if so inclined. See https://apexcharts.com/docs/options/legend/ for all options and much more.
Code snipped to get you started.
apex_config:
chart:
height: 250
legend:
show: true
showForSingleSeries: true
position: top
horizontalAlign: center
fontSize: 30px
offsetX: 0
offsetY: 0
labels:
useSeriesColors: true
onItemClick:
toggleDataSeries: false
onItemHover:
highlightDataSeries: false
Thanks for the response. I see that you’re way of writing in the config.yaml is different from mine. I have my sensors this way:
- platform: systemmonitor
resources:
- type: processor_use
- type: processor_temperature
- type: memory_free
- type: disk_use_percent
arg: /
- type: disk_use
- type: disk_free
- type: throughput_network_in
arg: enp0s3
- type: throughput_network_out
arg: enp0s3
# Temperatur-Attribut Buitentemp volgens HA zelf
sensors:
norwegian_temperature:
friendly_name: "met.no Tempratuur Buiten"
unit_of_measurement: '°C'
value_template: "{{ state_attr('weather.huis', 'temperature') }}"
# Temperatur-Attribut Windkracht volgens HA zelf
sensors:
friendly_name: "met.no Windkracht Buiten"
unit_of_measurement: 'km/h'
value_template: "{{ state_attr('weather.huis', 'wind_speed') }}"
#WK gemiddelde beide sensors
- platform: min_max
type: mean
entity_ids:
- sensor.sonoff_woonkamer_sensor_temperature
- sensor.woonkamer_temperature
#WK gemiddelde beide sensors 24h
- platform: statistics
name: WK avg Sonoff en Xiaomi 24h
entity_id: sensor.avg_wk_xiaomi_sonoff
state_characteristic: mean
max_age:
hours: 24
# Gemiddelde WK temp Sonoff 24h
name: WK Sonoff avg 24h
entity_id: sensor.sonoff_woonkamer_sensor_temperature
max_age:
hours: 24
# Gemiddelde WK temp Xiaomi 24h
name: WK Xiaomi avg 24h
entity_id: sensor.woonkamer_temperature
max_age:
hours: 24
#Buiten gemiddelde beide sensors zonder tijd
- platform: min_max
type: mean
entity_ids:
- sensor.sonoff_buiten_sensor_temperature
- sensor.sonoff_buiten_sensor_2_temperature
#Buiten gemiddelde beide sensors 24h
name: BU avg Sonoff hok en huis 24h
entity_id: sensor.avg_bu_sonoff_sonoff2
max_age:
hours: 24
# Gemiddelde Buiten temp Sonoff naast huis 24h
name: BU Sonoff naast huis avg 24h
entity_id: sensor.sonoff_buiten_sensor_2_temperature
max_age:
hours: 24
So in short: I start with the tag Sensor:
And under that tag i define my sensors and their platform, like template.
I see that you start with Template. Is that te platform or is that a different way of writing? I am getting errors when I trie it that way
Sorry, on the phone here, but if you look at the template documentation, your way is now considered “legacy”, meaning that it’s still supported, but the new way with template on the top level is the recommended way going forward.
“Legacy binary sensor configuration format
This format still works but is no longer recommended. Use modern configuration.”
I actually just discovered this myself and I would recommend reading the documentation and related discussion well before converting to the new one.
E.g. friendly name is now not longer needed. It now takes advantage of unique_id instead.
