shall I publish again in MQTT ? as now I get unknown instead of the value
and yes this is a newbee here…
Currently i’ve this chart, but i want to add two horizontal lines one with a entity value (average price) and a static value 40.0 in this case.
Can someone give me a clue, with the default documentation i can’t my head around this.
type: custom:apexcharts-card
graph_span: 24h
hours_12: false
header:
title: cent/kWh uurtarief vandaag
show: true
span:
start: day
now:
show: true
color: grey
label: Nu
series:
- entity: sensor.nordpool
type: column
data_generator: |
return entity.attributes.raw_today.map((start, index) => {
return [new Date(start["start"]).getTime(), entity.attributes.raw_today[index]["value"]];
Hi all, I thought I’d share the code and image for a Monthly Stacked example that hopefully will answer some recently asked questions. There are some reported known issues when using this method, so checkout the HA Apex Chart github issues page if your question has not been answered by my posting. github link
type: vertical-stack
cards:
- type: custom:config-template-card
entities:
- sensor.month
- sensor.year
card:
graph_span: 1month
cache: true
span:
start: month
offset: +1day
show:
last_updated: false
loading: false
header:
show: false
standard_format: true
floating: false
show_states: false
yaxis:
- id: stroom&gas
show: true
min: 0
max: 5
decimals: 2
apex_config:
forceNiceScale: 'yes'
labels:
show: true
formatter: |
EVAL:function(value) {
let text = parseFloat(value).toFixed(2);
let result = "€" +text.replace(".", ",");
return result;
style:
colors: '#ffffff'
fontSize: 14px
offsetX: 0
offsetY: 0
axisBorder:
show: false
color: '#78909C'
title:
text: Inclusive of all admin. costs & taxes
rotate: -90
offsetX: 0
offsetY: 0
style:
fontSize: 14px
series:
- entity: sensor.daily_gas_consumption_costs
float_precision: 2
type: column
yaxis_id: stroom&gas
statistics:
type: state
period: day
align: middle
fill_raw: zero
group_by:
fill: zero
duration: 1d
start_with_last: false
func: last
color: orange
unit: ' '
show:
legend_value: false
in_header: true
name_in_header: true
header_color_threshold: true
in_chart: true
datalabels: true
hidden_by_default: false
extremas: false
- entity: sensor.daily_electric_consumption_costs
float_precision: 2
type: column
statistics:
type: state
period: day
align: middle
fill_raw: zero
group_by:
fill: zero
duration: 1d
func: last
color: green
unit: ' '
show:
legend_value: false
in_header: true
in_chart: true
datalabels: true
extremas: false
apex_config:
chart:
height: 500
type: bar
stacked: true
plotOptions:
bar:
borderRadius: 5
dataLabels:
position: top
dataLabels:
enabled: true
offsetX: 0
offsetY: 0
style:
fontSize: 14px
colors:
- '#ffffff'
zoom:
enabled: false
toolbar:
show: true
tools:
download: true
zoom: true
zoomin: false
zoomout: false
pan: false
reset: true
tooltip:
enabled: false
shared: false
theme: light
style:
fontSize: 14px
onDatasetHover:
highlightDataSeries: false
x:
show: true
format: ddd dd MMM yyyy
marker:
show: false
fixed:
enabled: true
position: topRight
offsetX: -10
offsetY: 0
grid:
show: true
strokeDashArray: '0'
borderColor: '#666666'
xaxis:
lines:
show: false
yaxis:
lines:
show: true
xaxis:
labels:
show: true
rotate: 0
rotateAlways: true
style:
colors: '#ffffff'
fontSize: 14px
offsetX: 0
offsetY: 0
format: dd
position: bottom
showDuplicates: false
axisBorder:
show: true
color: yellow
height: 1
width: 100%
offsetX: 0
offsetY: 5
axisTicks:
show: true
color: yellow
height: 6
offsetX: 0
offsetY: 0
title:
text: >-
${{'Stacked Apex Chart Example - Daily Gas & Stroom costs for ' +
states['sensor.month'].state + ', ' + states['sensor.year'].state
+ ' (LTS)'}}
offsetX: 0
offsetY: 0
floating: true
style:
fontSize: 20px
color: '#fff000'
legend:
show: true
showForSingleSeries: true
position: top
horizontalAlign: center
fontSize: 25px
offsetX: 0
offsetY: 0
labels:
useSeriesColors: true
onItemClick:
toggleDataSeries: true
onItemHover:
card_mod:
style: |
ha-card {
background-color: transparent;
box-shadow: 0px 0px;
border: 1px solid yellow;
border-radius: 20px 20px 20px 20px;
width: 99.4% !important;
background-image: url("/local/images/windmill-sunset-3.jpg");
background-size: 100% 500px;
See my latest post that is using a monthly stacked method.
See my latest post that is using a monthly stacked method with datalabels.
Please help. How come the one graph plot is not even showing on the chart?
Do I need to set a min/max?
Which one isn’t showing? Looks like your pool temp is only updating occasionally so there are gaps in the data.
Yea im not sure whats up with that, but its also almost below the minimum of the graph?
The default graph in HA displayed it just fine.
Confirm you are using chart_type
line
and not scatter
And yes if you want to have more of a gap at the bottom you will have to use min but beware that is then fixed and may not be want you always want.
Yes, you should publish in MQTT
I’m trying to get this graph into a week format. Can someone help me with this?
graph_span: 7d
update_interval: 5m
cache: true
span:
end: day
offset: '-1sec'
header:
show: true
title: Normaal en dal per dag
apex_config:
xaxis:
labels:
format: dd-MM
show: true
showAlways: true
yaxis:
forceNiceScale: false
decimalsInFloat: 0
min: 0
chart:
type: area
height: 300
stroke:
show: true
width: 1
legend:
show: true
dataLabels:
enabled: false
distributed: true
fill:
type: gradient
gradient:
shadeIntensity: 0.1
opacityFrom: 0.25
opacityTo: 1
inverseColors: true
stops:
- 0
- 90
- 100
series:
- entity: sensor.stroom_import_dal_dagelijks
type: column
float_precision: 2
group_by:
func: max
duration: 23h59m59s
- entity: sensor.stroom_import_normaal_dagelijks (This is daily, i can change these to monthly or weekly)
type: column
float_precision: 2
group_by:
func: max
duration: 23h59m59s
If you mean me? Thats not working for me since “statistics: type state” is not available for my sensor only max, min, mean.
Also, the core issue is described here…and I left a message:
There is a bug report in Apex-Chart Git which also mentioned some similar problem with diff … not sure if Apex-Chart problem or core statistics.
Anyhow, I still need help how to remove the wrong statistics value at 0:00 containing not 0 but the last value of the last day. How can I remove this wrong value from sensor statistics?
Thanks!
Yes, definitely line.
chart_type: line
header:
show: true
show_states: true
colorize_states: true
series:
- entity: sensor.pooltemperature
- entity: sensor.serverroomtemp
Is there any way to group points by timestamp into days without reducing the number of points? Essentially I have multiple events occurring on the same day, but on my chart I’d like to show them all in line over the x-axis label for that day. Currently, they are offset from the label depending on the time these events occurred. In the graph below, both of the dots represent events that occurred on Jan. 21, but as you can see they are shifted left from the Jan 21 label depending on the time of day they were recorded:
If possible, I’d like to stack them vertically directly above each other and above the Jan 21 label.
Current config:
chart_type: scatter
graph_span: 1 week
apex_config:
dataLabels:
enabled: true
yaxis:
min: 0
max: 1440
tickAmount: 6
labels:
formatter: |
var suffix = '';
var hour = Math.floor(value / 60);
if (hour == 0) {
return '';
if (hour > 12) {
suffix = 'PM';
hour -= 12;
} else {
suffix = 'AM';
return hour + suffix;
header:
show: true
title: Poop Chart
series:
- entity: button.poop_button
color: '#704000'
group_by:
func: raw
duration: 1d
transform: |
var time = new Date(x);
return time.getHours() * 60 + time.getMinutes();
I’ve one question how can i add a value of a sensor to the yaxis?
Hi, did not know this (admitting to not have read all options)
Question with that… I would like to color the label depending on another value
e.g. I have ‘pairs’ with value and boolean in my sensor
value:
- 1
- 2
value_b
- true
- false
Can one use an EVAL to change the style (color) of the label based on the boolean?
Unfortunately there is no formatter option available for label colors. You can change the colors to some extent. I have used 3 in this example.
yaxis:
- id: °c
decimals: 3
apex_config:
title:
text: Temperatures °c
style:
fontSize: 16px
forceNiceScale: true
labels:
show: true
formatter: |
let text = parseFloat(value).toFixed(0);
let result = text.replace(".", ",");
return result;
style:
colors:
- '#FFFF00'
- '#ffffff'
- '#0000FF'
fontSize: 14px
series:
To use external and variable values in the Apexcharts card you must first install the HACS - Frontend “Config Template Card” card.
Use the example below my screenshot to make it the way you wish.
cards:
entities: sensor.nordpool
variables:
average: states['sensor.nordpool'].attributes.average
card:
graph_span: 24h
hours_12: false
header:
show: true
span:
start: day
now:
show: true
color: grey
label: Nu
apex_config:
annotations:
yaxis:
- y: ${average}
y2: 40
strokeDashArray: 5
borderColor: var(--primary-color)
opacity: 0.5
label:
text: ${average}
series:
type: column
data_generator: |
I ended up to program my own data_generator to correctly sum-up long term statistics. Would be great if HA core team or apex-chart team fixes the problem.
thanks here for inspiration
For anyone who may need this…here my code:
chart_type: donut
graph_span: 30d
update_interval: 1h
series:
- entity: sensor.daily_energy_consumption
show:
datalabels: percent
data_generator: |
var statistics = await hass.callWS({
type: 'recorder/statistics_during_period',
start_time: new Date(start).toISOString(),
end_time: new Date(end).toISOString(),
statistic_ids: [entity.entity_id],
period: "hour",
var stats = statistics[entity.entity_id];
var result = [];
var len = stats.length;
var hour, day;
var tzoffset = new Date().getTimezoneOffset()*1000*60;
var timeoffset = tzoffset - 1000*60; //timezone -1min
var sum = 0;
for (let i = 0; i < len; i++) {
hour = new Date(stats[i].start).getHours();
day = new Date(stats[i].start).getDate();
if(parseFloat(hour) == 0){ //add last value to result
sum += stats[i].max;
if(hour !=0){ //add last reading of current day but avoid double
sum += stats[len-1].max;
result.push([(new Date(stats[len-1].end).getTime()),sum]);
return result;
