Don’t use stroke_width on column, if you read further up on the linked topic, i shared my code, where you’ll find where and howto use % as width for columns ( edit: “Bars” ) … so they get “centered”
With a column ? Read the documentation.
Thanks. If these charts can’t plot just two days of data without taking over my HA then they are no good to me. Thought they might have been a better alternative to Grafana on a dashboard.
??? , i have never answered you in any regards, so i really have no idea of why you reply to me ?
EDIT: Beside, if i would have answered you in your request for help/assistance, i would have told you to … 1. show what’s wrong 2. explain “bog down” . 3 INVESTIGATE, bog down , because you most likely have some underlying issues, with 1 of, or both your “suspec_named_sensors”, which might give you a hint, to solve your “bog down” experience
For some reason this doesn’t work for me. Any idea why?
data_generator: |
return entity.attributes.raw_today.map((entry) => {
const nu = new Date()
const series_entry = new Date(entry.start)
if(nu.getHours() == series_entry.getHours())
{return [series_entry, entry.value + hass.states['sensor.elpris_paslag'].state]}
return [series_entry, 0];
- sensor:
- name: "elpris_paslag"
state: >
{% set paslag = 0.82225|float %}
{{ paslag }}
I don’t get an error but the hass.states['sensor.my_sensor'].state
simply seem to return 0.
I didn’t, I responded to OzGav. Don’t know why it appears as responding to you.
But thanks anyway!
I can’t because the chart makes the HA system and browser slows down so much I can’t do anything with it. It takes minutes for one mouse click to respond.
The entire HA interface slows down to a near stop as a result of just adding this one chart, system resources are overwhelmed to the point that Home Assistant dashboard crashes. I had to be very careful and patient, eventually was able to delete the manual card with this chart. Once it was deleted my HA is back to its normal zippy self.
Not sure what to look for or to know what is wrong. The sensors display their data just fine in regular HA dashboards. I can view their history tab quickly and easily, and if i choose a regular inbuilt card they show data just fine, e.g. these are the two sensors I was using, they show here in a jiffy and no system issues:
Yeah I’m not sure if that is the issue just suggested to try it and see if that helps. If it does then you can continue down on the track to work out why
Does hass.states['sensor.elpris_paslag'].state]
return text and needs converting to a number?
Maybe, the template sensor code is in my post above and there I (think I) convert it to a float.
Edit:
Working now, me being stupid as always
Thanks. I think I need to set up a test environment for this, or take a snapshot of my HA VM before trying again. I’m not going to risk putting any Apex Chart in my regular dashboard again. It’s that bad.
Try with first remove 1 of the sensors from this apex-card
ie.
- remove solarnet-power-photo
- remove
as this seems in conflict with the 8000W that seems to be registered in your native history card
if you still have problems after removing these 2, i would look into / monitoring your system and network resources, as im not familiar with what system you have your HA on, nor which device you trying to view your Graphs from, i can’t say much, but your “bog down” seems related to power/resource whether it’s cpu/ram or network , should be fairly easy to figure out
Lets say your solar_power_prod_sensor , spewing 8000W ( to your limited to 3000 graph ) AND at the same time does this in a constant flow with 1 seconds interval … i mean the graph your showing aint showing a nice thin line, the blue line is very irregular , same goes for the pink for that matter, so there is heavy activity, i don’t know where this info gets trans-coded, or whether it’s raw … and i don’t see any “group_by” in your card … so i think you basically trowing in a homogeneous amount of information, which the card obviously have hard to deal with
Not to mention: … i assume you are aware that the “graphs” you are trying to “create” is COLUMNS , not lines, now that would look interesting in a detailed scale, considering the amount of “points” ( which are not group-ed) , how often does this(these) sensors “update” … spewing out tons of info in “buckets” or ? , small, large buckets ? , does each “bucket” crave a column ?..
PS: sorry for my way of writing, but before you criticize and spew your negative opinions, be sure you know what you are doing
I am sure this “transform” also is a large “bog down” source, you basically let your HA frontend do the math , of a solar-power-production sensor
nobody find?
Hi. I think i found your post, and by setting the width to 200000% made it look ok. But i have another chart too, showing tomorrows price when it’s available, and that one reacts completely different. adding a wider space before the last column and not making them the same size as the other chart
type: custom:apexcharts-card
header:
title: ' '
show: true
show_states: true
colorize_states: true
graph_span: 10d
span:
start: day
offset: '-9d'
apex_config:
legend:
show: false
plotOptions:
bar:
columnWidth: 200000%
dataLabels:
enabled: false
series:
- entity: sensor.elpris_idag
type: column
color: '#03a9f4'
group_by:
func: max
duration: 1day
extend_to: false
#stroke_width: 12
- entity: sensor.snittpris_denna_manad
type: line
stroke_width: 5
fill_raw: last
curve: smooth
color: lightblue
VS
header:
title: ' '
show: true
show_states: true
graph_span: 10d
span:
start: day
offset: '-8d'
apex_config:
legend:
show: false
plotOptions:
bar:
dataLabels:
enabled: false
series:
type: column
color: '#03a9f4'
group_by:
func: max
duration: 1day
extend_to: false
#stroke_width: 12
- entity: sensor.elpris_imorgon
type: column
color: blue
group_by:
func: last
duration: 1day
extend_to: false
#stroke_width: 12
data_generator: |
return [[new Date(entity.attributes.datum).getTime(), entity.state]]
type: line
stroke_width: 5
fill_raw: last
curve: smooth
color: lightblue
VS ???, i have no idea what you are “dealing” with … and it’s definitive first time in any category i’ve heard of 200.000%
seriously you are on your own, don’t refer to me
PS: i tried to copy/paste your “code” to a view/card here, it absolutely dont work !, NOT even if i remove everthing from VS and donw, so i only should have the first graph, wrong intends !!! , sorry can’t help you on this as it’s not “obvious” what you are doing here
PS: somewhere in your code you have a wrong intend, i can’t find it, thou i can make a similar card, with same sensor, AND without 200000%, as this number is obvious wrong
- Whats does this sensor provide ?
sensor.elpris_idag
Is it current pries ( 1 , entry at a given time , during the day ?), or is it ALL prises during “today” ? (i.e like a forecast)
Same goes for
sounds pretty much like a “forecast”
for these , as i assume is ALL prises during the day / or during tomorrow , it makes no sense in making a graph using “group by max” and then “duration” day
for those 2 sensors, which expose several values, during the day/tomorrow, most likely 1 for each hour, and you can make a graph for that “using raw” ALL data points, im pretty sure neither here in SE, nor DK or NO, have 1 single “elpris_idag”, , so this/these sensors provide you with several , prices, and you can’t uses a card to summarize this, and giving it any sense
I wasn’t looking, but I did see a posted solution for this problem in this year !!
Hi @Kertz1954, please excuse my delay. I have 6 plots and 4 additional values in the header ut not in the chart. I defined three yaxis and referenced them via id. If i hide the first entity of my series with yaxis-id= energy_axis_day the complete yaxis disapperas, otherwise there are 4 other entities with the same yaxis left.
header:
show: true
title: PV-Leistungsübersicht (heute)
show_states: true
update_interval: 1m
graph_span: 24h
show:
last_updated: true
apex_config:
chart:
height: 300%
span:
start: day
offset: '-0d'
yaxis:
- id: percent
min: 0
max: 100
decimals: 0
apex_config:
tickAmount: 5
- id: energy_axis_day
decimals: 0
min: 0
max: ~10000
opposite: true
align_to: 1000
apex_config:
tickAmount: 5
- id: none
show: false
now:
show: true
color: red
series:
- entity: sensor.e3dc_battery_soc
yaxis_id: percent
type: area
opacity: 0.3
color: rgb(209, 226, 175)
stroke_width: 2
group_by:
func: last
duration: 30m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.e3dc_power_consumption
yaxis_id: energy_axis_day
type: line
color: rgb(204, 51, 51)
stroke_width: 2
extend_to: false
group_by:
func: last
duration: 12m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.e3dc_grid_power_in
type: line
color: rgb(0, 102, 128)
stroke_width: 2
extend_to: false
group_by:
func: last
duration: 12m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.e3dc_wallbox_power
type: line
color: grey
stroke_width: 2
extend_to: false
group_by:
func: last
duration: 12m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.e3dc_grid_power_out
type: line
color: rgb(0, 164, 206)
stroke_width: 2
extend_to: false
group_by:
func: last
duration: 12m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.solar_power_overall
type: line
color: rgb(255, 194, 56)
stroke_width: 2
group_by:
func: last
duration: 12m
show:
in_header: false
in_chart: true
extremas: false
- entity: sensor.total_energy_yield_day
yaxis_id: none
group_by:
func: last
duration: 12m
show:
in_header: true
in_chart: false
extremas: false
- entity: sensor.netzbezug_tag
yaxis_id: none
group_by:
func: last
duration: 12m
show:
in_header: true
in_chart: false
extremas: false
- entity: sensor.netzeinspeisung_tag
yaxis_id: none
group_by:
func: last
duration: 12m
show:
in_header: true
in_chart: false
extremas: false
- entity: sensor.hausverbrauch_tag
yaxis_id: none
stroke_width: 2
group_by:
func: last
duration: 12m
show:
in_header: true
in_chart: false
extremas: false
If you have any idea please give me a hint.
Best regards,
Chrclaus
Hi there, yet another question: I want to groupBy data on a monthly basis. As i noticed
group_by:
duration: 4w
does not work for months. Does anybody has a workaround for example on a weekly-basis like i did to keep the monthly-interval?
apex_config:
chart:
stacked: true
update_interval: 1d
graph_span: 4w
span:
end: month
show:
last_updated: true
header:
show: true
title: Energie-Übersicht (Monat)
show_states: true
series:
- entity: sensor.energy_e3dc_wallbox
type: column
color: grey
group_by:
func: delta
duration: 4w
fill: zero
- entity: [...continiuos...]
Best regards,
Chrclaus
the VS was a way to show it is two separate charts. I have them in conditional cards in a vertical stack card, maybe thats why the intendention is wrong. The sensors are template sensors that show the average price today and the average price tomorrow. the today sensor gets it’s value at 00:00:00 and the tomorrow sensor gets its value when nordpool releases the new prices
