I have no idea, where i can find something about the Loading… in my logs.
maybe in the influxdb-integration logs, Settings/Add-ons/influxdb, … or ha-logs, in some case one have to enable “loglevel- Debug” ( in configuration.yaml) default log-level in HA is “info”, so if something is “wrong” you can change loglevel
Is it a known bug that the fontFamily and fontSize doesn’t work for the title
When increasing the font size, the only thing that happens is that the text is moved down the more I increase the font size.
apex_config:
title:
text: Kompressor (Hz)
style:
fontSize: 150px;
fontWeight: light
fontFamily: Segoe Ui Light;
Here’s my 10 cents !!
My code (ignore the javascript notations).
title: {
text: 'neerslag komende twee uur',
align: 'center',
margin: 0,
offsetX: 0,
offsetY: 5,
floating: false,
style: {
fontSize: '150px', //'20px',
fontWeight: 'normal',
fontFamily: 'Segoe Ui Light', //'Helvetica, Arial, sans-serif',
color: '#FFFFFF'
Try adding the following for fixed location.
margin: 0
offsetX: 0
offsetY: 0
When implementing your code (on the Open-Meteo integration) I am getting my rain forecast shifted 1 day ahead of the rest of the graph: today, 22/03, it’s the 23/03 forecast that is displayed at the “now” level.
I believe it’s a detail to fix, but I don’t know how. Can you help?
Edit: Temperature forecast come from Openweather hourly
Beautiful, worked like a charm Thank you!
Is it possible to get 1 series with the sum of 2 entities/sensors?
I try to find the consumed solar energy by getting the difference between solar-produced energy (+ve) and exported energy (-ve).
Thanks!
It should be with data_generator but I always find it simpler to create a template sensor doing the match and then presenting the result.
Two questions about labels and their UI:
Can we somehow format the extremas labels to look simolar to data labels?
Is there any way of only showing a data label for a line series for the latest value? So basically the “now” function but with the actual data in the label for the most recent data point?
This is how a data label can be formatted vs. how extremas look:
Short answer to both questions. No.
Long answer to both questions. Nooooooooooooooo.
Reason 1:- extrema labels are an HA feature and have no format method.
Reason 2:- data labels for any series do have a formatter option, but any configuration applies to all dataPointIndex’s, not just the last one which you are seeking.
But (there’s always a but), you could use the “now” function in combination with the custom:config-template-card.
now:
show: true
label: >-
${'Current Temp.' + states['sensor.meter_plus_6469_temperature'].state + '
°C'}
Thank you Kertz!
That config-tempalte-card is getting closer and closer… I haven’t looked into it yet as I’m afraid it’s gonna be complicated and take away even more time to HA
Didn’t do anything special.
It’s shown automatically for me with graph_span: 2d
Thanks for this, worked a treat, been looking for a way to do this for ages, also used it to changed the Now colour based on a state.
now:
show: true
label: >-
${states['climate.immersion_heater_thermostat'].attributes.current_temperature + '°'}
color: >-
${states['binary_sensor.immersion_heater_heating'].state === 'on' ? 'red' : 'cyan'}
trying to figure out the data_generator
, but need some help, please…
if this is my sensor and attributes list:
how would I need to change this config, so it actually renders anything…?
- type: custom:apexcharts-card
graph_span: 48h
update_interval: 1h
header:
show: true
title: Solar Forecast
span:
start: day
now:
show: true
label: Now
yaxis:
- id: power
decimals: 0
apex_config:
plotOptions:
bar:
columnWidth: 100%
stroke:
width: 2
series:
- entity: sensor.solar_forecast_estimate_watts
yaxis_id: power
data_generator: |
return entity.attributes.watts.map((entry) => {
return [new Date(entry).getTime(), entry];
type: column
show:
extremas: true
opacity: 1
float_precision: 3
I’ve copied the above form some other sensor attributes for price, but they contain an actual named KVP like
and use:
series:
- entity: sensor.energyzero_today_energy_average_price
name: Price this hour
yaxis_id: price
data_generator: |
return entity.attributes.today.map((entry) => {
return [new Date(entry.timestamp).getTime(), entry.price];
that wont work now obviously,
but I fail to see how I should change to fix it.
please have a look? thanks!
How does this look like, if you paste the sensor in Dev-tools/state ?
Assuming that is white space before the value, you could try this.
data_generator: |
const myArray = Watts.split(" ");
return [new Date(myArray[0]).getTime(), myArray[1]];
thanks for your reply, unfortunately that throws an error:
Error: TypeError: entity.attributes.watts.map is not a function in 'return entity.attributes.watts.map((entry) => {
return [new Da...'
is there a way to test these data generators? given the fact its JS I cant get my head around any online tool with this, we need the frontend info?
to be precise, the output of:
{{state_attr('sensor.solar_forecast_estimate_watts','watts')}}
is:
{'2023-03-24T06:34:00+01:00': 0, '2023-03-24T07:00:00+01:00': 145, '2023-03-24T08:00:00+01:00': 222, '2023-03-24T09:00:00+01:00': 329, '2023-03-24T10:00:00+01:00': 414, '2023-03-24T11:00:00+01:00': 473, '2023-03-24T12:00:00+01:00': 515, '2023-03-24T13:00:00+01:00': 577, '2023-03-24T14:00:00+01:00': 1175, '2023-03-24T15:00:00+01:00': 1395, '2023-03-24T16:00:00+01:00': 1054, '2023-03-24T17:00:00+01:00': 627, '2023-03-24T18:00:00+01:00': 258, '2023-03-24T19:00:00+01:00': 70, '2023-03-24T19:02:00+01:00': 0, '2023-03-25T06:31:00+01:00': 0, '2023-03-25T07:00:00+01:00': 187, '2023-03-25T08:00:00+01:00': 329, '2023-03-25T09:00:00+01:00': 413, '2023-03-25T10:00:00+01:00': 480, '2023-03-25T11:00:00+01:00': 594, '2023-03-25T12:00:00+01:00': 689, '2023-03-25T13:00:00+01:00': 1207, '2023-03-25T14:00:00+01:00': 2140, '2023-03-25T15:00:00+01:00': 2188, '2023-03-25T16:00:00+01:00': 1808, '2023-03-25T17:00:00+01:00': 969, '2023-03-25T18:00:00+01:00': 360, '2023-03-25T19:00:00+01:00': 108, '2023-03-25T19:04:00+01:00': 0}
maybe I need the .items()
here too, like in the jinja templates for template-entity-row I use:
{% if states[config.entity] is not none %}
{% set attr =
state_attr(config.entity,'watts').items()
|sort(attribute='1',reverse=True) %}
{% set peak = (attr|first| default(('Unknown',0))) %}
{{peak[1]}} W op {{as_datetime(peak[0]).strftime('%-d-%m')}} om {{as_datetime(peak[0]).strftime('%-H')}} uur
{% else %} Initializing
{% endif %}
or is that what the .map((entry)
does in the data_generator?
maybe its no a float? figured it is, because of no quotes in the KVP
checking the objects doc on W3, doesnt help me a lot…
I have reached a similar solution a while back (lots of searching)
show:
in_header: false
legend_value: false
yaxis_id: value
color: '#ffa600'
opacity: 1
stroke_width: 1
float_precision: 1
unit: kWh
offset: '-1h'
data_generator: >
let res = []; for (const [key, value] of
Object.entries(entity.attributes.forecast.result)) {
res.push([new Date(key).getTime(), value/1000]);
} return res
in my graph (this is a combined card obviously)
EDIT:
vingerha already replied, this is the explination why.
The map function only works on ‘lists’, like arrays, you can recognize them by the square brackets [].
“entity.attributes.watts” is a dict, like objects, recognized by the curly brackets.
To convert an dict to a list, you could indeed use the items() function in jinja templates. But the data_gerenator is uses javascript. So then you use the function Object.entries().
Can you test the data_generator like this:
data_generator: |
return Object.entries(entity.attributes.watts).map((entry) => {
thanks! I figured that to be the case, but fail to fix the generator…
data_generator: |
should I completely do away with the const myArray, and use the .push construction?
because I did test:
data_generator: |
res.push([new Date(key).getTime(), value]);
} return res;
and still it does not render
wait, there more to change:
data_generator: |
Object.entries(entity.attributes.watts)) {
} return res;
now shows!
yeas!!. Now time for some formatting maybe even color_thresholds…
cool, thx @studioIngrid and @vingerha , much appreciated!
