ApexCharts card - A highly customizable graph card
How can I change the box size and font size of the label showing extrema?
how did you geht the values under your radialBar? Can’t see it in your code
Hello everyone,
is it possible to change the color of the title and the font size?
grafik
Untitled
What is the part in GUI called, that is marked with the red square?
It messes up my UX with mobile, as it effectively hides the actual value when trying to click the hour to see the actual value?
Can anyone advise? I am displaying graph of how long each irrigation zone was running. I am displaying last 3 days. I would like to display only days on X-axis. Now, I have gaps between bars where there are hours. Help is appreciated
type: custom:apexcharts-card
graph_span: 3d
span:
  end: day
apex_config:
  chart:
    height: 235px
header:
  title: Zones and Water - 3 days
  show: true
  show_states: false
  colorize_states: true
stacked: false
series:
  - entity: sensor.irrigation_drippers_house_on_per_day
    transform: return (x * 60).toFixed(0) ;
    unit: min
    type: column
    color: rgb(138, 228, 255)
    group_by:
      duration: 24h
      func: last
    stroke_width: 2
    yaxis_id: time
  - entity: sensor.irrigation_drippers_corner_on_per_day
    unit: min
    type: column
    group_by:
      duration: 24h
      func: last
    stroke_width: 2
    yaxis_id: time
  - entity: sensor.irrigation_field_on_per_day
    unit: min
    type: column
    color: rgb(235, 203, 183)
    group_by:
      duration: 24h
      func: last
    stroke_width: 2
    yaxis_id: time
  - entity: sensor.irrigation_lawn_south_on_per_day
    unit: min
    type: column
    color: rgb(174, 245, 186)
    group_by:
      duration: 24h
      func: last
    stroke_width: 2
    yaxis_id: time
  - entity: sensor.irrigation_lawn_west_on_per_day
    unit: min
    type: column
    group_by:
      duration: 24h
      func: last
    stroke_width: 2
    yaxis_id: time
  - entity: sensor.daily_well_water
    color: rgb(209, 249, 255)
    type: area
    group_by:
      duration: 24h
      func: last
    extend_to: now
    stroke_width: 1
    opacity: 0.3
    curve: smooth
    yaxis_id: water
yaxis:
  - id: time
    decimals: 0
    apex_config:
      tickAmount: 4
    min: 0
    max: ~60
  - id: water
    opposite: true
    decimals: 1
    apex_config:
      tickAmount: 4
    min: 0
    max: ~0.5
Is there a way to use a sensor or attribute value for the “name” field? e.g.:
  - entity: sensor.solcast_forecast_d3
    yaxis_id: header_only
    name: "{{ state_attr('sensor.solcast_forecast_today', 'dayname') }}"
    color: grey
    float_precision: 1
    show:
      legend_value: true
      in_header: true
      in_chart: false
The above just results in the name being the raw text in the quotes.
Yes, with config template card:
I use it for the title of my cards:
apex_config:
    title:
      text: '${''Temperatur: '' + states[''sensor.nibe_105703_40004''].state + '' °C''}'
And there is also card templater, not sure what the diff is between the two options
gadgetchnnel/lovelace-card-templater: Custom Lovelace card which allows Jinja2 templates to be applied to other cards (github.com)
Hi, I am trying to plot a graph of Czech spot electricity prices for the next day using the ote_rate sensor which looks like this:
The sensor attributes in this case aren’t an object but rather a list of 24 costs for individual hours of the next day. I tried the following card configuration but it doesn’t work (the graph displays Loading…):
      - type: "custom:apexcharts-card"
        graph_span: 1d
        span:
          start: day
        series:
          - entity: sensor.current_ote_energy_cost
            type: column
            data_generator: |
              return entity.attributes.map((cost, i) => {
                return [new Date(start.getTime() + i * 3600000), cost];
Am I doing something wrong?
I haven’t seen anyone with the same issue so I’m asking:
  • Is it possible to apply gradient to only one serie?
I have a graph with two series with different yaxis and when I apply gradient/fill both yaxis-graphs get the gradient applied, and I cannot get the fill- to only work on a single yaxis ID…
See green graph:
When i move the fill-config to the apex_config in yaxis-id the gradient is not applied …
Complete code:
now:
  show: true
  color: orange
show:
  loading: true
graph_span: 2d
update_interval: 2m
span:
  start: day
apex_config:
  fill:
    type: gradient
    gradient:
      type: vertical
      shadeIntensity: 0
      inverseColors: false
      opacityFrom: 1
      opacityTo: 0
      stops:
        - 0
  chart:
    height: 300px
    foreColor: var(--secondary-text-color)
    dropShadow:
      enabled: true
      enabledOnSeries:
        - 0
      blur: 2
    animations:
      enabled: true
      easing: easein
      animateGradually:
        enabled: true
      dynamicAnimation:
        enabled: false
  grid:
    show: false
  legend:
    show: false
  xaxis:
    labels:
      format: HH
    tickPlacement: between
    tickAmount: 10
    tooltip:
      enabled: false
  tooltip:
    enabled: true
    shared: true
    x:
      show: true
      format: dddd - H:mm
    fixed:
      enabled: true
      position: topRight
yaxis:
  - id: pris
    min: 0
    apex_config:
      labels:
        show: false
  - id: forbruk
    min: 0
    apex_config:
      opposite: true
      labels:
        show: false
series:
  - entity: sensor.powersaver_lavest
    yaxis_id: pris
    name: Pris i dag
    extend_to: end
    color: green
    type: line
    curve: stepline
    stroke_width: 1.5
    show:
      extremas: true
    data_generator: |
      return entity.attributes.hours.map((entry) => {
        return [new Date(entry.start).getTime(), entry.price];
  - entity: sensor.eva_meter_reader_smartenergymetering
    yaxis_id: forbruk
    extend_to: now
    color: darkorange
    opacity: 0.2
    type: area
    stroke_width: 2
    curve: smooth
    show:
      legend_value: true
    group_by:
      func: avg
      duration: 1.5h
Hi All,
Am having an issue where apex wont display the value of a climate attribute but it will display the state of a temp sensor that are both rendered in a template sensor. Confusing???
  sensors:
    temp_sensor1:
      unit_of_measurement: "°C"
      value_template: "{{ states('sensor.outside_temp') | float }}"
    sensors:
      inside_set_temp:
        value_template: "{{ state_attr('climate.inside', 'temperature') | float }}"
Apex will display the temp_sensor1 but it wont display inside_set_temp.
From what I can see in dev tools/templates both templates return a number.
Diagnostically: a very simple implementation.
entities:
  - entity: sensor.inside_set_temp
  - entity: sensor.temp_sensor1
and it results in this:
Capture20
the only difference is that the template inside_set_temp (N/A) renders from an attribute rather than from a state.
Any ideas from apex gurus???
Hey there, is it possible (and if so, how) to plot a datetime on the y-axis?
I have a sensor, based on the Google Maps distance matrix integration, to calculate an ETA, and I’m interested to see how the ETA changes over time.
If I just add the ETA as a sensor (see .yaml below), the plot only shows the year of the datetime (also shown below).
header:
  show: true
  title: ''
  show_states: true
series:
  - entity: sensor.eta
ETA_plot
I would like a bit finer detail, maybe only hh:mm.
Btw, this is my very first post on this forum, so teach me if I’m doing something wrong :slight_smile:
can you share the code please?
Happy to share, but this thread is very long and I am not sure what post of mine you are referencing.
this one ApexCharts card - A highly customizable graph card - #65 by RomRider
See if this helps you, I had removed the :
      show:
        datalabels: true
from each plot range since the post picture, but I put them back in to make it look like my original post. I’m not sure why I removed this option… Picture as it looks today with the option back on is below. Good hunting!
  - type: custom:apexcharts-card
    header:
      show: false
    series:
    - entity: sensor.home_instantaneous_demand
      color: orange
      type: column
      show:
        datalabels: true
      group_by:
        func: avg
        duration: 1h
        fill: 'zero'
      color: blue
      offset: -30days
      type: column
      show:
        datalabels: true
      group_by:
        func: avg
        duration: 1h
        fill: 'zero'
      color: red
      offset: -60days
      type: column
      show:
        datalabels: true
      group_by:
        func: avg
        duration: 1h
        fill: 'zero'
    update_interval: 5m
    graph_span: 24h
    span:
      start: day
    cache: true
    apex_config:
      title:
        text: 'SCE Average Watts per Hour Today vs. Last Month vs. 2 Months Ago 24h'
        align: 'center'
        floating: false
        style:
          fontSize:  '14px'
          fontWeight:  'bold'
          fontFamily:  'Arial'
      chart:
        height: 450
      yaxis:
          show: true
          showAlways: true
          showForNullSeries: true
          seriesName: undefined
          opposite: false
          reversed: false
          logarithmic: false
          tickAmount: 6
          min: 0
          max: 2000
          forceNiceScale: true
          floating: false
          decimalsInFloat: 0
I thought this was a neat idea and spent a bit of time on it but am stuck
I used a series where (through data_generator), I made the y-values as timestamps but then I tried the yaxis formatter and ‘nothing’
@RomRider is there an option to format yaxes tiemstamps into ‘anything’ e.g. show the HH:MM?
header:
  title: TEST
  show: true
  floating: false
  show_states: true
series:
  - entity: sensor.testing_fc2
    data_generator: |
      return entity.attributes.series.map((entry) => {
            return [new Date(entry.time), new Date(entry.eta).getTime()];
the data (randomly picked):
series:
  - time: '2023-05-28T02:00:00Z'
    eta: '2023-05-29T02:00:00Z'
  - time: '2023-05-29T03:00:00Z'
    eta: '2023-05-29T06:00:00Z'
  - time: '2023-05-30T04:00:00Z'
    eta: '2023-05-29T0e4:00:00Z'
friendly_name: testing_fc2
Hi
I have been trying for a while to create two vertical lines representing the sunrise and sunset, and I can’t figure out what else to do. I’m reaching out for help. I’m including my code.
span:
  start: day
graph_span: 24h
header:
  show: true
  show_states: true
all_series_config:
  stroke_width: 2
  opacity: 0
  type: area
apex_config:
  grid:
    show: false
  xaxis:
    tooltip:
      enabled: false
    labels:
      style:
        fontSize: 10px
  legend:
    show: true
  stroke:
    show: true
    width: 2
    curve: smooth
  dataLabels:
    enabled: true
  annotations:
    xaxis:
      - x: ${new Date(states['sensor.sun_next_dawn'].state).getTime()}
        label:
          text: Sunrise ☉
          borderWidth: 0
          style:
            background: '#0000'
            fontSize: 10px
      - x: ${new Date(states['sensor.sun_next_rising'].state).getTime()}
        label:
          text: ☼
          borderWidth: 0
          style:
            background: '#0000'
            fontSize: 10px
show:
  last_updated: true
series:
  - entity: sensor.atc_2dab_humidity
    show:
      datalabels: true
now:
  show: true
thanks
you have use the config-template-card for additional entities
          - type: custom:config-template-card
            entities:
               - sensor.sun_next_dawn
               - sensor.sun_next_rising
            card:
              span:
              .... your code ...
Thank you very much for the response, however, it is giving an error, and looking at the code, I don’t see anything wrong.
