ApexCharts card - A highly customizable graph card
you have first to install https://github.com/iantrich/config-template-card in the same way as apexcharts-card
you can see the error message in your screenshot: “custom element doesn’t exist”
I’m really a beginner.
Thank you so much, i modified it a bit for my taste but i learned a lot from you.
My {radialBar} color_threshold config always gives me the color defined in the first range, regardless of the sensor value… unless I’m misunderstanding the thresholds?
          - type: custom:apexcharts-card
            chart_type: radialBar
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
              color_threshold: true
            series:
              - entity: sensor.current_temperature_first_floor
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: yellow
                  - value: 79
                    color: orange
                  - value: 83
                    color: red
                min: 50
                max: 90
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
                  --card-primary-font-size: 16px;
                  --card-secondary-font-size: 14px;
                  --ha-card-border-width: 0px
color_threshold
Do you think it would be possible to have a graph (Jan - Dec) plotting the sunset times? Something similar to the below?
Since a recorder is only saving 7 days of data I would need to plot it manuellt which I’m ok with. Does anyone have an example of plotting a list of fixed values?
Is there any way to replicate this, without having to have duplicates of each series in the legend?
I’m drawing forecast using a data generator, but also the history back to midnight using the state history. Doing it like this is pretty messy.
e.g part of the config:
series:
  - entity: sensor.solar_generation
    curve: stepline
    stroke_width: 2
    color: orange
    extend_to: now
    show:
      in_header: false
      legend_value: false
  - entity: sensor.p_pv_forecast
    name: PV (Forecast)
    curve: stepline
    stroke_width: 2
    color: orange
    show:
      in_header: false
      legend_value: false
    data_generator: |
      return entity.attributes.forecasts.map((entry) => {
        return [new Date(entry.date), entry.p_pv_forecast];
I have a problem with the chart often becomming “stretched”. Especially when returning to the HA tab but sometimes even after a reload. It fixes itself usually by just reloading but sometimes I need to enter the edit mode and then dismiss it.
This is how it looks when stretched:
when correct the card is square and goes from 07-17 (I can only post one image)
Anyone have any idea what could be wrong and how to fix it?
What can I do to show the x axis label in the origin (13:00 in this picture):
experimental:
graph_span: 12h
span:
  start: hour
  offset: +60min
header:
  show: true
  title: Temperature Forecast
  show_states: true
yaxis:
  - apex_config:
      labels:
        show: false
    max: ~20
    min: ~15
now:
  show: false
  label: now
apex_config:
  grid:
    xaxis:
      lines:
        show: true
    yaxis:
      lines:
        show: false
  xaxis:
    labels:
      style:
        fontSize: 15px
        fontWeight: bold
  legend:
    show: false
  dataLabels:
    enabled: true
    formatter: |
      EVAL:function (val) {
        return (Math.round(val).toFixed(0) + '°C');
    style:
      fontSize: 15px
      color: black
      fontWeight: bold
    background:
      enabled: true
      borderWidth: 3
      opacity: 1
      foreColor: black
      borderColor: rgb(44,153,234)
      borderRadius: 10
series:
  - entity: weather.pirate_weather_home
    stroke_width: 3
    color: white
    color_threshold:
      - value: 10
        color: rgb(242,249,255)
      - value: 17.5
        color: rgb(44,153,234)
      - value: 18
      - value: 25
    type: line
    unit: °C
    extend_to: now
    show:
      in_header: false
      datalabels: true
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
        return [new Date(entry.datetime), entry.temperature];
    group_by:
      func: avg
      duration: 2h
Hi, does anyone know how to change the font size of the series value in the header? I want to fit all four values in this chart.
Here’s the code I have so far.
I’ve got a great interface set up for climate control in multiple zones/rooms, and the only thing missing is color threshold for the radialBar to show current temperature:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: grid
  - square: false
    columns: 3
    type: grid
    cards:
      - type: custom:stack-in-card
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
              - entity: sensor.current_temperature_basement
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
                  --ha-card-border-width: 0px;
            entity: climate.ac000w011633790
            tap_action:
              action: fire-dom-event
              browser_mod:
                command: call-service
                title: Test
                service: browser_mod.popup
                service_data:
                  card:
                    type: vertical-stack
                    cards:
                      - type: custom:button-card
                        tap_action:
                          action: none
                        hold_action:
                          action: none
                        styles:
                          grid:
                            - grid-template-areas: '"area area" "temp humidity" "tchart hchart"'
                            - grid-template-columns: 1fr 1fr
                            - grid-template-rows: 1fr
                          custom_fields: null
                          area:
                            - font-size: 25px
                            - font-weight: bold
                            - align-self: middle
                            - justify-self: middle
                          temp:
                            - padding-top: 10px
                            - padding-right: 10px
                            - align-self: end
                            - justify-self: right
                            - font-size: 30px
                            - font-weight: bold
                          humidity:
                            - padding-top: 10px
                            - align-self: end
                            - font-size: 30px
                            - font-weight: bold
                          tchart:
                            - height: 50px
                            - padding-right: 5px
                          hchart:
                            - height: 50px
                            - padding-left: 5px
                        card:
                          - background-color: rgba(7, 103, 215, 0.24)
                        custom_fields:
                          area: Basement
                          temp: |
                              if (states['sensor.current_temperature_basement'].state <= 60) {
                              return `<ha-icon
                                icon="mdi:thermometer"
                                style="width: 20px; height: 20px; color: blue;">
                                </ha-icon> <span> ${states['sensor.current_temperature_basement'].state} °F</span>`;
                              if (states['sensor.current_temperature_basement'].state <= 67) {
                              return `<ha-icon
                                style="width: 20px; height: 20px; color: cyan;">
                                </ha-icon> <span> ${states['sensor.current_temperature_basement'].state} °F`;
                              if (states['sensor.current_temperature_basement'].state <= 73) {
                              return `<ha-icon
                                style="width: 20px; height: 20px; color: green;">
                              if (states['sensor.current_temperature_basement'].state <= 80) {
                              return `<ha-icon
                                style="width: 20px; height: 20px; color: orange;">
                              if (states['sensor.current_temperature_basement'].state <= 90) {
                              return `<ha-icon
                                style="width: 20px; height: 20px; color: red;">
                              } else {
                                return `<ha-icon
                                style="width: 20px; height: 20px; color: white;">
                          humidity: |
                              if (states['sensor.basement_baseboards_humidity'].state <= 50) {
                              return `<ha-icon
                                icon="mdi:water-percent"
                                </ha-icon> <span> ${states['sensor.basement_baseboards_humidity'].state} %</span>`;
                              if (states['sensor.basement_baseboards_humidity'].state <= 70) {
                              return `<ha-icon
                              if (states['sensor.basement_baseboards_humidity'].state <= 100) {
                              return `<ha-icon
                              } else {
                                return `<ha-icon
                                </ha-icon> <span> ${states['sensor.basement_baseboards_humidity'].state}</span>`;
                          tchart:
                            card:
                              type: custom:mini-graph-card
                              entities:
                                - sensor.current_temperature_basement
                              points_per_hour: 1
                              color_thresholds:
                                - value: 60
                                  color: blue
                                - value: 67
                                  color: cyan
                                - value: 73
                                  color: green
                                - value: 80
                                  color: orange
                                - value: 90
                                  color: red
                              tap_action:
                                action: none
                              show:
                                icon: false
                                state: false
                                points: hover
                              card_mod:
                                style: |
                                  ha-card {
                                    border: none;
                                    background-color: rgba(7, 103, 215, 0.0);
                          hchart:
                            card:
                              entities:
                                - sensor.basement_baseboards_humidity
                              points_per_hour: 1
                              color_thresholds:
                                - value: 50
                                  color: green
                                - value: 70
                                  color: orange
                                - value: 100
                                  color: red
                              tap_action:
                                action: none
                              show:
                                icon: false
                                state: false
                                points: hover
                              card_mod:
                                style: |
                                  ha-card {
                                    border: none;
                        card_mod:
                          style: |
                            ha-card {
                              border: none;
                              background-color: rgba(7, 103, 215, 0.24);
                      - type: custom:mushroom-climate-card
                        primary_info: name
                        secondary_info: none
                        hvac_modes:
                          - heat
                          - cool
                          - 'off'
                        show_temperature_control: true
                        collapsible_controls: false
                        icon: mdi:heat-pump-outline
                        tap_action:
                          action: none
                        card_mod:
                          style: |
                            ha-card {
                              {% if is_state('climate.ac000w011633790', 'heat') %}
                                background-color: rgba(255, 0, 0, 0.3);
                              {% elif is_state('climate.ac000w011633790', 'cool')
                                background-color: rgba(0, 150, 255, 0.45);
                              {% else %}
                              {% endif %}
                        entity: climate.basement_baseboards
                        primary_info: name
                        hvac_modes:
                          - heat
                          - 'off'
                        collapsible_controls: true
                        tap_action:
                          action: call-service
                          service: climate.set_hvac_mode
                          data: null
                          hvac_mode: heat
                          target: null
                          entity_id: climate.basement_baseboards
                          confirmation: null
                          text: Do you want to turn on the baseboards?
                        icon: mdi:radiator
                        card_mod:
                          style: >
                            ha-card { {% if
                            is_state('climate.basement_baseboards', 'heat') %}
                              background-color: rgba(255, 0, 0, 0.24);
                            {% else %}
                            {% endif %} --card-primary-font-size: 16px;
            primary: >-
              {% set state =
              (states.sensor.current_temperature_first_floor.state) %} {{ state
              }} °F
            secondary: Basement
            icon: |-
                mdi:fire
              {% elif is_state('climate.ac000w011633790', 'cool') %}
                mdi:snowflake
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: |-
                red
                blue
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
            entity: climate.ac000w007172407
            tap_action:
              action: more-info
            primary: >-
              {% set state =
              }} °F
            secondary: First Floor
            icon: |-
              {% if is_state('climate.first_floor_baseboards', 'heat') %}
                mdi:radiator
              {% elif is_state('climate.ac000w007172407', 'heat') %}
                mdi:fire
              {% elif is_state('climate.ac000w007172407', 'cool') %}
                mdi:snowflake
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: >-
              {% if is_state('climate.ac000w007172407', 'heat') or
              is_state('climate.master_bedroom_baseboards', 'heat') %}
                red
                blue
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
              - entity: sensor.current_temperature_second_floor
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
            tap_action:
              action: more-info
            primary: >-
              {% set state =
              (states.sensor.current_temperature_second_floor.state) %} {{ state
              }} °F
            secondary: Second Floor
            icon: |-
              {% if is_state('climate.second_floor_baseboards', 'heat') %}
                mdi:radiator
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: |-
                red
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
              - entity: sensor.current_temperature_master_bedroom
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
            tap_action:
              action: more-info
            primary: >-
              {% set state =
              (states.sensor.current_temperature_master_bedroom.state) %} {{
              state }} °F
            secondary: Master Bedroom
            icon: |-
              {% if is_state('climate.master_bedroom_baseboards', 'heat') %}
                mdi:radiator
              {% elif is_state('climate.ac000w011634191', 'heat') %}
                mdi:fire
              {% elif is_state('climate.ac000w011634191', 'cool') %}
                mdi:snowflake
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: >-
              {% if is_state('climate.ac000w011634191', 'heat') or
                red
                blue
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
              - entity: sensor.current_temperature_kid_s_room
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
            entity: climate.heat_pump_kids_room
            tap_action:
              action: more-info
            primary: >-
              {% set state =
              (states.sensor.current_temperature_kid_s_room.state) %} {{
              state }} °F
            secondary: Kid's Room
            icon: |-
                mdi:radiator
              {% elif is_state('climate.heat_pump_kids_room', 'heat') %}
                mdi:fire
              {% elif is_state('climate.heat_pump_kids_room', 'cool') %}
                mdi:snowflake
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: >-
              {% if is_state('climate.heat_pump_guest_room', 'heat') or
                red
              {% elif is_state('climate.heat_pump_guest_room', 'cool') %}
                blue
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
        cards:
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 100%
                    margin: 0
              legend:
                show: false
              chart:
                height: 140
            experimental:
            series:
              - entity: sensor.current_temperature_guest_room
                color_threshold:
                  - value: 50
                    color: blue
                  - value: 67
                    color: cyan
                  - value: 72
                    color: green
                  - value: 75
                    color: orange
                  - value: 80
                    color: red
                min: 50
                max: 90
                header_actions:
                  tap_action:
                    action: none
                show:
                  legend_value: false
            card_mod:
              style: |
                ha-card {
            entity: climate.heat_pump_guest_room
            tap_action:
              action: more-info
            primary: >-
              {% set state =
              (states.sensor.current_temperature_guest_room.state) %} {{ state
              }} °F
            secondary: Guest Room
            icon: |-
                mdi:radiator
              {% elif is_state('climate.heat_pump_guest_room', 'heat') %}
                mdi:fire
                mdi:snowflake
              {% else %}
                mdi:cancel
              {% endif %}
            icon_color: >-
                red
                blue
              {% else %}
                #6f6f6f
              {% endif %}
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -59px;
                  margin-right: 0px;
card_mod:
  style: |
    ha-card {
      --ha-card-background: rgba(7, 103, 215, 0.24);
Climate
The radial bar shows current temperature. The icon shows what the climate control unit is doing. Clicking on the icon will ideally show a pop-up with various options, but I don’t have that working yet.
Credit to @rhysb for sharing YAML.
Why don’t the last label on the column (Fri) show up on my diagram, and how can I fix it?
apex_config:
  xaxis:
    labels:
      format: ddd
graph_span: 1w
span:
  end: day
series:
  - entity: input_number.dagens_kwh
    yaxis_id: elanv
    type: column
    group_by:
      func: last
      duration: 1d
    unit: kWh
    show:
      legend_value: false
      in_chart: true
      - entity: sensor.indoor_temperature
        color: purple
        float_precision: 0
        offset: '-1d'
gives me Gisteren(-1d). how can I get rid of the (-1d) ?
On Mine the first Label, “Vanished” about 2 weeks, a month ago, have no idea why, maybe something about using card_mod " margin .- X " not sure, maybe i dont really care, to much other stuff to think about :grinning_face_with_smiling_eyes:
03.06.2023_01.23.24_REC
    show:
      legend_value: false
Nice! Can you share your code?
:joy: It’s a “combo” of several cards, in vertical stack in grid, and alot of card_mod (probably to much/over-modded)
But sure, maybe you can get some ideas (i doubt you can use it as is, but maybe you can “get a grip” of what i’ve been playing with
I wish i could get something similar, an easier way , but i think i stay with this “touch” for awhile now.
PS: here is the part shown
  - type: custom:text-divider-row
    text: 7 Hours Ahead
    align: center
  - type: vertical-stack
    cards:
      - type: custom:weather-chart-card
        entity: weather.forecast_home_hourly
        show_main: false
        show_attributes: false
        icons: /local/weather-icons/shadows/
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              margin-top: -20px;
              margin-right: -10px;
              margin-left: -5px;
              margin-bottom: 0px;
              padding-bottom: 0px;
              padding-top: 0px;
            ha-card div.chart-container {
              height: 0.1px;
            ha-card div.conditions img {
              height: 40px; width: 40px;
        graph_span: 7h
        span:
          start: hour
          offset: +1h
        header:
          show: false
          show_states: false
        all_series_config:
          group_by:
            func: last
            duration: 1h
        apex_config:
          grid:
            xaxis:
              lines:
                show: false
            yaxis:
              lines:
                show: false
          chart:
            height: 40
          plotOptions:
            bar:
              columnWidth: 80%
              borderRadius:
                - 5
          legend:
            show: false
          xaxis:
            axisBorder:
              color: '#2E2E2E'
          yaxis:
            show: false
        series:
          - entity: weather.forecast_home_hourly
            yaxis_id: temp
            unit: °C
            type: column
            color: '#FFBF00'
            data_generator: |
                var date = new Date(entry.datetime);
                return [date, entry.temperature];
            show:
              datalabels: true
            yaxis_id: mm
            unit: mm
            type: column
            color: '#6495ED'
            data_generator: |
                    return [date, entry.precipitation];
            show:
              datalabels: true
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              border-radius: 0px;
              padding: 0px 0px 0px 0px;
              margin-top: -30px;
              margin-right: 0px;
              margin-left: 0px;
              margin-bottom: -40px;
    text: Next 5 Days
    align: center
    cards:
        show_main: false
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              margin-top: -22px;
              margin-left: -20px;
              margin-bottom: 0px;
              height: 0.1px;
        graph_span: 5d
        span:
          start: day
          offset: +1d
        header:
          show: false
          show_states: false
        all_series_config:
          group_by:
            func: last
            duration: 1d
        apex_config:
          grid:
            xaxis:
              lines:
                show: false
            yaxis:
              lines:
                show: false
          chart:
            height: 40
          plotOptions:
            bar:
              columnWidth: 80%
              borderRadius:
                - 5
          legend:
            show: false
          xaxis:
            axisBorder:
              color: '#2E2E2E'
            lines:
              show: false
            labels:
              format: ddd dd
          yaxis:
            show: false
        series:
            yaxis_id: temp2
            unit: °C
            type: column
            color: '#FFBF00'
            data_generator: |
            show:
              datalabels: true
            yaxis_id: temp3
            unit: °C
            type: column
            color: '#87bf50'
            data_generator: |
                return [date, entry.templow];
            show:
              datalabels: true
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              border-radius: 0px;
              padding-bottom: 0px !important;
              padding-top: 0px !important;
              margin-top: -28px;
              margin-right: 0px;
              margin-left: -25px;
              margin-bottom: -5px;
        graph_span: 5d
        span:
          start: day
          offset: +1d
        header:
          show: false
          show_states: false
        all_series_config:
          group_by:
            func: last
            duration: 1d
        apex_config:
          grid:
            xaxis:
              lines:
                show: false
            yaxis:
              lines:
                show: false
          chart:
            height: 40
          plotOptions:
            bar:
              columnWidth: 80%
              borderRadius:
                - 5
          legend:
            show: false
          xaxis:
            axisBorder:
              color: '#2E2E2E'
            lines:
              show: false
            labels:
              format: ddd dd
          yaxis:
            show: false
        series:
            yaxis_id: mm
            unit: mm
            type: column
            color: '#6495ED'
            data_generator: |
            show:
              datalabels: true
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              border-radius: 0px;
              margin-top: -34px;
              margin-right: -20px;
              margin-left: -40px;
              margin-bottom: -13px;
Here is the whole “column in grid”
Edit: 28-06
Doo to HA updates, i change graph_span to 6 days ! as the “weather.forecast_home
" has been updated”
And had to change margins few places also, at the same time , as something caused it to “cover” above “text-divider”, most likely also caused by the change in “weather.forecast_home” entity
Hi everyone,
Can someone help me with my graph? I want to move the yaxis to more the boarders of the card. Here is my code:
header:
  show: true
  title: Verbrauch
graph_span: 1h
update_interval: 1min
all_series_config:
  stroke_width: 1
apex_config:
  legend:
    show: false
yaxis:
  - id: first
    decimals: 0
    apex_config:
      forceNiceScale: true
      title:
        text: '[W]'
        rotate: 0
        offsetX: 15
        offsetY: -140
      'labels:':
        show: true
        offsetX: 50
      axisTicks:
        show: true
  - id: second
    opposite: true
    decimals: 0
    apex_config:
      title:
        text: '[%]'
        rotate: 0
        offsetX: -15
        offsetY: -140
  - id: third
    opposite: true
    decimals: 0
    apex_config:
      title:
        text: '[°C]'
        rotate: 0
        offsetX: -15
        offsetY: -140
series:
  - entity: sensor.wohnzimmer_server_stecker_aubess_tuya_power
    yaxis_id: first
    fill_raw: last
    show:
      in_header: true
  - entity: sensor.proxfuji_cpu_load_1_min_avg
    yaxis_id: second
    offset: +1min
    fill_raw: last
  - entity: sensor.proxfuji_temperature_x86_pkg
    yaxis_id: third
    fill_raw: last
And here the resulting graph:
Screenshot_20230605_092702
I would like it to look like this:
sssScreenshot_20230605_094729
Edit:
I had a typo and was able to move the yaxis label to the side, but the graph stays small:
yaxis:
  - id: first
    decimals: 0
    apex_config:
      title:
        text: '[W]'
        rotate: 0
        offsetX: 15
        offsetY: -140
      labels:
        show: true
        offsetX: -30
      axisBorder:
        offsetX: -30
      axisTicks:
        offsetX: -30
Screenshot_20230605_095913
edit: nevermind. it just kind of … fixed itself after a while.
I don’t know since when, but I get a mass of errors like this from ApexCharts:
2023-06-07 07_02_48-Übersicht – Home Assistant
Chrome freezes because of not enough memory.
Example of a configuration:
graph_span: 4h
update_interval: 10s
cache: false
show:
  loading: false
span:
  offset: +30m
now:
  show: true
color_list:
  - var(--label-badge-blue)
header:
  show: true
  title: i3s | soc
  show_states: true
  standard_format: true
  colorize_states: true
all_series_config:
  show:
    legend_value: false
series:
  - entity: sensor.i3s_120_remaining_battery_percent
    unit: '%'
    fill_raw: last
yaxis:
  - min: 0
    max: 100
    apex_config:
      tickAmount: 5
apex_config:
  style:
    width: 100%
    height: auto
  xaxis:
    tooltip:
      enabled: false
card_mod:
  style: |
    #state__name, .apexcharts-xaxis-label, .apexcharts-yaxis-label {
      font-size: 1em !important;
    .apexcharts-legend {
      padding-top: 10px;
My initial thought is, your “battery” wont last long, if you “poll” it every 10 sec, and i wonder why you actually want the information “Every 10 seconds” , are you “living on the edge” ? or is it a “life saving” Device?
I believe HA can handle this “setup”, but obviously not your Chrome
