In view of the fact that I agree with you about the time interval of 10 seconds, this is no explanation for the error messages and no solution.
Anyway, thanks for the tip, I’ll change it.
Hi there!
Does anybody know how to get rid of that white space in the upper section in order to maximize the graph?
I think I found a bug: The property borderRadiusApplication: “around” has no impact on the bar chart. Only ends gets rounded.
- type: custom:apexcharts-card
card_mod:
style: |
ha-card {
background-color: transparent !important;
border-radius: 0px;
padding: 0px !important;
margin: 0px !important;
border-width: 1px;
border-color: var(--green);
header:
show: false
title: Stromverbrauch / 24h
apex_config:
plotOptions:
bar:
borderRadius: 5
borderRadiusApplication: "around"
chart:
height: 98px
fontFamily: Quicksand
parentHeightOffset: 20px
yaxis:
forceNiceScale: true
reversed: false
opposite: true
dataLabels:
background: false
offsetY: -10
style:
colors:
- 'var(--contrast20)'
graph_span: 24h
update_interval: 60sec
layout: minimal
span:
end: hour
all_series_config:
type: column
curve: smooth
show:
datalabels: false
series:
- entity: sensor.hauszahler
unit: Wh
transform: "return x / 2;"
color: "var(--green)"
group_by:
duration: 2h
func: avg
Could someone help me to create a graph like this ?
My sensors are: sensor.inverter_input_power, sensor.power_meter_consumption, sensor.power_meter_exported and sensor.power_meter_active_power (this one should show negative values eg: transform: return Math.max(0,x)) or transform: return -Math.min(0,x);
How do you make red line (Grid) not to be negative ?
Here is my code
experimental:
color_threshold: true
header:
show: true
show_states: true
colorize_states: true
title: Power Flows
graph_span: 1d
span:
start: day
apex_config:
chart:
type: area
stroke:
show: true
dataLabels:
enabled: true
legend:
show: true
fill:
type: gradient
gradient:
inverseColors: true
type: vertical
shadeIntensity: 0.7
opacityFrom: 0.7
opacityTo: 0.3
grid:
show: false
all_series_config:
stroke_width: 1
group_by:
func: last
duration: 30m
curve: smooth
type: area
series:
- entity: sensor.inverter_active_power
color: green
extend_to: false
transform: return x / 1000;
unit: kW
float_precision: 2
- entity: sensor.power_meter_active_power
color: red
extend_to: false
unit: kW
float_precision: 2
- entity: sensor.apf_real_house_load
color: blue
extend_to: false
unit: kW
float_precision: 2
I want to use a input_select as value for a annotation line. How?
apex_config:
annotations:
yaxis:
- 'y': {{states['input_select.limit']}}
borderColor: '#cf6679'
label:
text: Limit
style:
color: '#fff'
background: '#cf6679'
have to do a new sensor as this:
value_template: "{{(states('sensor.power_meter_active_power') | float * -1 ) | round(2)}}"
You could wrap it with card-templater, it allows to add templates to almost any attribute (there is another card that allows templating too)
EDIT, example where I use wto input select fields to drive the offset
can we rewrite a data_generator:
data_generator: |
return entity.attributes.prices.map((record, index) => {
return [record.time, record.price];
to use individual entities for the hourly prices?
Ive deleted that CC providing those attributes (not allowed in core HA…) but do have a rest sensor providing 24 entities
I have this in a custom:mini-graph-card config now, but would prefer it to be an apexcharts.
this is the idea currently:
- entity: sensor.energieprijs_uur_0
- entity: sensor.energieprijs_uur_1
- entity: sensor.energieprijs_uur_2
- entity: sensor.energieprijs_uur_3
- entity: sensor.energieprijs_uur_4
- entity: sensor.energieprijs_uur_5
- etc!
would appreciate some nudges into the right direction , thx!
Hi, can anyone help me troubleshoot two issues please?
No matter what I do, I can’t seem to disable the automatic scaling of the Y axis. I would like to be able to set min and max manually so it doesn’t constantly adjust with my MQTT sensors. However, when I do this it shows me the correct Y axis for a second whilst pulling data from my sensor, but then defaults to the max value of the sensor and continues to automatically adjust the scale. I have tried forceNiceScale with no luck.
I also can’t seem to set a label on my Y axis. No matter what options I out in, nothing ever shows.
I can’t help thinking that the two issues are related, and would be very grateful if someone could point out whatever obvious point I’m missing!
Thanks in advance
title: Water
- panel: true
cards:
graph_span: 48h
show:
last_updated: true
apex_config:
chart:
height: 300px
width: 100%
yaxis:
labels:
show: true
yaxis:
- id: W
decimals: 0
apex_config:
min: 0
max: 80
labels:
show: true
series:
- entity: sensor.tank_water_temperature
type: line
group_by:
func: last
duration: 5m
stroke_width: 2
yaxis_id: W
D’oh! Thanks very much…
This awesome card is sometimes too awesome
to find your way aound
very simple, just add “-” to your return x
color: red
extend_to: false
transform: return x / -1000;
unit: kW
float_precision: 2
where do I put this ?
within the series as it is a series/sensor specific choice
Hi, your post was 2 years ago, and unfortunately I can’t help you with your question either.
But could you share the yaml for your solar forcast card? Especially the readout of the SOLCast pv_estimate10 and pv_estimate90 (both Future Forecast) with the correct timestamp would interest me. (the setting of the data_generator). Thanks a lot!
To generate a forecast card using Apexcharts and SolCast showing the past forecast values (forecast pv_estimate in kWh) and the future lower and upper bound probabilistic forecast data P10, P90 (detailedForecast pv_estimate10 and pv_estimate90 in kWh) and the generated PV power (solarman_total_ac_output_power_active in W):
apex_config:
chart:
height: 350px
all_series_config:
unit: kWh
float_precision: 3
opacity: 0.3
stroke_width: 3
header:
title: Daily forecast
show: true
standard_format: true
show_states: true
graph_span: 1d
span:
start: day
offset: '-0d'
now:
show: true
label: Now
yaxis:
- id: kWh
min: 0
max: 0.6
apex_config:
tickAmount: 5
- id: header_only
show: false
series:
- entity: sensor.solarman_total_ac_output_power_active
yaxis_id: kWh
type: area
color: orange
opacity: 0.4
show:
legend_value: false
in_header: false
stroke_width: 1
transform: return x/1000
group_by:
func: avg
duration: 1min
extend_to: false
- entity: sensor.solcast_forecast_today
yaxis_id: kWh
type: line
color: black
opacity: 1
stroke_width: 2
data_generator: |
var now = new Date().getTime();
var today = entity.attributes.forecast
.filter(start => new Date(start["period_start"]).getTime() < (now + 1000*60*30))
.map((start, index) => {
return [
new Date(start["period_start"]).getTime(), start["pv_estimate"] || 0
var data = today
return data;
show:
legend_value: false
in_header: false
extend_to: false
yaxis_id: kWh
type: line
color: grey
opacity: 1
stroke_width: 2
data_generator: |
var today = entity.attributes.detailedForecast
.filter(start => new Date(start["period_start"]).getTime() > (now - 1000*60*30))
return [
var data = today
return data;
show:
legend_value: false
in_header: false
extend_to: false
yaxis_id: kWh
type: line
color: grey
opacity: 0.6
stroke_width: 1
data_generator: |
return [
new Date(start["period_start"]).getTime(), start["pv_estimate10"] || 0
var data = today
return data;
show:
legend_value: false
in_header: false
extend_to: false
yaxis_id: kWh
type: line
color: grey
opacity: 0.6
stroke_width: 1
data_generator: |
return [
new Date(start["period_start"]).getTime(), start["pv_estimate90"] || 0
var data = today
return data;
show:
legend_value: false
in_header: false
extend_to: false
How do you reference attributes? The docs say that you can read an attribute instead of state, but it doesn’t do anything, state is the same as the last value of the data_generator which reads an array called rates. The “current” value is also held in an attribute called rate.
In a console.log in the data_generator I can reference entity.attributes.rate.value_inc_vat, but how do I use this in the attribute?
attributestring v1.4.0 Instead of retrieving the state, it will retrieve anattributeof the entity. Make sure you increaseupdate_delayif the chart doesn’t reflect the last value of the attribute
I have added an extra entity and hidden the incomplete graph (ends at now) and used the state from that as the header, meanwhile taken the data_generator for the same, hidden the header. Now I’m left with legend names and values at the bottom for each duplicate series How can I remove the legend at the bottom, I blanked them out but the dots remain?
graph_span: 29h
span:
start: day
offset: +0h
I had the span set to 24h with an 12h offset, but this needs to be more dynamic as the next day’s forecast doesn’t appear until 4pm and after midnight, the start: day really screwed things up. how can I restrict the range to consistently show previous 2 hours and as much future data at is available, sizing the graph to the available data rather than getting the flatline at the end?
