ApexCharts card - A highly customizable graph card
I am trying to create a donut chart based off some local csvfiles, but I am not able to show each entry (“Name”) with its corresponding value (“Wert”), instead, it just uses the last entry in my local json file as a series value.
For a donut chart, is there a way to create a custom series for each “Name” it finds in the local json? So is there a dynamic way to add as many series as it finds in the json?
type: custom:apexcharts-card
chart_type: donut
header:
  show: true
  standard_format: true
  disable_actions: true
  show_states: false
  colorize_states: true
apex_config:
  plotOptions:
    pie:
      donut:
        labels:
          show: true
          total:
            show: true
series:
  - entity: input_number.dummy
    group_by:
      func: "raw"
    data_generator: |
      const request  = async () => {
        let a = [],
          req = await fetch('/local/data/mydata/holdings.json', {method: 'GET', headers: {'Accept': 'application/json'}, cache: 'no-cache' }),
          req_json = await req.json();
        for(let r of req_json["data"]) {
          a.push([r["Name"],r["Wert"]]);
        console.log(a);
        return a;
      return request();
Is it possible to have two (or more) concentric donuts like this…?
ChatGPT suggested some YAML (a piece if it is below), but I wasn’t able to get it to work my in case. Perhaps sharing that will inspire someone.
series:
  - data:
      - entity: sensor.sensor1
      - entity: sensor.sensor2
      - entity: sensor.sensor3
  - data:
      - entity: sensor.sensor4
      - entity: sensor.sensor5
      - entity: sensor.sensor6
Fingers crossed. Thanks in advance!
Install config-template-card Card integration and try this:
type: custom:config-template-card
variables:
  - states['48_hour_anerage_electricity_profit_cost'].state
card:
  header:
  apex_config:
    annotations:
      yaxis:
        - 'y': ${vars[0]}
          borderColor: '#00E396'
          borderWidth: 4
          label:
            text: mean
Is there any way to change font-size for entities value in header when using:
header:
  show_states: true
I’ve tried various card-mod but nothing seems to be able to change the font for those values. I only managed to change the font for the title.
Does Apexchart not working with Long Term Statistic ?
My Charts seems to not include the long term stats data?
It does. Have a look at the statistics options.
ChatGPT doesn’t understand what you’re doing, it suggests total nonsense.
Useful during the cold winter days:
Code
span:
  end: day
header:
  title: Airco Energy Consumption
  show: true
graph_span: 7d
locale: en
apex_config:
  chart:
    type: area
  xaxis:
    labels:
      format: ddd
yaxis:
  - id: first
    decimals: 0
    apex_config:
      tickAmount: 4
      forceNiceScale: true
  - id: second
    opposite: true
    decimals: 0
    apex_config:
      tickAmount: 4
series:
  - entity: sensor.airco_energy
    yaxis_id: first
    type: column
    show:
      datalabels: true
    statistics:
      type: sum
      period: hour
    group_by:
      func: diff
      duration: 24h
  - entity: sensor.bresser_weather_station_temperature
    yaxis_id: second
    type: line
    show:
      datalabels: true
    group_by:
      func: min
      duration: 24h
Hello
I was looking an implemetation for this also, but apexcharts only can use different entities for pie as far as I know.
Perhaps a Feature Request for apexchart to use values of the same sensor??
Meanwhile, I have configured some sensors to cover this.
Perhaps not the best one or the final one. But it could be an option
Here is the link with the implementation:
Sensor with different values in an apexchart pie – MelCloud – OperationMode example
I hope this helps
Best regards
Thx!
I have allmost the same using this code:
experimental:
  color_threshold: true
graph_span: 7d
span:
  end: day
header:
  show: true
  title: WP werkingsstatus | dag
  show_states: true
chart_type: pie
series:
  - entity: sensor.wp_werking_geschiedenis_legionella
  - entity: sensor.wp_werking_geschiedenis_koelen
  - entity: sensor.wp_werking_geschiedenis_ontdooien
  - entity: sensor.wp_werking_geschiedenis_stop
  - entity: sensor.wp_werking_geschiedenis_verwarmen
  - entity: sensor.wp_werking_geschiedenis_warm_water
but yours look better, so i borrow some of the code, great
I would like to use this feature of apex charts for smoother interpolations:
stroke: {
curve: “monotoneCubic”
I can’t figure out where to add it. I tried this, but it just stopped showing any plots:
apex_config:
stroke:
curve: monotoneCubic
Is there a way to make the graph using the full card, having no axis and name as well as state (center and a big font) on the top and above the graph?
Similar to the mock shown below?
I know the mini-graph-card, but there the graph is only a very small part of the card.
Here are a number of things you can play with
layout: minimal
apex_config:
  legend:
    show: false
  grid:
    margin:
      left: 0
      right: 0
  xaxis:
    axisborder:
      show: false
    axisTicks:
      show: false
    labels:
      show: false
  yaxis:
    axisborder:
      show: false
    axisTicks:
      show: false
    labels:
      show: false
The layout: minimal does most of what I was looking for. Thanks for the hint.
Most of the other seem to redundant, when going with the minimal; at least, I don’t see changes, wehe playing with those.
Now I looks like this:
Is there a way to stretch the graph to the top of the graph (plotted behind the state value)?
How to move the state value to the middle?
Edit: Added the source, to have it together with the result.
layout: minimal
header:
  show: true
  title: Außen
  floating: true
  show_states: true
  colorize_states: false
graph_span: 24h
series:
  - entity: sensor.lumi_lumi_weather_temperature_2
    color: '#ff444f'
apex_config:
  stroke:
    width: 2
  legend:
    show: false
    showForSingleSeries: true
    position: top
    horizontalAlign: center
    fontSize: 40px
    offsetX: 0
    offsetY: -8
    labels:
      useSeriesColors: false
    onItemClick:
      toggleDataSeries: false
    onItemHover:
      highlightDataSeries: false
add floating: true to the header section
Had this already. Does only half of the expected stretching.
I’ve added my source to my posting above, to have source and result together.
Looking for some help here with the y-axis. The value does not correspond to the value of the combined values for both airco’s, it tops off at 16. Looking for some advise where I am going wrong with my config.
stacked: true
span:
  end: day
header:
  show: true
graph_span: 7d
apex_config:
  chart:
    type: area
  xaxis:
    labels:
      format: ddd
yaxis:
  - id: first
    decimals: 0
    apex_config:
      tickAmount: 4
  - id: second
    opposite: true
    decimals: 0
    apex_config:
      tickAmount: 4
series:
  - entity: sensor.living_room_energy_consumption
    yaxis_id: first
    type: column
    show:
      datalabels: true
    statistics:
      type: sum
      period: hour
    group_by:
      func: diff
      duration: 24h
  - entity: sensor.daily_energy_airco_upstairs_2
    yaxis_id: first
    type: column
    show:
      datalabels: true
    statistics:
      type: sum
      period: hour
    group_by:
      func: diff
      duration: 24h
  - entity: sensor.average_daily_outdoor_temp
    name: Average temperature
    yaxis_id: second
    type: line
    show:
      datalabels: true
    group_by:
      func: min
      duration: 24h
apex
Hi guys,
does anyone have an idea, how I could align the columns correctly?
I think with this data generator I am just adding the start time, but no end time, so the columns are centered exactly at the hour:
But this example, the columns are right of the hour, as they seem to represent a duration of 1hr or have an end time:
How could I change the data_generator to get the same results as in the example?
There would be an attribute end_time available too.
- type: custom:apexcharts-card
  card_mod:
    style: |
      ha-card {
        border: none;
        background: none;
        box-shadow: none;
  yaxis:
    - decimals: 0
      show: true
      apex_config:
        decimalsInFloat: 0
        labels:
          style:
            colors: '#9b9b9b'
            fontSize: 12
            fontWeight: bolder
            fontFamily: Roboto,Noto,sans-serif
  apex_config:
    tooltip:
      x:
        show: true
        format: HH:00 - HH:59
    chart:
      height: 232px
    grid:
      show: true
      borderColor: '#9b9b9b'
    xaxis:
      axisTicks:
        show: true
        color: '#9b9b9b'
      labels:
        style:
          colors: '#9b9b9b'
          fontSize: 12
          fontWeight: bolder
      axisBorder:
        show: false
  graph_span: 36h
  span:
    start: hour
    offset: '-2hr'
  series:
    - entity: sensor.epex_spot_at_net_price
      show:
        extremas: true
      type: column
      color: '#0288d1'
      stroke_width: 2.5
      unit: ct/kWh
      extend_to: false
      float_precision: 2
      data_generator: >
        return entity.attributes.data.map((entry, index) => { return [new
        Date(entry.start_time).getTime(), entry.price_ct_per_kwh]; });
Thank you
Oliver
Please, can you share the code?
I have added the complete card code now.
Thank you
If I look at the history graph, the measurements seem to be ‘on’ the hour so why would you want it to show ‘next’ to the hour, isn’t that twisting the data? I also donot know why you interpret the column to be a period but that is a different topic. Simple solution (?) would be to add a small offset to push it left or right as this seems stable ‘on-the-hour’
