just remove “as_duration: hour” and you will get duration in hours only
I was looking if it is possible to have different colors above and below the x-axis…
this is what I found
Is it possible to do it in HA ?
To configure the ApexCharts chart so that values less than zero are represented with red bars and values greater than zero are represented with green bars, you need to modify the
plotOptions
section in youroptions
object. Specifically, you should define two separate ranges in thecolors
section within theplotOptions
for thearea
chart type. Here’s how you can modify your existingoptions
object:var options = { // ... your existing options ... plotOptions: { area: { colors: { ranges: [ { from: -Infinity, // Any value less than this will be red to: 0, color: "#e85347" // Red color }, { from: 0, to: Infinity, // Any value greater than this will be green color: "#1ee0ac" // Green color } ] }, columnWidth: "80%" } }, // ... rest of your existing options ... };
In this modified version of your
options
object, theranges
array in thecolors
section of theplotOptions
now defines two ranges:
- Values less than zero will be colored red (
"#e85347"
).- Values greater than or equal to zero will be colored green (
"#1ee0ac"
).With this configuration, the chart bars will be colored according to your specified conditions.
I’m looking to combine the tooltip of my combined chart:
I would like to show both the orange and the blue line in the tooltip but they don’t seem to want to play along. Here’s my code, any ideas?
type: custom:apexcharts-card
graph_span: 24h
header:
show: true
title: Badkamer
show_states: false
colorize_states: true
yaxis:
- id: Vochtigheid
decimals: 0
min: 50
max: 100
apex_config:
title:
text: Luchtvochtigheid %
- id: Temperatuur
opposite: true
min: 15
max: 22
decimals: 0
apex_config:
title:
text: Temperatuur °C
apex_config:
legend:
show: false
tooltip:
shared: true
intersect: false
enabledOnSeries:
- 0
- 1
x:
show: false
format: HH:mm
series:
- entity: sensor.thermometer_badkamer_luchtvochtigheid
stroke_width: 3
show:
legend_value: false
yaxis_id: Vochtigheid
- entity: sensor.thermometer_badkamer_temperatuur
stroke_width: 3
show:
legend_value: false
yaxis_id: Temperatuur
- entity: binary_sensor.raamsensor_badkamer_openen
transform: 'return x === "on" ? 0 : 100;'
type: area
color: grey
opacity: 0.2
stroke_width: 0
curve: stepline
show:
legend_value: false
in_header: false
name_in_header: false
datalabels: false
- entity: sensor.verwarming_overloop_aan
transform: 'return x === "on" ? 100 : 0;'
type: area
color: red
opacity: 0.2
stroke_width: 0
curve: stepline
show:
legend_value: false
in_header: false
datalabels: false
I have a question about the broken yellow line in the apex chart but in the history there is data available. The break in in the green line a a restart of HA.
Code
header:
show: true
title: Kinderzimmer
show_states: true
series:
- entity: sensor.kinderzimmer_raumthermostat_temperature
type: area
color: rgb(76, 175, 80)
stroke_width: 2
opacity: 0.1
- entity: sensor.heizung_kinderzimmer_temperatur_trv
color: rgb(255, 193, 7)
curve: stepline
stroke_width: 2
I´v got a problem with the x-axis.
It is not centered on the columns as seen i
n the picture.
Also there is no text for Thursday (taken last night).
edit: Second image is from today and that looks even worse… no text and no column
Have been trying to fix it but am all out of ides…
- type: custom:apexcharts-card
apex_config:
legend:
show: false
dataLabels:
background:
borderWidth: 0
opacity: 0
foreColor: rgba(228,224,17,1)
#fontFamily: "Roboto"
offsetY: -10
chart:
height: 294px
grid:
show: true
borderColor: rgba(112, 135, 164, 0.5)
xaxis:
labels:
hideOverlappingLabels: false
rotate: -45
rotateAlways: true
showDuplicates: true
datetimeFormatter:
year: 'ddd'
month: 'ddd'
day: 'ddd'
header:
show: true
title: Produktio
show_states: false
hours_12: false
graph_span: 7d
span:
offset: '-1day'
yaxis:
- id: kWh
decimals: 0
opposite: false
apex_config:
tickAmount: 6
# title:
# text: kWh
min: 0
series:
- entity: sensor.daily_yield_total_energy
type: column
unit: kWh
show:
extremas: false
datalabels: true
float_precision: 1
# stroke_width: 2
color: rgba(228,224,17,1)
opacity: 0.7
yaxis_id: kWh
group_by:
duration: 24h
func: max
Your solution I like it very much, but unfortunately the code doesn’t work.
I have successful shift the series for 30 minutes, but have issues with the tooltips.
I don’t know how to troubleshoot it, because my knowledge of Java is very little.
Please help.
I have a simple 24h span bar graph. The xaxis time labels have an interval of 5h. How do I change that to a 4h interval? I tried some apex_config, but till now no result.
My YAML:
graph_span: 24h
header:
title: Nordpool day-ahead vandaag
show: true
span:
start: day
now:
show: true
label: Now
series:
- entity: sensor.nordpool_kwh_nl_eur_3_10_0
type: column
offset: '-30min'
data_generator: |
return entity.attributes.raw_today.map((start, index) => {
return [new Date(start["start"]).getTime(), entity.attributes.raw_today[index]["value"]];
apex_config:
xaxis:
tickAmount: 6
Issue was due to bad state_class on sensor.
It only seems to work with type numeric
apex_config:
xaxis:
type: numeric
tickAmount: 2
hello
I have a little problem. I modify my recorder from 7 days to 3 days of retention.
I have t2 template energy who are statistics
So before the modification i have this graph with 7 days. But now i just have 3 days and today
I add the statistics in the card code but i have this error
/// apexcharts-card version 2.0.4 /// value.series[0] is not a ChartCardSeriesExternalConfig value.series[0].statictics is extraneous value.series[0].statictics is extraneous
My card with error
cache: false
update_interval: 1h
header:
standard_format: true
show: false
title: Consommation HP/HC
show_states: true
span:
end: day
graph_span: 7d
stacked: true
apex_config:
fill:
opacity: 1
type: gradient
gradient:
shade: light
type: horizontal
grid:
show: true
xaxis:
axisBorder:
show: false
axisTicks:
show: false
yaxis:
show: true
series:
- entity: sensor.zlinky_metering_hc
type: column
statictics:
type: sum
period: day
align: end
color: 5A6FE7
opacity: 1
group_by:
duration: 1d
func: diff
show:
datalabels: true
- entity: sensor.zlinky_metering_hp
type: column
statictics:
type: sum
period: day
align: end
color: EA4234
opacity: 1
group_by:
duration: 1d
func: diff
show:
datalabels: true
Can you help me?
Thank’s
I don’t know if it was already asked, but is it possible to place the candlestick charts instead of centered to the value, left- or rightbound?
Like on this example, the first column should be placed like the purple one, the second, like the blue, the third like the orange, etc.
OK, I’m blind, someone just had a similar issue a few posts above and I managed to implement it now with a 30 min offset, however now I have a problem in the header, where it wouldn’t show the current hour price but also a 30 minute offset price.
is it possible to have a different entity in the title (different from the chart entity) ?
Does anyone know if it is possible to sort the entities in a donut chart, based on state ?
Dear community. I am new to Home Assistant and I need help with some questions.
I want the minimum value on the chart to be visible (see screenshot). I.e. the vertical scale should have at least 0.1 margin and not start from the lowest value at the moment. I could use the code:
- id: EUR
decimals: 3
min: 0.1
but in this case the chart does not look nice. It is important to me that the minimum value of -0.1 is used to plot the chart, so that the slag of the minimum value can also be seen.
I was looking for some code ( on chat gpt ) for having different color above and below the x-axis
graph_span: 12
header:
show: true
title: My Chart
series:
- entity: sensor.p1_meter_5c2faf04a1f2_actueel_vermogen
type: area
data_generator: |
(entity, stateObj, attributes, ha) => {
return ha.states[entity].attributes.data.map(entry => entry.value);
apex_config:
fill:
type: gradient
gradient:
shadeIntensity: 1
opacityFrom: 0.7
opacityTo: 0.9
stops: [0, 100]
colors: |
(value, seriesIndex, w) => {
if (value < 0) {
return "#FF0000"; // Red for values below the x-axis
} else {
return "#008000"; // Green for values above or equal to the x-axis
the code isn’t looking that strange, but it is not working. It stays on loading. what is wrong with it ?
Is it possible to get my bar-colors by percent of a sensor-value?
Like 60% of sensor.highprice = orange / 80% of sensor.highprice = red.
Apologies if this has already been answered but I can’t find the answer.
Is it possible to enforce each legend item onto it’s own line. Ie. so the legend does wrap.I want each sensor to have it’s own line.
Also is it possible to order the legend by value? Highest to lowest
Thanks in advance.
I have just found this very cool graphing HA lovelace add on which I am currently using for some Tado thermostat temperature readings.
One question I have is that I am seeing some quite big gaps in the graph where presumably HA did not receive data from Tado for some reason - which in itself is rather strange as I can’t see the same large gaps on the HA built in history graphs.
Is there any way around this. e.g. joining up the gaps etc?
Sorry if this is discussed above but this is a seriously long discussion thread now.
I am struggling with the ‘update_interval’ setting:
Where in my config should i put this setting in the following card:
type: custom:config-template-card
variables:
- states['input_select.hours_to_show_2'].state
entities:
- input_select.hours_to_show_2
- sensor.electricity_meter_power_consumption
- sensor.electricity_meter_power_production
- sensor.electricity_meter_power_production_phase_l1
- sensor.pana_vermogen_kw
card:
apex_config:
chart:
height: 450%
header:
show: true
title: Electra
all_series_config:
stroke_width: 1
graph_span: ${vars[0]}
series:
- entity: sensor.electricity_meter_power_consumption
color: orange
curve: stepline
fill_raw: zero
- entity: sensor.electricity_meter_power_production
color: 76c0f5
curve: stepline
- entity: sensor.electricity_meter_power_production_phase_l1
name: Productie Fase 1
color: green
curve: stepline
- entity: sensor.pana_vermogen_kw
color: f07b73
curve: stepline
yaxis:
- min: 0
max: ~3
decimals: 1
apex_config:
tickAmount: 15
forceNiceScale: true
Is there a way to change the date format on the xaxis from day/month to month/day as is customary in the US?
