Hi!
I want to use a template in the title of a chart, but it doesn´t work.
Is this somehow possible or does anyone have any other ideas?
Best regards,
Michael
Hi!
Best regards,
Michael
Hello – Something happened to column charts with color_thresholds when upgrading from version 2.0.4 to 2.1.0 or above. Each column now has a fixed gray border messing up the intended look:
v2.0.4:
The code for this example:
- type: "custom:apexcharts-card"
graph_span: 1 days
header:
show_states: false
colorize_states: true
span:
start: day
offset: -1day
experimental:
color_threshold: true
series:
- entity: sensor.nordpool_kwh_fi_eur_3_10_024
transform: "return x * 100"
yaxis_id: foo
stroke_width: 4
opacity: 0.8
type: column
unit: "snt/kWh"
time_delta: +1h
group_by:
func: avg
duration: 60min # sample size
color_threshold:
- value: -1
color: 00A000 #green
- value: 8
color: 1E90FF #blue
- value: 16
color: DAA520 #yellow
- value: 24
color: FF0000 #red
apex_config:
yaxis:
- id: foo
min: 0
max: 60
decimalsInFloat: 0
show: true
legend:
show: false
tooltip:
enabled: false
Does anyone know how I can show the header only without the graph? I like the way it shows the temperatures in the different rooms in the header and I can also display the equivalent temperature from 24hrs ago.
Thanks.
Care to explain as this is an odd question for a GRAPH card?
Hi all,
Since an update done a month ago (running now on v2.1.2), my color_threshold that have worked fine for more than a year all look grey.
I didn’t find any breaking change in the update info, did I miss something?
my code:
type: custom:apexcharts-card
apex_config:
chart:
height: 140
stroke:
width: 12
curve: straight
legend:
show: false
yaxis:
decimals: 2
tickAmount: 4
graph_span: 10h
update_interval: 3m
span:
end: hour
experimental:
series:
- entity: sensor.electricity_consumption_15_minutes_net_consumption
transform: return x * 4;
type: column
group_by:
func: last
duration: 15m
color_threshold:
- value: -10
color: SteelBlue
- value: -3
color: CadetBlue
- value: -1
color: LightBlue
- value: 0
color: 99ff99
- value: 1
color: ffce00
- value: 2
color: ff9a00
- value: 3
color: ff5a00
- value: 4
color: ff0000
- value: 5
color: a70000
A quick question
How can I limit (cap) the entry.pv_estimate to 5? So within the data generator, if entry.pv_estimate > 5, entry.pv_estimate = 5?
series:
- entity: sensor.solcast_pv_forecast_forecast_today
color: Grey
opacity: 0.3
stroke_width: 0
type: area
extend_to: false
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
return entity.attributes.detailedForecast.map((entry) => {
return [new Date(entry.period_start), entry.pv_estimate];
Try something like this, I may have made a typo (cannot verify this 100%)
let res = [];
if (entry.pv_estimate > 5) {
res.push ([new Date(entry.period_start), entry.pv_estimate])
else {
res.push ([new Date(entry.period_start), 5])
return res;
Hi everyone,
I am trying to plot a binary_sensor that is currently tracking if 8.8.8.8 can be pinged.
But the plot is extreeeeeeemly slow. On my mobile it won’t even show anything. On my PC is shows the plot after a while.
Given that there are very few data points to this binary_sensor, I was wondering if anybody knows why it is so slow?
view_layout:
grid-area: card01
series:
- entity: binary_sensor.8_8_8_8
transform: 'return x === ''on'' ? 1 : 0;'
yaxis_id: first
color: orange
show:
in_chart: true
in_brush: true
header:
show: true
show_states: true
yaxis:
- id: first
show: true
min: 0
max: 2
decimals: 0
apex_config:
tickAmount: 2
apex_config:
markers:
strokeWidth: 1
fillOpacity: 1
colors: '####'
legend:
show: false
grid:
show: false
position: front
xaxis:
lines:
show: true
yaxis:
lines:
show: true
borderColor: darkgrey
strokeDashArray: 1
row:
colors:
- transparent
- transparent
opacity: 0.1
dropShadow:
enabled: true
color: green
top: 18
left: 7
blur: 100
opacity: 0.5
dataLabels:
enabled: true
all_series_config:
stroke_width: 1
group_by:
func: raw
type: area
opacity: 0.1
curve: stepline
fill_raw: last
show:
extremas: true
datalabels: false
experimental:
brush: true
brush:
selection_span: 2.0d
graph_span: 30.0d
span:
offset: ''
I am using all of these settings on a different plot without the transform, and there is works without any issues. And that one actually has far more data points.
Thank you… no error, but chart not displaying at all with this. Any thoughts?
data_generator: |
let res = [];
if (entry.pv_estimate < 5) {
else {
return res;
No clue … this is what it shows with me
header:
title: Compare forecast@6 with rolling forecast
show: true
graph_span: 1d
span:
start: day
apex_config:
legend:
floating: true
position: top
now:
show: true
series:
- entity: sensor.weather_forecast_hourly_openweathermap
color: green
extend_to: false
data_generator: |
let res = [];
entity.attributes.forecast.map((entry) => {
if (entry.temperature > 26) {
res.push([new Date(entry.datetime), entry.temperature]);}
else { res.push([new Date(entry.datetime), 5]) }
return res
Very interesting… there must be some subtle difference in the forecast data… I am sure you have given me the solution - I just need to figure out why it is not quite doing its thing!
So this works (it uses two return statements):
data_generator: |
And this does not work
data_generator: |
res = [];
return res;
This is essentially the same problem I’m experiencing, see: ApexCharts card - A highly customizable graph card - #3652 by hkapanen
Hi Andrew, how did you configure the donut chart with the temperature lines (server health)? Do you mind to show the config you used? I can’t seem to get it done
Hi !
I’ve to delete and recreate a device within an integration.
But, the name of the entities change : the first ones have english names, and now it’s french names.
So, the graph forget all the past values.
Is there a way to mix the 2 entities on one graph line ?
Thanks.
How do I hide the values above and the legend below the pie/donut? I can’t find any variables in the documentation for them.
Hi, apologies if I’ve missed it but am a bit confused by the code structure and how it’s presented in documentation.
Am trying to implement a dashed line for the second series below. Current code is:
series:
- entity: sensor.study_wetbulb_temperature
name: Wet Bulb Temperature
yaxis_id: temperature
unit: C
curve: smooth
color: rgb(255, 255, 255)
stroke_width: 1
show:
legend_value: false
in_chart: true
extremas: false
- entity: input_number.study_aircon_targettw
name: Target Wet Bulb Temperature
unit: C
curve: stepline
color: rgb(40, 60, 180)
stroke_width: 1
show:
legend_value: true
in_chart: true
extremas: false
I’ve tried adding various entries - ‘strokeDashArray’, ‘stroke_DashArray’, etc but this doesn’t seem to work.
Appreciate any pointers
Is there any method to debug the apexcharts code? Like pull up a log to see where things are falling over?
e.g. stroke_dash : 3
I am not sure why it deviates from the apexcharts doc…
