ApexCharts card - A highly customizable graph card
So you will (!) have to try yourselves and since the data seems to be current, the options to play around are graph_span: and span:, look at the docs
Thanks, I think I got it:
type: custom:apexcharts-card
graph_span: 1d
header:
  show: false
  title: TP110 Server
  show_states: true
  colorize_states: true
yaxis:
  - decimals: 2
series:
  - entity: sensor.tapo_p110_server_current_power
    type: line
    show:
      legend_value: false
      name_in_header: false
      datalabels: false
    stroke_width: 2
    color: rgb(66, 105, 208)
    group_by:
      func: avg
      duration: 30min
    type: area
    stroke_width: 1
    color: rgb(37, 48, 72)
    group_by:
      func: min
      duration: 30min
    type: area
    stroke_width: 1
    group_by:
      func: max
      duration: 30min
    data_generator: ""
Just need to figure out now how to hide the legend and add more space bellow, aka min value + n
I now see (visually) what you meant…the area min/max … :slight_smile: For the rest…plenty of entries on formatting things in this very long thread/post
@vingerha
How did you get the column transparency over a color-filled area ? No way to me using opacity…Can you share your config of this chart ?
c5a71b6f38b84de794690cd530c69e647afecf6e
Without seeing your code, I assume uit is the experimental one
header:
  title: Temp
  show: true
  floating: false
  show_states: true
graph_span: 6d
experimental:
  color_threshold: true
span:
  start: day
apex_config:
  legend:
    show: true
  title:
    floating: true
    align: center
    style:
      fontSize: 20px
      fontWeight: bold
  datalables:
    enabled: true
    formatter: |
      EVAL:function (val) {
        return "£" + val.toFixed(0);
    offsetY: -10
    background:
      enabled: false
    style:
      colors:
        - var(--primary-text-color)
      fontSize: 16px
      fontWeight: bold
  plotOptions:
    bar:
      labels:
        show: true
      borderRadius: 5
      dataLabels:
        position: center
        enabled: true
series:
  - entity: sensor.weather_forecast_daily_accuweather
    show:
      in_header: false
    offset: +6h
    type: column
    opacity: 0.3
    stroke_width: 2
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
            return [new Date(entry.datetime), entry.temperature];
    color_threshold:
      - value: 5
        color: blue
        opacity: 0.4
      - value: 10
        color: cyan
        opacity: 0.2
      - value: 12
        opacity: 0.2
        color: green
      - value: 23
        color: orange
  - entity: sensor.weather_forecast_daily_mouans_sartoux
    stroke_width: 2
    data_generator: |
  - entity: sensor.weather_forecast_daily_openweathermap
    offset: +11h
    show:
      offset_in_name: false
    stroke_width: 2
    type: area
    data_generator: |
    color_threshold:
      - value: 10
        color: blue
        opacity: 0.4
      - value: 12
        color: yellow
        opacity: 0.1
      - value: 14
        opacity: 0.2
        color: red
      - value: 24
        color: green
Atleast it did display data but it looks like only 1 record its like it didnt loop the each month of data
The data is old, the card is trying to show the last value only, you need to apply offset / graph_span
@vingerha
You’re right, I’ll try to expose my issue and show my code:
i create a template sensor with historical stats platform that show time per day in % my floor heating is on.
In apex chart i add to this sensor outside temp sensor.
Here is my code:
experimental:
apex_config:
  chart:
    height: 470px
  grid:
    show: true
    strokeDashArray: 2
    borderColor: black
    position: front
    xaxis:
      lines:
        show: true
    yaxis:
      lines:
        show: true
graph_span: 6d
span:
  end: day
show:
  last_updated: true
header:
  show: true
  show_states: true
yaxis:
  - id: first
    min: 0
    max: 100
    decimals: 0
    apex_config:
      tickAmount: 4
  - id: second
    min: 0
    max: ~30
    opposite: true
    decimals: 1
    apex_config:
      tickAmount: 4
series:
  - entity: sensor.riscaldamento_on_day
    yaxis_id: first
    show:
      header_color_threshold: true
      datalabels: true
    stroke_width: 15
    type: column
    color: red
    opacity: 0.4
    name: Riscaldamento Acceso in % per Giorno
    group_by:
      func: last
      duration: 1 day
  - entity: sensor.outside_temperature
    yaxis_id: second
    stroke_width: 1
    curve: smooth
    opacity: 0.7
    color_threshold:
      - value: -4
        color: blue
      - value: 0
        color: cyan
      - value: 2
        color: green
      - value: 4
        color: yellow
      - value: 6
        color: orange
      - value: 8
        color: red
    show:
      extremas: true
    type: area
    fill_raw: last
card_mod:
  style: |
    ha-card {
      background: #EFDECD;
      box-shadow: none;
      --primary-text-color: black;
The chart works well but the columns cover area and i tried many solutions without success. It’s not a problem related to experimental color threshold cause this issue also appears with ‘normal’ color filled area.
Curiosly, if i transdorm the type area in a line:
you can see columns doesn’t cover the line and opacity for it works while for columns doesn’t.
When I saw your graph I wondered how you did it but maybe I did something wrong, however it’s curious.
Thanks anyway for your support
tbh I never looked at this detail but it is ‘odd’ (is it?). I played around a bit and when I put the group_by also on the other entity then it works with me
Have you tried these options?
            apex_config:
              fill:
                type: gradient
                gradient:
                  type: vertical
                  shadeIntensity: 0
                  opacityFrom: 1
                  opacityTo: 0.5
                  stops: 10
ENERGY COST ESTIMATE GRAPH
Hey guys, I got my Energy bill.
Yeah
Now I would love to have a Graph spanning over a year showing each month and the past and current Energy Consumtion in kWh.
And also a indicator / bar showing the “average” Energy Consumtion what my Contract is based on.
I got a imput number helper with the estimated yearly consumtion - lets say 6000 kWh.
So the imput number shall be devided by the graph span there should be a line showing the “estimated consumption” for that timeframe.
If need 6000kWh per year and the graph span is 12 month then its 500 kWh per Month.
if the Graph span is 7 days. then it is 115kWh per Day.
Any Idea how I could do it?
Wrapping it in custom config template card (hacs) you can use ‘templates’ for the individual settings
The card cannot guess the span so this will have to be a template too
For the display of the value, you can fake this by using any entity and just put transform in it, example below.
The example value ‘13’ you would then replace by a template from your helper-sensor
I am trying to monitor my heating system. I am tracking ‘heating degree days’ and the hours my heating run.
Now I would like to bring them into a ratio to make different weeks comparable with each other.
How can I create an additional serious/line to show the result of the following calculation?
(sum of sensor.living_room_heating_hours_today_total_increasing, sensor.office_heating_hours_today_total_increasing, sensor.bedroom_heating_hours_today_total_increasing)
divided by
sensor.heating_degree_days
Any help would be welcome!
My current code is:
experimental:
  brush: true
header:
  show: true
  title: ApexCharts-Card
  show_states: true
graph_span: 90day
span:
  end: day
stacked: true
yaxis:
  - id: first
    decimals: 0
    min: 0
    max: 150
  - id: second
    opposite: true
    min: 0
    decimals: 0
  - id: third
    opposite: true
    min: 0
  - id: fourth
    opposite: false
    min: 0
    decimals: 0
    max: 140
series:
  - entity: sensor.heating_degree_days
    type: line
    yaxis_id: second
    group_by:
      duration: 7 days
    statistics:
      type: change
      period: week
      align: end
    stack_group: b
  - entity: sensor.living_room_heating_hours_today_total_increasing
    type: column
    yaxis_id: first
    group_by:
      duration: 7day
    statistics:
      type: change
      period: week
      align: end
    show:
      datalabels: false
    stack_group: a
  - entity: sensor.office_heating_hours_today_total_increasing
    type: column
    yaxis_id: first
    group_by:
      duration: 7day
    statistics:
      type: change
      period: week
      align: end
    show:
      datalabels: false
    stack_group: a
  - entity: sensor.bedroom_heating_hours_today_total_increasing
    type: column
    yaxis_id: first
    group_by:
      duration: 7day
    statistics:
      type: change
      period: week
      align: end
    show:
      datalabels: false
    stack_group: a
  - entity: sensor.living_room_temperature
    type: line
    yaxis_id: fourth
    show:
      datalabels: false
    statistics:
      type: mean
      period: week
      align: end
  - entity: sensor.office_temperature
    type: line
    yaxis_id: fourth
    show:
      datalabels: false
    statistics:
      type: mean
      period: week
      align: end
  - entity: sensor.master_bedroom_temperature_2
    type: line
    yaxis_id: fourth
    show:
      datalabels: false
    statistics:
      type: mean
      period: week
      align: end
Not… you would have to create a template sensor for that
Thank you @vingerha. Follow up question. If I create such a template sensor, I would only solve it for the future. I can’t do the calculation for the past, right?
Or is there any trick to do this for past data?
Indeed, that is the case, and for the future you should also setup the template-sensor to be taken into account of statistics, using proper device_class
EDIT: theoretically you can reconstruct the historical data in the db but then you need to know how to do this and quite often the moments of measured data are not equal, i.e. it will be tricky to sum sensor1 with time 15:00:00 with sensor 2 15:01:00
Thanks @vingerha. Not exactly what I was hoping to hear.
I also used AI (Google Gemini) to query that question. It proposes to use the data_generator.
However, it is showing an error, that an entity is missing.
Any thoughts to bypass the need of having an entity?
/// apexcharts-card version 2.1.2 /// value.series[7] is not a ChartCardSeriesExternalConfig; value.series[7].entity is missing
- type: line
  yaxis_id: third
  data_generator: |
    const heatingHoursLivingRoom = entity.series[1].data;
    const heatingHoursOffice = entity.series[2].data;
    const heatingHoursBedroom = entity.series[3].data;
    const degreeDays = entity.series[0].data;
    const result = heatingHoursLivingRoom.map((livingRoomHours, index) => {
      const totalHeatingHours = livingRoomHours + heatingHoursOffice[index] + heatingHoursBedroom[index];
      if (degreeDays[index] === 0) {
        return 0;
      return totalHeatingHours / degreeDays[index];
    return result;
AI is in most cases of 0 value, it will cost more time to analyse what is missing and I am not going to analyse that. Search for other entries in this very-long post, I remain pretty sure that it is not possible.
After one hour of scrolling now i’m feeling less alone
As I already answered to ttmetro… search for “full width” and then you find a.o. my link
ApexCharts card - A highly customizable graph card - Share your Projects! / Dashboards & Frontend - Home Assistant Community
