ApexCharts card - A highly customizable graph card
hi is it possible to remove the marked area in a radiabar figure?
have you tried setting the legend to false?
apex_config:
  legend:
    show: false
thanks. it works
I’m not sure I understand the question?
I guess they want a graph that starts at Jan 1st and ends at Dec 31st.
I guess in this case what you want @skank is:
span:
  start: year
(not sure also why you have an offset, the timezone is automatically calculated)
Yes,
But when i think of it , its normal cause it shows 12 months
So latest is always the current one
Thank you !
Lovely card by the way !
edit: its more narrow now, i liked it before where i have the number for each month, but in the order like below
That’s because your group_by 31 days times 12 is superior to 365 days and the slices of time for the group by are always built from the end of the chart.
Hi, great work! Very nice card! I’m going to replace all my mini graphs with this.
I have a question. Is it possible to change the unit of measurement? It doesn’t take the sensor unit (TB) but replace it with %
Cattura
Not so far, see here
Ok thanks, Hopefully this will be supported with the upcoming changes
Is there a way to ignore certain values from the charts? Sometimes due to connection dropping to certain devices, it causes the sensor to record a spike.
You could use transform to get rid of those values.
Thx @RomRider . I tried this
transform: "return x === 100 ? null: x;"
But it doesn’t seem to work.
What is your full configuration?
Here you go.
- type: custom:apexcharts-card
  apex_config:
    yaxis:
      - title:
          text: Temperature
        decimalsInFloat: 0
        min: 40
        tickAmount: 6
  all_series_config:
    extend_to_end: false
    stroke_width: 2.5
    show:
      legend_value: false
  color_list: ['MediumOrchid','Coral','MediumAquamarine','DodgerBlue','SaddleBrown']
  graph_span: 1d
  y_axis_precision: 0
  series:
    - entity: sensor.outside_temp
    - entity: sensor.ble_temp_kitchen
    - entity: sensor.temp_bedroom
    - entity: sensor.temp_rumpus
Could you try return parseFloat(x) === 100 ? null : x;
If it works it means your sensor stores its state as a string, not as a number.
Thx. It worked!
I’m looking for feedback on displaying extremas: https://github.com/RomRider/apexcharts-card/issues/43
With the proposed solution https://github.com/RomRider/apexcharts-card/issues/43#issuecomment-778840160
Feel free to comment on the issue :slightly_smiling_face: thanks folks!
