ApexCharts card - A highly customizable graph card
Is that sarcasm?
Thank you! It’s it a bug that float_precision: 1 doesn’t change “1” to “1.0”?
No it’s intended :blush:
Alright, too bad :wink: Can I use transform to force it to float maybe?
Of course not. I need to change the font size - and I feel somewhat stupid that I’m unable to figure out how to accomplish such an obvious and simple task… So, please tell me how?
You use card-mod. And you won’t have to scroll far up in this post to find a partially hijacked discussion on the same question
Thank you :blush:
It never occurred to me to search this thread for “card-mod”, and it beats me why this CSS mod only seems to work when added to the very end of the YAML.
But - now it works, so again; Thank you :+1:
Is it possible to call a service by tapping (clicking) on the card? I’m thinking about using tap_action to open a popup window to see the chart in a larger view. Thank you.
Not yet. I don’t really know to what part of the card I should assign the action to since everything is already interactive in the chart. If you have an idea, feel free to share it.
Does anyone have an example of adding an annotation? I have tried the following to add a y axis line but no graph is displayed at all.
type: 'custom:apexcharts-card'
series:
  - entity: sensor.octopus_agile_current_rate
apex_config:
  annotations:
    yaxis:
      'y': 13
      borderColor: '#00E396'
      label:
        text: Test
The graph-wrapper is interactive, but a click on the header is possible if it’s shown. Another possibility would be to create a “tap-zone” right on the bottom of the card below the legend.
If
show:
  tap_zone: true
then the tap-zone is visible and it’s possible to assign the action to it.
Example
Bad idea?
Another weirdiness. or again I’m doing something wrong :slight_smile:
I’m stacking 3 series using vertical stack in card to show in one cgart up/download speed and and in second card latency:
Screenshot 2021-02-20 at 6.44.54
Both charts use exaclty the same configuration (exception upper one uses 2 series and is higher), but on the bottom chart I can’t get legend to display. here is exact code I use:
type: 'custom:vertical-stack-in-card'
cards:
  - type: 'custom:text-divider-row'
    text: WAN Throughput
  - type: 'custom:apexcharts-card'
    show:
      loading: false
    apex_config:
      stroke:
        width: 2
      chart:
        height: 200
      fill:
        type: solid
      plotOptions:
        bar:
          columnWidth: 90%
      header:
        show: false
      grid:
        show: true
        borderColor: '#222222'
        strokeDashArray: 0
        position: front
    graph_span: 5min
    series:
      - entity: sensor.internet_speed_in1
        color: var(--darkblue1)
        type: column
      - entity: sensor.internet_speed_out1
        color: var(--red3)
        type: column
        invert: true
    text: WAN Latency
    update_delay: 500ms
    show:
      loading: false
    apex_config:
      stroke:
        width: 2
      chart:
        height: 100
      fill:
        type: solid
      plotOptions:
        bar:
          columnWidth: 90%
      header:
        show: false
      grid:
        show: true
        strokeDashArray: 0
        position: front
    graph_span: 5min
    series:
      - entity: binary_sensor.default_gateway
        attribute: round_trip_time_avg
        color: var(--red3)
        type: column
        unit: ms
I managed to hide legen in upper graph using apex_config: > legend: > show: hfalse, but not the other way around…
Bonus question; is there any possibility to display down/upload bars aligned? Currently these are altrnated on x-axis (e.g wherever there is column up, there is a break between columns going down). It is normal and expected, as I’m using it in somehow non-standard way, but perhaps there is some hidden parameter to change this? Maybe this could work for stacked columns charts… one day it is supported? So something like on picture below, but columns instead of bars:
Screenshot 2021-02-20 at 7.19.07
Bonus question 2: Is there any way to control density of y-axis grid? On ApexCharts page there are few options documented related to formatting appearance of grid, but I found nothing about formatting density…
By default, the legend is only displayed if the number of series is > 1.
So:
apex_config
  legend:
    showForSingleSeries: true
Yes, that’s how the ApexCharts library works.
You can try stacked: true and see if that helps (it might or might not :slight_smile: )
You should increase/decrease the number of ticks on the y-axis. The grid is aligned with the number of ticks.
I see that this option : hours_12 is Deprecated
how can you config that you get 24h view of hours?
Because the times are shown as AM/PM
It is now based on your home-assistant locale. But I’ll reintroduce the feature to force 12/24h display on top of the locale support.
Negative Values on Y-axis…
test
Anyone know if it is possible to hide/remove the “-” on yaxis negative values? I’m trying to copy a unifi controller throughput graph. The purple is download but it isn’t obviously negative (used invert: true to flip it on the chart). Ideal would be yaxis to show 30 --> 10 --> 10 -->30. I don’t think its possible after reading the apex docs but hoping I’m wrong. Thanks in advance
That is not possible for the y-axis, however I’ll change the tooltip/legend display to not show negative values in the next release if invert is set to true
Thanks. Appreciate all your efforts on this and your other cards
Interesting… I also love unifi interface and just started to gradually convert my config to resemble their look. So far I created new theme that takes their color scheme and started to create dashboard for my LAN. Obviously using Apex Chart for graphing :slight_smile: Here is the outcome so far:
Yet long way to go, lots of polishing, but without Apex would not be possible to get close enough.
Hi!
Thank you for a really good card.
I’m using it for so many graphs that the Core i7 CPU works on 100% when starting up the system :slight_smile:
But I don’t get my color_treshold card right. The colors seam to stretch differently depending of the value.
Is this a bug, or am I doing something wrong here?
