ApexCharts card - A highly customizable graph card
Cool chart with the blocks! I understand you have created the “block” effect by having the y axis lines on top of the chart?
@RomRider > Can this effect be achieved without grid lines? I have a sensor that gives value between 0-6,5 with 0,5 steps so this block look would make it super easy to see the current value.
Yes, exactly! I put the grid lines on top (apex_config: grid: position: front) and made them very dense (apex_config: yaxis: tickAmount: 12). Drawback is that also y-axis descriptions get very dense :slight_smile:
Thank you!!
hi, if it wouldn’t be too much trouble, could you share the view you’re showing here? I’m really interested in finding out how you got the 4 little buttons on the left hand side, (are they buttons?) and, how the top horizontal set of sensors aligns with that…
thanks if you would!
Sure thing, here you go:
    card:
      type: vertical-stack
      style: |
        ha-card {
          border-radius: 12px;
          background: none;
      cards:
        - type: 'custom:button-card'
          color_type: blank-card
          styles:
            card:
              - height: 10px
        - type: horizontal-stack
          cards:
              styles:
                card:
                  - width: 10px
            - type: custom:layout-card
              layout: horizontal
              column_width: [18%, 82%]
              cards:
                - type: vertical-stack
                  cards:
                    - type: "custom:button-card"
                      styles:
                        card:
                          - border-radius: 12px
                          - color: 'var(--primary-background-color)'
                          - font-size: 14px
                        name:
    #                      - padding-right: 20px
                          - color: var(--primary-text-color)
                      color_type: icon
                      color: 'var(--primary-color)'
                      show_icon: true
                      icon: mdi:restart
#                      layout: icon_name
                      aspect_ratio: 1/1
                      show_name: false
                      show_state: false
                      haptic: success
                      tap_action:
                        action: call-service
                        service: homeassistant.restart
                      confirmation:
                        text: 'Are you sure you want to restart Home Assistant?'
                      styles:
                        card:
                          - font-size: 14px
                        name:
                      color_type: icon
                      show_icon: true
                      icon: mdi:compare
#                      layout: icon_name
                      aspect_ratio: 1/1
                      show_name: false
                      show_state: false
                      haptic: success
                      tap_action:
                        service: input_select.select_next
                        service_data:
                          entity_id: input_select.theme
                      styles:
                        card:
                          - font-size: 14px
                        name:
                      color_type: icon
                      show_icon: true
                      icon: mdi:apple
#                      layout: icon_name
                      aspect_ratio: 1/1
                      show_name: false
                      show_state: false
                      haptic: success
                      tap_action:
                        service: homekit.start
                      confirmation:
                        text: 'Are you sure you want to start HomeKit?'
                      styles:
                        card:
                          - font-size: 14px
                        name:
                      color_type: icon
                      show_icon: true
#                      layout: icon_name
                      aspect_ratio: 1/1
                      icon: mdi:google-assistant
                      show_name: false
                      show_state: false
                      haptic: success
                      tap_action:
                        service: google_assistant.request_sync
                      confirmation:
                        text: 'Are you sure you want to sync Google Assistant?'
                - type: custom:apexcharts-card
                  chart_type: radialBar
                  header:
                    show: true
                    floating: false
                    show_states: true
                    colorize_states: true
                  apex_config:
                    title:
                      floating: false
                      align: center
                      style:
                        fontSize: 12px
                        fontWeight: bold
                    chart:
        #              fontFamily: "Julius Sans One"
                      foreColor: rgb(148,148,148)
                      offsetY: 5
                    legend:
                      show: false
                      position: top
                  series:
                    - entity: sensor.disk_use_percent_home
                      color: var(--primary-color)
                    - entity: sensor.processor_use
                      color: var(--light-primary-color)
                    - entity: sensor.memory_use_percent
                  style: |
                        ha-card {
                          background-color: transparent;
                          box-shadow: none;
                          font-size: 12px;
I received yesterday my Aqara temp. sensors and want to add them to ha dashboard.
I dont know which is the best view (have 11 sensors with temp, pressure and humidity)…
But I recognize that there is a display error with the temps:
The overview shows the correct temperature, the graph didnt…
Is this error known?
Maybe some of you have a good idea how I can create a beatiful overview of the temperature…
We can’t help if you don’t share your card configuration…
sry, think I posted the screenshot and the code…
  - title: Temp
    path: temp
    icon: 'hass:thermometer'
    badges: []
    cards:
      - type: entities
        entities:
          - entity: sensor.temp_bad_temperature
          - entity: sensor.temp_balkon_temperature
          - entity: sensor.temp_buero1_temperature
          - entity: sensor.temp_buero2_temperature
          - entity: sensor.temp_esszimmer_temperature
          - entity: sensor.temp_flur_temperature
          - entity: sensor.temp_kueche_temperature
          - entity: sensor.temp_schlafzimmer_temperature
          - entity: sensor.temp_skylounge_temperature
          - entity: sensor.temp_wc_temperature
          - entity: sensor.temp_wohnzimmer_temperature
        title: Temperaturen
      - type: 'custom:apexcharts-card'
        header:
          show: true
          title: Bad
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const now = new Date();
              const data = [];
              for(let i = 0; i <= 24; i++) {
                data.push([now.getTime() - i * 1000 * 60 * 60, Math.floor((Math.random() * 10) + 1)])
              return data.reverse();
        header:
          show: true
          title: Balkon
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Büro1
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Büro2
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Esszimmer
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Flur
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Küche
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Schlafzimmer
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Skylounge
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: WC
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
        header:
          show: true
          title: Wohnzimmer
          show_states: true
        series:
            data_generator: |
              // REMOVE ME
              const data = [];
This is the code of the separate dashboard
It’s pretty explicit, it says REMOVE ME in capital letters :slight_smile:
So remove all the data_generator and you’ll be fine.
dont laugh…
but I tried this in the first step and it doesnt work, the graph is empty and temp. is n/a
        header:
          show: true
          title: Balkon
          show_states: true
        series:
I tested it with and w/o
 data_generator: |
thanks! will check it out for sure.
Then it’s because you don’t have the recorder enabled/your entities are excluded from the recorder.
how can I set this?
Or still find out, if the sensor can do this?
It’s the xiaomi sensor wsdcgq11lm
Here: https://www.home-assistant.io/integrations/recorder/
Damn it, okay thats not quite simply as I though.
Have to fix this issue tonight…
Thanks!
It’s not complex, just enable the recorder in your configuration.yaml file and you are good to go:
recorder:
yes, I tried this.
But the file from record is still empty
in my config.yaml I added recorder:
Did you restart your instance?
yes, multiple times and tried both codes…
Think this can be probably the problem…
