bgrr
(bgrr)
March 20, 2021, 11:50pm
786
I was still looking to see if the unchanged data is stored in de DB and your already 10 steps ahead hahaha
My yaml code of the sensor should make sure it’s stored in the DB even if it doesn’t change by using the force_update option.
- platform: mqtt
state_topic: "tele/energy_power/SENSOR"
unit_of_measurement: "W"
icon: mdi:home
force_update: true
If i pull the history of this sensor in node red it give an entry per minute. Even if it doesn’t change.
3/21/2021, 12:44:22 AMnode: 344ba799.de60a8
msg.payload : Object
{ entity_id: "sensor.energy_power", state: "3", attributes: object, last_changed: "2021-03-20T23:27:45.223263+00:…", last_updated: "2021-03-20T23:27:45.223263+00:…" }
{ entity_id: "sensor.energy_power", state: "3", attributes: object, last_changed: "2021-03-20T23:28:45.076861+00:…", last_updated: "2021-03-20T23:28:45.076861+00:…" }
{ entity_id: "sensor.energy_power", state: "2.5", attributes: object, last_changed: "2021-03-20T23:29:45.201822+00:…", last_updated: "2021-03-20T23:29:45.201822+00:…" }
{ entity_id: "sensor.energy_power", state: "2.5", attributes: object, last_changed: "2021-03-20T23:30:45.025889+00:…", last_updated: "2021-03-20T23:30:45.025889+00:…" }
3/21/2021, 12:44:23 AMnode: 344ba799.de60a8
{ entity_id: "sensor.energy_power", state: "2.5", attributes: object, last_changed: "2021-03-20T23:31:45.151167+00:…", last_updated: "2021-03-20T23:31:45.151167+00:…" }
{ entity_id: "sensor.energy_power", state: "2.5", attributes: object, last_changed: "2021-03-20T23:32:45.160869+00:…", last_updated: "2021-03-20T23:32:45.160869+00:…" }```
Airyphyla
(Airyphyla)
March 21, 2021, 9:26am
787
Hi there, i really like this chart! Would you mind sharing this with me?
CDRX2
(CDRX2)
March 21, 2021, 9:39am
788
Sure! It’s based off an Openweathermap weather entity which is configured as onecall-daily.
- type: 'custom:apexcharts-card'
graph_span: 7d12h
span:
start: day
offset: +12h
apex_config:
dataLabels:
enabled: false
chart:
height: 270%
legend:
position: 'top'
stroke:
colors: ['#ffa31a', '#03a8f4', 'none']
fill:
type: ['gradient', 'gradient', 'solid']
gradient:
type: 'vertical'
shade: 'dark'
inverseColors: true
opacityFrom: 0.8
opacityTo: 0.1
stops: [20, 100]
opacity: 0.85
plotOptions:
area:
fillTo: 'origin'
bar:
columnWidth: '150%'
series:
- entity: weather.openweathermap
type: area
curve: smooth
color: '#ffa31a'
extend_to_end: true
fill_raw: last
show:
legend_value: false
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime), entry.temperature];
type: area
curve: smooth
extend_to_end: true
color: '#03a8f4'
fill_raw: last
show:
legend_value: false
data_generator: |
return [new Date(entry.datetime), entry.templow];
type: column
color: '#0b0385'
fill_raw: last
show:
legend_value: false
data_generator: |
return [new Date(entry.datetime), entry.precipitation];
card_mod:
style: |
:host {
left: 50%;
top: 72.5%;
width: 90% !important;
ha-card {
background: none !important;
Viking:
Sure, here it is:
Here you go:
type: custom:apexcharts-card
graph_span: 6d
span:
start: hour
offset: '-36h'
header:
show: true
title: Temperature Forecast
show_states: true
now:
show: true
label: now
apex_config:
legend:
show: false
series:
unit: °C
attribute: temperature
fill_raw: last
extend_to_end: false
group_by:
func: avg
duration: 2h
type: line
unit: °C
show:
in_header: false
data_generator: |
const res = entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.temperature];
return [[new Date().getTime(), parseFloat(entity.attributes.temperature)], ...res]
It should be fixed in the latest beta , please report back
Viking
March 21, 2021, 11:00am
790
@RomRider , you lost me, but “I’m here”
now it looks like this:
This is much better, but I wish I could understand how you build such syntax. Especially the “…res”
What on earth does that mean?
bgrr
(bgrr)
March 21, 2021, 8:15pm
792
I spent embarassingly long trouble shooting the HACS installation method “Not Loading”. I should have known better that it would be the resources path via .yaml file.
Here’s what worked for me in case anyone else stumbles:
resources:
- url: /hacsfiles/apexcharts-card/apexcharts-card.js
type: module
bochelork
(Bochelork)
March 22, 2021, 11:12am
794
Thanks @RomRider for these charts, I really missed these customizable charts. I have a quick question, for displaying my crypto wallets. I like to transform my values in each series, by subtracting the first value from the actual value. Something like this:
transform: "return x-first;"
Can you help me with the right formula?
That’s not possible but what is your use case?
bochelork
(Bochelork)
March 22, 2021, 11:29am
796
I’m trying to find a clear way to display my different crypto wallets in one view. Since some of my wallets are bigger and others are smaller I would like to start each series at ‘0’ and show relative values, so difference between timestap 0 and timestamp x.
arifroni
(Arif Roni)
March 22, 2021, 7:57pm
797
I want to make the heating curve filled 100% but without the line…only the filling will stay. how can i do that?
header:
title: Bedroom
show: true
show_states: true
colorize_states: true
update_interval: 10m
graph_span: 1d
apex_config:
tooltip:
enabled: true
yaxis:
- show: true
decimalsInFloat: 0
min: 18
labels:
style:
colors: '#FFB62E'
fontSize: 12px
fontWeight: bold
forceNiceScale: true
- show: true
opposite: true
decimalsInFloat: 0
min: 0
max: 99
labels:
style:
colors: '#FFB62E'
fontSize: 12px
fontWeight: bold
- show: false
opposite: true
decimalsInFloat: 0
min: 18
labels:
style:
colors: '#FFB62E'
fontSize: 12px
fontWeight: bold
xaxis:
axisBorder:
show: false
labels:
style:
fontSize: 14px
chart:
height: 250px
grid:
show: false
legend:
show: false
fontSize: 12px
height: 40
dataLabels:
enabled: false
stroke:
width: 3
curve: smooth
# fill:
# type: gradient
# gradient:
# type: vertical
# shadeIntensity: 0.8
# inverseColors: false
# opacityFrom: 0.5
# opacityTo: 0
# stops:
# - [0, 50, 100]
series:
- entity: sensor.bedroom_temperature
type: line
# opacity: 0
fill_raw: last
float_precision: 1
group_by:
duration: 10m
func: avg
- entity: sensor.bedroom_heating
type: area
color: grey
fill_raw: last
float_precision: 0
opacity: 0.2
group_by:
duration: 10m
func: avg
- entity: sensor.target_temp_bedroom
type: line
# opacity: 0
fill_raw: last
float_precision: 1
group_by:
duration: 10m
func: avg
At the moment it looks like this
I want to make this look somewhat like this.
how to use different fill properties for different lines?
interesting observation: if i use secondary y aaxis limit max=100, it sets to 120, but with 99 it sets to 100!!!
formicro
(Formicro)
March 23, 2021, 12:09am
798
In reference to Frank question there :
https://community.home-assistant.io/t/apexcharts-card-a-highly-customizable-graph-card/272877/296?u=formicro
graph_span: 24h
cache: true
span:
start: day
chart_type: donut
apex_config:
plotOptions:
pie:
donut:
total:
show: true
showAlways: true
formatter: null
Is it possible to display a sensor value, right in the center of a donut ?
Thanks for suggestions, regards, Thomas.
lless
(lless)
March 23, 2021, 6:02am
799
Now, i have 2 elements with current value: legend and header. Header looks better, but him not have function hide series. I try hide header and up legend, but him looks bad. How i may add click function to header or make a legend view like header
markcocker
(Mark Cocker)
March 23, 2021, 3:54pm
800
The line can be removed by setting stroke_width=0
For example for a binary sensor:
- entity: binary_sensor.night
curve: stepline
opacity: 0.2
stroke_width: 0
show:
in_header: false
transform: 'return x === ''on'' ? 1 : 0;'
markcocker
(Mark Cocker)
March 23, 2021, 4:17pm
801
Is there a mechanism to create an axis annotation at a timestamp contained in a sensor? From what I’ve read above Jinja templates are not supported.
In my case X axis annotations for sunrise and sunset, eg:
apex_config:
annotations:
xaxis:
- x: states.sensor.sunrise
label:
text: Sunrise
You can use config-template-card to build that for now
markcocker
(Mark Cocker)
March 24, 2021, 9:59am
803
Thanks for the hint. Works great…
Card config
type: 'custom:config-template-card'
entities:
- sensor.sunrise
- sensor.sunset
- sensor.zappi_generation
- sensor.harvi
card:
header:
show: true
show_states: true
title: Solar generation
span:
start: day
graph_span: 24h
all_series_config:
stroke_width: 2
type: area
float_precision: 0
color_list:
- yellow
- yellow
- green
- grey
series:
- entity: sensor.zappi_generation
name: Solar on house
group_by:
func: avg
duration: 20min
offset: '-24h'
type: line
opacity: 0.2
group_by:
func: avg
duration: 20min
show:
in_header: false
- entity: sensor.harvi
name: Solar on shed
group_by:
func: avg
duration: 20min
y_axis_precision: 0
apex_config:
annotations:
xaxis:
- x: '${new Date(states[''sensor.sunrise''].state).getTime()}'
label:
text: ☼
borderWidth: 0
style:
background: '#0000'
- x: '${new Date(states[''sensor.sunset''].state).getTime()}'
label:
text: ☾
borderWidth: 0
style:
background: '#0000'
yaxis:
- seriesName: Solar on house
decimalsInFloat: 0
show: false
- seriesName: Solar on shed
show: false
- seriesName: Night time
opposite: true
show: false
tooltip:
x:
format: 'ddd dd MMM - HH:mm'
xaxis:
tooltip:
enabled: false
legend:
show: false
grid:
borderColor: '#7B7B7B'
chart:
foreColor: '#7B7B7B'
zoom:
type: x
enabled: true
autoScaleYaxis: true
toolbar:
show: true
autoSelected: zoom
tools:
zoom: true
zoomin: false
zoomout: false
pan: false
reset: true
Any ideas why the x - axis hides the dates with a column graph? …changing the graph to line type seems to kind of work, but still it is not displaying all the 7 days.
