Thanks!
I was not attentive.
Haven’t started using the card, just testing it sometimes.
Now I wonder how it processes unavailable data.
Here are two simple sensors:
- Equal to some
input_number, is available if someinput_boolean=on. - Equal to the 1st sensor * 2, is available if that 1st sensor is available.
sensors:
test_availability:
unit_of_measurement: "unit"
icon_template: mdi:account
value_template: >-
{{ states("input_number.test_number") }}
availability_template: >-
{{ is_state("input_boolean.test_boolean","on") }}
test_availability_2:
icon_template: mdi:car
value_template: >-
{% set VALUE = states("sensor.test_availability") -%}
{%- if is_number(VALUE) -%}
{{ VALUE | float * 2 }}
{%- else -%}
{{ 0 }}
{%- endif %}
{{ not states("sensor.test_availability") in ["unavailable","unknown"] }}
Now let’s see graphs for these sensors:
- type: entities
entities:
- entity: input_boolean.test_boolean
- entity: input_number.test_number
- type: divider
- entity: sensor.test_availability
- entity: sensor.test_availability_2
- type: vertical-stack
cards:
- type: custom:mini-graph-card
entities:
show_points: true
show_points: true
lower_bound: 0
points_per_hour: 60
hours_to_show: 1
average_func: last
update_interval: 0
line_width: 1
smoothing: false
cache: false
- type: history-graph
entities:
hours_to_show: 1
refresh_interval: 0
- type: custom:apexcharts-card
series:
curve: stepline
stroke_width: 1
fill_raw: 'null'
curve: stepline
stroke_width: 1
fill_raw: 'null'
graph_span: 1h
cache: false
now:
show: true
There are 3 graphs:
- based on
mini-graph-card; - based on stock
history-graph; - based on
apexcharts-card.
Play with the input_number value & the input_boolean value.
Note that:
- The
mini-graph-cardshows no gap forunavailabledata (sad but true - and this will not be rectified unfortunately). - The stock
history-graphshows gaps when sensors areunavailable(great!!!). - The
apexcharts-cardshows gaps - but in a strange manner:
it shows a gap when the data are unavailable, then shows a curve otherwise:
then again shows a gap - even for the time when the data were available:
Is it a bug? Or am I missing smth?
Hi @ all,
how i can change the font Size of the "Status Display?
5 Sensors are for this size to much, i want a display without a Linebreak.
best reguards
Faruk
Just discovered this card
LINES NETWORK
Convert kB/s and MB/s with custom legend
yaml
layout: minimal
graph_span: 1h
apex_config:
tooltip:
style:
fontSize: 14px
x:
show: true
formatter: |
EVAL:(timestamp) => {
let date = new Date(timestamp).toLocaleString('sv-SE',{weekday: 'long', hour: '2-digit', minute:'2-digit'}).toString();
return date.charAt(0).toUpperCase() + date.slice(1);
chart:
fontFamily: SF Text
height: 250px
legend:
fontSize: 15px
fontWeight: 600
itemMargin:
horizontal: 25
formatter: |
EVAL:(seriesName, opts) => {
var arr = opts.w.globals.series[opts.seriesIndex],
value = arr[arr.length - 1],
convert = (value / 1024).toFixed(2);
if (value == null) {
return seriesName;
} else {
return value < 1024 ? `${Math.round(value)} kB/s` : `${convert} MB/s`;
markers:
width: 26
height: 23
customHTML:
EVAL:() => {
return `<ha-icon icon="mdi:arrow-down-bold" style="--mdc-icon-size: 23px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="mdi:arrow-up-bold" style="--mdc-icon-size: 23px;"></ha-icon>`
fillColors:
- none
- none
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.2
opacityFrom: 0.7
opacityTo: 0.1
stops:
- 0
- 90
- 100
stroke:
curve: smooth
width: 3
all_series_config:
type: area
fill_raw: last
series:
- entity: sensor.nas_network_down
color: green
- entity: sensor.nas_network_up
color: '#385581'
AREA WEIGHT
Fetch data directly from InfluxDB Using HA or HACS graphs w/ InfluxDB data in HA? - #6 by koying
yaml
graph_span: 0.3month
apex_config:
yaxis:
show: true
decimalsInFloat: 1
labels:
style:
colors:
- rgba(255, 255, 255, 0.5)
fontSize: 13px
fontWeight: 200
offsetX: -2
grid:
show: true
borderColor: rgba(112, 135, 164, 0.1)
title:
text: kg
style:
color: white
fontSize: 30px
fontWeight: 100
tooltip:
style:
fontSize: 14px
x:
show: true
formatter: |
let date = new Date(timestamp).toLocaleString('sv-SE',{day: 'numeric', year: 'numeric', month:'long'}).toString().split(' ');
return `${date[0]} ${date[1].charAt(0).toUpperCase() + date[1].slice(1)} ${date[2]}`;
xaxis:
tooltip:
enabled: false
crosshairs:
show: false
axisTicks:
show: false
axisBorder:
show: true
color: rgba(112, 135, 164, 0.5)
height: 1
labels:
style:
fontSize: 15px
fontWeight: 500
offsetX: -1
formatter: |
return new Date(timestamp).toLocaleString('sv-SE',{day: 'numeric', month:'short'});
chart:
fontFamily: SF Text
height: 350px
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.2
opacityFrom: 0.7
opacityTo: 0.1
stops:
- 0
- 90
- 100
stroke:
curve: smooth
width: 3
all_series_config:
type: area
fill_raw: last
series:
- entity: sensor.date
curve: smooth
color: '#9a0ca3'
data_generator: |
let params = new URLSearchParams({
db: "home_assistant",
q: "SELECT value FROM kg WHERE entity_id = 'weight'"
request = async () => {
let a = [],
r = await fetch("http://192.168.1.241:8086/query?" + params),
j = await r.json();
for (let r of j.results[0].series[0].values) a.push([new Date(r[0]), r[1]]);
return a
return request()
COLUMN ENERGY
Fetch data from Tibber API
yaml
graph_span: 5months
apex_config:
tooltip:
style:
fontSize: 14px
x:
show: true
formatter: |
let date = new Date(timestamp).toLocaleString('sv-SE',{year: 'numeric', month:'long'}).toString()
chart:
height: 400px
fontFamily: SF Text
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.2
opacityFrom: 1
opacityTo: 0.7
stops:
- 0
- 70
- 100
grid:
show: true
yaxis:
show: true
decimalsInFloat: 0
labels:
style:
colors:
fontSize: 13px
fontWeight: 200
offsetX: -2
title:
text: ⚡ kWh
style:
color: white
fontSize: 38px
fontWeight: 700
xaxis:
tooltip:
enabled: false
crosshairs:
show: false
axisTicks:
show: false
axisBorder:
show: true
height: 1
labels:
style:
fontSize: 15px
fontWeight: 500
offsetX: -1
formatter: |
let date = new Date(timestamp).toLocaleString('en-US',{month:'short'}).toString();
return date.replace('c','k').replace('y','j');
series:
unit: kWh
type: column
color: rgba(228,224,17,1)
data_generator: |
let array = [], request = async () => {
let request = await fetch("https://api.tibber.com/v1-beta/gql", {method:"POST",headers:{Authorization:"Bearer xxx","Content-Type":"application/json"},body:JSON.stringify({query:"{viewer{homes{consumption(resolution: MONTHLY, last: 12){nodes{from consumption}}}}}"})}),
json = await request.json();
console.log(request);
for (let request of json.data.viewer.homes[0].consumption.nodes) array.push([new Date(request.from), request.consumption]);
return array
}; return request()
RADIAL SENSOR
UniFi OS style sensor
yaml
type: grid
cards:
chart_type: radialBar
apex_config:
legend:
onItemHover:
highlightDataSeries: false
show: false
chart:
height: 280px
fontFamily: SF Display
plotOptions:
radialBar:
startAngle: -180
endAngle: 180
dataLabels:
name:
show: true
offsetY: 55
value:
show: true
offsetY: 5
fontSize: 50px
fontWeight: 600
color: '#379c55'
total:
show: true
fontSize: 21px
fontWeight: 300
label: CPU Load
color: '#a8a8a8'
formatter: |
EVAL:(w) => {
return w.globals.seriesTotals + '٪';
hollow:
image: >-
data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg'
viewBox='0 0 283.5 283.5'%3E%3Cpath d='M117.3
109.2h48.8v4.1h12.2v8.1h-12.2v8.1h12.2v8.1h-12.2v8.1h12.2v8.1h-12.2v8.1h12.2v8.1h-12.2v4.1h-48.8V170h-12.2v-8.1h12.2V154h-12.2v-8.1h12.2v-8.1h-12.2v-8.1h12.2v-8.1h-12.2v-8.1h12.2v-4.3m20.4
44.8v12.2h4.1V154h-4.1m8.1 0v12.2h4.1V154h-4.1m8.2
0v12.2h4.1V154H154z' fill='%23a8a7a7'/%3E%3C/svg%3E
imageWidth: 118
imageHeight: 118
imageOffsetY: -50
imageClipped: false
track:
show: true
background: '#222222'
strokeWidth: 155%
stroke:
dashArray: 3.2
lineCap: butt
series:
- entity: sensor.template_udm_cpu
color: '#379c55'
apex_config:
legend:
onItemHover:
show: false
chart:
height: 280px
plotOptions:
radialBar:
startAngle: -180
endAngle: 180
dataLabels:
name:
show: true
offsetY: 55
value:
show: true
offsetY: 5
fontSize: 50px
fontWeight: 600
color: '#379c55'
total:
show: true
fontSize: 21px
fontWeight: 300
label: CPU Temp
color: '#a8a8a8'
formatter: |
EVAL:(w) => {
return w.globals.seriesTotals + '°';
hollow:
image: >-
viewBox='0 0 283.5 283.5'%3E%3Cpath d='M152.1 145.4v-26.9a10.07
10.07 0 1 0-20.2 0v26.9c-7.4 5.6-8.9 16.1-3.4 23.5 5.6 7.4 16.1
8.9 23.5 3.4s8.9-16.1 3.4-23.5c-.9-1.4-2.1-2.5-3.3-3.4M142
115.1a3.37 3.37 0 0 1 3.4 3.4v10.1h-6.7v-10.1c-.1-1.9 1.4-3.4
3.3-3.4z' fill='%23a8a7a7'/%3E%3C/svg%3E
imageWidth: 150
imageHeight: 150
imageOffsetY: -50
imageClipped: false
track:
show: true
strokeWidth: 155%
stroke:
dashArray: 3.2
lineCap: butt
series:
- entity: sensor.template_udm_cpu_temp
color: '#379c55'
columns: 2
square: true
DONUT COUNTER
Count total entities {{ states.automation | count }} etc.
yaml
chart_type: donut
apex_config:
fill:
type: gradient
gradient:
shade: dark
shadeIntensity: 0.1
opacityFrom: 0.9
opacityTo: 0.85
stops:
- 0
- 90
- 100
chart:
fontFamily: SF Text
legend:
position: right
fontSize: 13px
fontWeight: 300
markers:
width: 16
height: 25
customHTML:
EVAL:() => {
return `<ha-icon icon="hass:robot" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:radiobox-blank" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:account" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:lightbulb" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:cast" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:eye" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:flash" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:home-assistant" style="--mdc-icon-size: 14px;"></ha-icon>`
fillColors:
- none
- none
- none
- none
- none
- none
- none
- none
stroke:
show: true
width: 0.4
dataLabels:
enabled: false
style:
fontSize: 14px
fontWeight: 700
dropShadow:
enabled: true
top: 0
left: 0
blur: 3
color: black
opacity: 0.1
plotOptions:
pie:
startAngle: 0
endAngle: 360
expandOnClick: true
offsetX: 0
offsetY: 0
customScale: 1
dataLabels:
offset: 0
minAngleToShowLabel: 10
donut:
background: transparent
labels:
show: true
value:
fontSize: 42px
fontWeight: 700
offsetY: 16
total:
show: true
label: Entities
fontSize: 15px
fontWeight: 800
color: '#ffffff50'
series:
- entity: sensor.template_domain_counter
attribute: automation
attribute: binary_sensor
attribute: device_tracker
attribute: light
attribute: media_player
attribute: sensor
attribute: switch
attribute: other
Excuse the yaml, not used to using ui editor
EDIT: fixed “lines network” graph reversal
Does anyone know if it is possible to hide only the bottom time axis?
I would like a result like this. Like a minimal chart but keep the left value axis:
Edit, solved it:
xaxis:
labels:
show: false
axisTicks:
show: false
How can I add an extra value on the datapoint?
I use the Tautulli sensor to monitor Plex, I’d like to show the number of user watching (works out of the box), but show additional info on datapoint hover, i.e. user, title, these are currently nested attributes of the sensor (see screenshot). Is this possible?
Good morning,
some time ago I’ve made an ApexCharts dashboard for my weather station where, in some charts, I’ve put in header the value of a string sensor as “raw” (like the pressure trend or UV exposition warning) and it was correctly displayed.
From the last update or two of the integration I see, for that sensors, only “NaN” instead of the string.
Is possible to fix this?
How?
Amazing use of the card
Love it, thanks for sharing your work!
That won’t be possible
Please open a bug on github ![]()
Hi @RomRider,
Thanks for the quick reply. That’s not a big deal.
The only other issue I’m having is that because my sensor only updates upon a change, the column chart isn’t reflective of the status, i.e. a user started playing 30 mins ago, I have a single column at that time, but following, the graph is blank (unless the sensor updates, such as when they pause, play). How can I work around this? I tried to ‘fill’, ‘last’ but had no luck?
You can use update_interval instead of relying on the update of the sensor.
That’s what I’ve done, but you can see it’s not working (things have been playing for over 30m)
graph_span: 1h
update_interval: 5sec
stacked: true
all_series_config:
show:
extremas: false
opacity: 0.1
fill_raw: zero
now:
show: false
label: Now
color: FF0000
header:
show: true
title: 24H Watching Statistics
show_states: true
colorize_states: true
series:
- entity: sensor.tautulli
attribute: stream_count_direct_play
curve: stepline
type: column
show:
datalabels: false
in_chart: true
float_precision: 0
attribute: stream_count_direct_stream
curve: stepline
type: column
show:
datalabels: false
in_chart: true
float_precision: 0
attribute: stream_count_transcode
curve: stepline
type: column
show:
datalabels: false
in_chart: true
float_precision: 0
apex_config:
legend:
show: true
position: bottom
plotoptions:
bar:
borderRadius: 10
xaxis:
tooltip:
enabled: false
I would like to know if there is something to display the time serie by cumulate the value with the previous. Ex: "transform: return Y + (Y-1) "
Would you mind trying without curve: stepline please?
I’m trying to add to my chart when the AC turns on, and I’ve done it, but in a really janky way. What I’ve done is:
transform: 'return x > 100 ? 60 : null;'
but what I want is:
- When the AC is on, say ‘On’ vs 60
- A vertical line that fills from top to bottom vs being 60.
Help and thank you so much!
Full YAML Code
graph_span: 2d
all_series_config:
stroke_width: 1
group_by:
func: max
fill: last
header:
show: true
show_states: false
colorize_states: false
title: Temp Overlay
apex_config:
grid:
show: false
legend:
show: true
tooltip:
shared: true
series:
- entity: sensor.temp_sensor_001_temperature
type: line
- entity: sensor.temp_sensor_002_temperature
type: line
- entity: sensor.temp_sensor_003_temperature
type: line
- entity: sensor.temp_sensor_004_temperature
type: line
- entity: sensor.temp_sensor_005_temperature
type: line
- entity: sensor.6_channel_energy_meter_ct3_watts
type: area
unit: ' '
- entity: sensor.openweathermap_temperature
type: area
I tried the straight option.
Same strange behaviour:
I think that gaps on the apexcharts graphs should be same as on the stock graph.
Correct, I’ve just checked and update_interval is broken, I’ll need to look into it.
Could it be a reason of my issue too?
No, that’s different, I’ll need to investigate.
Please open a github issue as it’s easier for me to track it and update you.
Hi customizing professionals, is it possible to format the series name, in the example below? I would like to change both the positioning and font/color.
series:
- entity: sensor.aqaratemp1_temperature
type: area
name: '>>>>How do i format this text?<<<'
curve: smooth
stroke_width: 3
color: '#1188db'
opacity: 0.15
group_by:
func: last
duration: 4h
fill: last
