I have a sensor that gives the total amount of energy used, it restarts at 02:00 every night. Would it be possible to show the value from 02:00 only, and with history for the last 7 or 30 days?
Question:
Why isn’t it 0 the minimum in my y axis and why does it have 3 digits of precision? What am I doing wrong?
type: custom:apexcharts-card
apex_config:
chart:
height: 480px
graph_span: 24h
span:
start: day
header:
title: Consumo horário
show: true
update_interval: 1h
y_axis_precision: 2
yaxis:
- id: a
min: 0
series:
- entity: sensor.total_energy_hour
yaxis_id: a
type: column
float_precision: 2
group_by:
func: max
duration: 60min
are you sure your indentation is right? i am using like below
Thanks, it’s working now. I guess it’s necessary to have min and max defined, just the min doesn’t work.
New Release
1.10.0 (2021-10-24)
Features
- uses the time format defined in Home Assistant user profile (78df800), closes #213
yaxis: Align the extremas to the closest
align_tovalue. (a46c812), closes #170 - pie/donut now shows the value of the serie instead of the percentage. Old behavior with
datalabels: percent(7591aba) -
actions:
header_actionssupport for actions in header (#171) (bd6a497), closes #61 - display the chart’s last update time using
last_updated(2dd84ff) -
yaxis: Set the number of decimals shown on the yaxis. Deprecate
y_axis_precision. (33fc474), closes #164 - update from lit-html/lit-element to lit (5a7d944)
yaxis:
idandyaxis_idno longer needed with only 1 yaxis defined (e5e8904)
Bug Fixes
- color_threshold would sometimes render weirdly (d7063a5), closes #177
- extremas would not display with offset applied on series (4d7d77a), closes #177
- Floats were not truncated properly for radialBar (0c789ff), closes #174
- history data could be modified in some rare cases (d38fd6e)
- Ignore recorder when not required (c28a7a6), closes #169
- the hass object could sometimes be null (ff27baf), closes #191
- When recorder was skipped, attributes were ignored (15e5372)
- yaxis: auto scale was not taking the serie’s offset into account (f82f7e0), closes #172
- yaxis: Fixed + unfixed bounds on the same yaxis is now working (f7e4668)
Documentation
Sorry, I was quite absent lately, will try to do better in the future
I try to combine the chart with auto-entities. It works if I want to show each series in one graph, but how do I create separate graphs for each series, like in with mini-graph card:
type: custom:auto-entities
card:
type: grid
columns: 2
square: false
card_param: cards
filter:
include:
- entity_id: '*b*usd*'
state: '>2'
options:
type: custom:mini-graph-card
If I try the filter method I get 1 chart with different series.
card:
header:
show: true
apex_config:
chart:
height: 410px
stroke:
show: true
width: 1
graph_span: 12h
filter:
include:
- name: Binance*USD
state: '> 0'
options:
group_by:
func: avg
duration: 10min
exclude: []
sort:
method: none
Thanks.
That’s a perfect alternative to the big number card!
Nobody an idea, how to send the big numbers to the back?
Thanks for this release, especially the yaxis features and bug fixes.
I had problems with decimals but with your latest version of ApexCharts everything is working perfect now!
I use the “headers” in my charts. But in one of them, the label that comes from the sensor is too long. Is there a way to edit the label in the header?
Example: in this card, I’m doing a grid with two apexcharts-card, the left card shows ‘kB/s’, the right card shows ‘packets/s’, but the word is long and I’d like to abbreviate it to ‘pkts/s’ to keep the header to two lines instead of four lines.
The code for the card is:
type: grid
cards:
- type: custom:apexcharts-card
apex_config:
yaxis:
show: true
forceNiceScale: true
decimalsInFloat: 0
stroke:
width: 3
curve: smooth
legend:
show: false
graph_span: 2d
header:
show: true
show_states: true
colorize_states: true
title: pfSense WAN usage
series:
- entity: sensor.pfsense_interface_wan_inbytes_kilobytes_per_second
group_by:
func: avg
duration: 60min
name: Inbound avg 7h
group_by:
func: avg
duration: 7h
- entity: sensor.pfsense_interface_wan_outbytes_kilobytes_per_second
invert: true
group_by:
func: avg
duration: 60min
name: Outbound avg 7h
invert: true
group_by:
func: avg
duration: 7h
apex_config:
yaxis:
show: true
decimalsInFloat: 0
stroke:
width: 3
curve: smooth
legend:
show: false
graph_span: 2d
header:
show: true
show_states: true
title: pfSense WAN packets
series:
- entity: sensor.pfsense_interface_wan_inpkts_packets_per_second
group_by:
func: avg
duration: 60min
group_by:
func: avg
duration: 7h
- entity: sensor.pfsense_interface_wan_outpkts_packets_per_second
invert: true
group_by:
func: avg
duration: 60min
invert: true
group_by:
func: avg
duration: 7h
columns: 2
square: false
Hooray for header_actions!
Same as your mini-graph-card example, just replace csutom:mini-graph-card with custom:apexcharts-card
In each serie, you can redefine the unit:
series:
- entity: sensor.packets
unit: pkts/s
This is my code:
card:
type: grid
columns: 2
square: false
card_param: cards
filter:
include:
state: '>2'
options:
series:
- entity: this.entity_id
This is generated by the auto-entities:
entity: sensor.binancehotusd
series:
- entity: sensor.binancehotusd
The line ‘entity: sensor.binancehotusd’ causes this error:
/// apexcharts-card version 1.10.0-dev.6 /// value.entity is extraneous
Code below shows a card as expected:
series:
Is it possible to ignore ‘extraneous’ values? If the value is ignored things will work as expected. Or do you have any other advice?
You can disable the configuration check
experimental:
disable_config_validation: true
Hi all!!
Is it possible to use a sensor value to define the “max” in a graph?
I would like something like below:
chart_type: radialBar
header:
show: true
floating: false
show_states: true
apex_config:
title:
floating: false
align: center
style:
fontSize: 20px
fontWeight: bold
chart:
fontFamily: Julius Sans One
foreColor: rgb(148,148,148)
offsetY: 5
legend:
show: false
position: top
series:
- entity: sensor.teams_stat_activity_in_a_call
name: In a Call
max: 9
color: '#a45a52'
- entity: sensor.teams_stat_activity_in_a_conference_call
name: In a Conf Call
max: 9
color: '#8b0000'
- entity: sensor.teams_stat_activity_busy
max: 9
- entity: sensor.teams_stat_activity_idle
max: 9
color: '#fada5e'
- entity: sensor.teams_stat_activity_available
max: |
return 42;
color: '#008000'
style: |
ha-card {
border: 0px solid green;
#background-color: var(--dwains-theme-primary);
box-shadow: none;
font-size: 15px;
color: rgb(148,148,148);
This fails with error:
/// apexcharts-card version 1.10.0 /// value.series[4] is not a ChartCardSeriesExternalConfig; value.series[4].max is not a number
Guys, I’m trying to use a map with this code:
header:
title: Загрузка CPU
series:
- entities: sensor.processor_use_percent
But I get the error:
auto-entities.js:210 card custom:apexcharts-card Error: /// apexcharts-card version 1.10.0 /// value.series[0] is not a ChartCardSeriesExternalConfig; value.series[0].entities is extraneous
at HTMLElement.setConfig (apexcharts-card.js:829)
at s (hui-state-label-badge.ts:14)
at hui-state-label-badge.ts:14
at d (hui-state-label-badge.ts:14)
at c (hui-state-label-badge.ts:14)
at g (hui-state-label-badge.ts:14)
at HTMLElement.value (hui-stack-card.ts:16)
at hui-light-card.ts:35
at Array.map (<anonymous>)
at HTMLElement.value (hui-light-card.ts:35)
Tell me, what am I doing wrong?
I love that this feature is available now, something I have wanted for a long time:
last_updated(2dd84ff )
Would it be possible to integrate the time stamp in the name as shown below? Would make it look a bit nicer and better integrated in the overall layout.
Has anybody managed to get header_actions to work with a radial bar chart?
It’s supposed to be:
series:
- entity: sensor.xyz
Not entities ![]()
That is not possible but you can create a feature request on github
That should work the same as with other charts, if not open a bug on github
Open a feature request on github, I’ll look into it
