benm7
(Ben M)
March 18, 2022, 5:40am
1486
Is there a way to increase the size of a radial bar graph itself to take up more of the card space? I am using it within a button card but it doesn’t seem to occupy as much space as I would have expected it to. It is set to use 60% of the card on the right hand side.
I also can’t get it to accept Rob values for the color of each entity for some reason, but will keep trying with that one
Code:
- type: custom:apexcharts-card
chart_type: radialBar
style: |
ha-card {
border-radius: "var(--border-radius)";
box-shadow: none;
padding-bottom: 0px;
padding-top: 0px;
header:
show: false
apex_config:
title:
floating: false
align: top
style:
fontSize: 2px
fontWeight: bold
chart:
foreColor: rgb(148,148,148)
offsetY: 5
legend:
show: false
series:
- entity: "[[[ return variables.entity_1 ]]]"
name: "[[[ return variables.entity_1_name ]]]"
color: "#01C852"
- entity: "[[[ return variables.entity_2 ]]]"
name: "[[[ return variables.entity_2_name ]]]"
color: "#E91E63"
- entity: "[[[ return variables.entity_3 ]]]"
name: "[[[ return variables.entity_3_name ]]]"
color: "#FF9101"
gasolli
March 20, 2022, 12:50am
1487
Is there a way to “grey out” (a different color, slightly opaque background) a specific time of day?
I am trying to visualize night time on my weather forecast chart, and cant seem to figure it out…
hours_12: false
header:
show: true
title: Temperaturer neste 24t - (C°)
show_states: false
graph_span: 1d
span:
start: minute
update_interval: 1h
apex_config:
annotations:
position: back
yaxis:
- 'y': 0
strokeDashArray: 5
borderColor: '#5b5b5b'
borderWidth: 1
xaxis:
labels:
format: HH
axisBorder:
show: false
legend:
show: false
grid:
show: false
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.4
opacityFrom: 0.9
opacityTo: 0
stops:
- 1
- 95
- 100
chart:
dropshadow:
enabled: true
height: 300px
width: 100%
series:
- entity: weather.hjem_hourly
stroke_width: 3
color: rgba(10,100,140,1)
unit: C
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.temperature];
type: area
show:
legend_value: false
in_header: false
extremas: true
extend_to_end: true
view_layout:
column: 2
style:
ha-card {
background-color: rgba(0,0,0,0.1);
width: 1215px;
margin:auto;
position: absolute;
left: 0;
right: 0;
border: none;
box-shadow: none;
border-radius: 20px;
div#header__title {
font-size: 17px;
font-weight: bold;
text-align: center;
arrows
March 21, 2022, 7:02pm
1488
This featureset looks amazing! Unfortunately I’m stuck at the installation stage. I already use HACS, and when trying to add the Github repo as a custom repository, I get the message that “Repository ‘romrider/apexcharts-card’ exists in the store.”. When I search the store (using HACS → Integrations → Explore & Download Repositories button) ApexCharts is not found.
ETA: I did not realise that I needed to be clicking “Explore & Download Repositories” specifically on the Frontend tab, not the Integrations tab. All fixed.
I created a chart a bit similar to that
Unfortanelly today is just not the best time to showcase my chart since the weather got nice and the temperatures didn’t trigger the space heater, but still, here is a screenshot:
I don’t use a conventional climate entity though, I built an automation from scratch using two temperature sensors, one in the floor and one in the ceiling, so I can better monitor the rise in temperature coming from the space heater and be more smart switching it on and off.
If I get a nice chart view soon I’ll update the screenshot, it’s easy to see when the heater is on and the result from it.
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: gauge
entity: sensor.zig_temp_sensor1_temperature
severity:
green: 72
yellow: 78
red: 85
max: 90
min: 60
needle: true
name: Montains room temperature ceiling
- type: gauge
entity: sensor.zig_temp_sensor2_temperature
severity:
green: 72
yellow: 78
red: 85
max: 90
min: 60
needle: true
name: Montains room temperature floor
header:
show: true
title: ''
show_states: true
colorize_states: true
standard_format: true
floating: false
graph_span: 20h
all_series_config:
stroke_width: 2.2
opacity: 1
type: line
fill_raw: last
curve: smooth
show:
datalabels: false
extremas: true
legend_value: false
apex_config:
dataLabels:
enabled: true
dropShadow:
enabled: true
grid:
show: false
legend:
show: false
xaxis:
labels:
show: true
axisBorder:
show: true
axisTicks:
show: true
chart:
height: 200px
series:
- entity: sensor.openweathermap_temperature
color: hsl(150, 45%, 26%)
type: area
yaxis_id: second
stroke_width: 0
opacity: 0.1
show:
extremas: false
- entity: sensor.zig_temp_sensor1_temperature
color: green
type: line
yaxis_id: first
- entity: sensor.zig_temp_sensor2_temperature
color: rgb(60, 130, 160)
type: line
yaxis_id: first
- entity: switch.space_heater
transform: 'return x === ''on'' ? 1 : 0;'
color: rgb(250 100 250)
type: area
yaxis_id: third
opacity: 0.08
stroke_width: 0
show:
datalabels: false
extremas: false
group_by:
func: max
duration: 2m
start_with_last: true
fill: last
yaxis:
- id: first
min: ~68
max: ~78
apex_config:
labels:
show: false
axisBorder:
show: false
axisTicks:
show: false
- id: second
min: ~68
max: ~76
apex_config:
labels:
show: false
axisBorder:
show: false
axisTicks:
show: false
- id: third
min: 0
max: 0.1
apex_config:
labels:
show: false
axisBorder:
show: false
axisTicks:
show: false
I had to create a new “rounded” sensor of the original one to use in the Lovelace frontend. The “round(0)” at the end can be changed to (2) if you want two decimals.
Maybe the same approach is needed in your case?
sensors:
energy_current_consumption_rounded:
friendly_name: "Energy - Current consumption rounded"
unit_of_measurement: "W"
icon_template: mdi:flash-outline
value_template: >-
{{ (states('sensor.energy_current_consumption')|float)|round(0) }}
so glad I see this… having an issue in core history and even mini-graph-card , where I need to fill the graph relative to the x-axis… yours is the first I see doing that.
Would you be able to throw me the config settings for that please.
I cant get it that even though it is such a ‘default’ need, we would need to card-mod our way to it.
this is my bare/base apexchart I tried (which isnt very nice to my HA instance, but thats another matter)
header:
title: Gebruik actueel per uur
update_interval: 30sec
all_series_config:
stroke_width: 1
curve: smooth
graph_span: 12h
series:
- entity: sensor.zp_actuele_opbrengst
color: gold
- entity: sensor.calculated_bruto_verbruik
color: darkblue
- entity: sensor.netto_verbruik
color: lightblue
could you help me out please?
I need this:
and not this:
so sun should only fill from 0 to max sensor value upward, and same for the light blue, but then from max to min
Sure, here comes the code Hope it can help you.
header:
title: ''
show: true
show_states: true
colorize_states: false
graph_span: 24h
apex_config:
tooltip:
enabled: false
annotations:
position: back
yaxis:
- 'y': 0
strokeDashArray: 0
borderColor: '#303030'
borderWidth: 1
yaxis:
forceNiceScale: true
labels:
style:
fontSize: 10px
fontFamily: Segoe UI Light
xaxis:
axisBorder:
show: false
labels:
style:
fontSize: 10px
legend:
show: false
chart:
height: 225
grid:
show: false
strokeDashArray: 3
position: back
dataLabels:
enabled: false
stroke:
width: 1
fill:
type: gradient
gradient:
type: vertical
shadeIntensity: 0.8
inverseColors: false
opacityFrom: 0.7
opacityTo: 0
stops:
- 0
series:
- entity: sensor.garaget
type: area
curve: smooth
fill_raw: last
color: '#404040'
float_precision: 1
transform: return x + 1;
show:
in_chart: true
- entity: sensor.nibe_105703_40004
type: area
curve: smooth
fill_raw: last
color: fc7703
float_precision: 1
show:
extremas: false
- entity: sensor.nibe_105703_43084
type: column
color: orange
fill_raw: last
show:
in_chart: true
group_by:
func: avg
duration: 20min
style: |
ha-card {
--ha-card-background: rgba(0, 0, 0, 0);
box-shadow: none;
margin: 8px 8px 38px 8px;
font-size: 15px;
font-family: 'Segoe UI Light";
text-align: center
div#header__title {
font-size: 20px;
font-weight: 300;
font-color: #ff0000
thanks!.
I finally got somewhere… yo have a lot of settings, and out of the box that didnt make it happen just yet for me. Turns out I didnt have the correct type selected, (thought to use line, and fill the area below that…). Now found out I need the type: area…
header:
all_series_config:
stroke_width: 1
curve: smooth
graph_span: 6h
series:
color: gold
type: area
color: darkblue
color: lightblue
type: area
is getting closer
to the end goal
and I have to find out which of the config options make that happen. Maybe I can smooth out all of those spikes, by lowering the update frequency to 1 minute.
If you have suggestions please dont hold back!
Looks nice!
What you could try is altering your code like below and changing 20min to something that gives you the look you want:
series:
color: darkblue
group_by:
func: avg
duration: 20min
much better, and I didnt have to avg to 20min, 2 min suffices. As a matter if fact it is near perfect
original:
apex
guess I need to do that for the light blue too:
heck yeah:
and some finetuning:
header:
update_interval: 1min
graph_span: 6h
# apex_config:
# fill:
# type: gradient
# gradient:
# opacityFrom: 0.9
# opacityTo: 0.5
series:
color: gold
type: area
stroke_width: 3
opacity: 0.5
color: darkblue
group_by:
func: avg
duration: 2min
stroke_width: 1
color: lightblue
type: area
group_by:
func: avg
duration: 2min
stroke_width: 3
opacity: 0.5
not bad at all
thanks again, you made my day.
for the fun of it, a frontend selectable span:
type: custom:config-template-card
entities:
- input_select.apex_span
variables:
span: states['input_select.apex_span'].state
card:
graph_span: ${span}
series:
I am really enjoying this component, but there is one thing I miss: the option to pan through the data by dragging (zoom would also be nice). Is this something that could be added?
Just adding a second screenshot to the previous post, this one shows a little better the ON and OFF of the heater overl the temperature changes
wigster
March 24, 2022, 10:29am
1498
I’m trying to plot the weather forecast contained in a sensor I’m scraping from the local weather webpage to the sensor’s attributes. The sensor state looks like this:
state_class: measurement
forecast_time: |-
- 12:00
- 13:00
- 14:00
- 15:00
forecast_temperature: |-
- 15.0
- 16.0
- 17.0
- 17.0
forecast_time is the local time and forecast_temperature is the temperature.
I am trying to write a data_generator to plot this, but I can’t quite work it out:
series:
- entity: sensor.inpo_praha_temperature
stroke_width: 2
data_generator: |
return entity.attributes.forecast_time.map((time, index) => {
return [new Date(moment().format('YYYY-MM-DD'+'T'+time).getTime(), entity.attributes.forecast_temperature[index]];
I would very much appreciate some help!
HI,
having some severe issues with apex-chart cards performance in my views, I need to ask if this still belongs to the ‘regular’ console errors we could expect and forget, or if I should post an issue at the GitHub. Its a real let down currently, and HA dev nightly (which has a new way of web socket handling) doesnt really like it:
please if anyone could check these errors, and see if they are showing in your config too? thanks!
You should be able to drag the graph if using a mouse and zoom with the mouse wheel.
I use the following y-axis setting to be able to only drag the graph horizontaly which felt more logical.
defaults:
yaxes:
fixedrange: true
I cannot drag or zoom with my mouse (I can drag and zoom in another component with the same mouse).
Can you then drag only within the original boundaries (ie one day), or can you scroll through the whole history?
EDIT - I was looking at the wrong typ of graph (plotly-graph)
The whole history!
Here is my config for a standard graph.
type: custom:plotly-graph
title: Power
entities:
- entity: sensor.power
defaults:
yaxes:
fixedrange: true
hours_to_show: 3
refresh_interval: 10
layout:
xaxis:
rangeselector:
'y': 1.5
buttons:
- count: 1
step: minute
- count: 1
step: hour
- count: 12
step: hour
- count: 1
step: day
- count: 7
step: day
You are referring to the Plotly component (in which you can indeed pan and zoom), but I was referring to the component of this topic: ApexCharts.
Indeed! So sorry. I am testing all sorts of graphs and got carried away.
donnib
April 2, 2022, 9:43pm
1505
I am making following chart :
apex_config:
chart:
height: 350px
experimental:
color_threshold: true
graph_span: 24h
header:
title: Elpriser pr. time (kr/kWh)
show: true
span:
start: hour
offset: '-2h'
now:
show: true
label: Nu
yaxis:
- min: 0
apex_config:
tickAmount: 5
series:
- entity: sensor.strom_pris
type: column
data_generator: |
var data = entity.attributes.raw_today.map((start, index) => {
return [new Date(start["hour"]).getTime(), entity.attributes.raw_today[index]["price"]];
if (entity.attributes.tomorrow_valid) {
data.concat(entity.attributes.raw_tomorrow.map((start, index) => {
return [new Date(start["hour"]).getTime(), entity.attributes.raw_tomorrow[index]["price"]];
return data;
float_precision: 2
color_threshold:
- value: 0
color: green
- value: 2.8
color: orange
- value: 3.5
color: red
- value: 5
color: darkred
and the sensor data is at the moment of the screenshot this :
current_price: 3.405
unit: kWh
currency: DKK
area: East of the great belt
area_code: DK2
tomorrow_valid: true
next_data_update: '13:08:00'
today:
- 2.686
- 2.806
- 2.869
- 2.951
- 2.869
- 2.993
- 2.907
- 3.207
- 3.413
- 3.431
- 3.223
- 3.196
- 3.138
- 2.873
- 2.765
- 2.838
- 2.922
- 3.237
- 3.76
- 4.054
- 3.891
- 3.597
- 3.561
- 3.405
tomorrow:
- 3.495
- 3.439
- 3.464
- 3.452
- 3.462
- 3.446
- 3.419
- 3.435
- 3.478
- 3.337
- 3.325
- 3.31
- 3.264
- 2.756
- 2.547
- 2.611
- 2.773
- 2.192
- 2.283
- 2.482
- 2.295
- 2.245
- 2.177
- 2.079
raw_today:
- hour: '2022-04-02T00:00:00+02:00'
price: 2.686
- hour: '2022-04-02T01:00:00+02:00'
price: 2.806
- hour: '2022-04-02T02:00:00+02:00'
price: 2.869
- hour: '2022-04-02T03:00:00+02:00'
price: 2.951
- hour: '2022-04-02T04:00:00+02:00'
price: 2.869
- hour: '2022-04-02T05:00:00+02:00'
price: 2.993
- hour: '2022-04-02T06:00:00+02:00'
price: 2.907
- hour: '2022-04-02T07:00:00+02:00'
price: 3.207
- hour: '2022-04-02T08:00:00+02:00'
price: 3.413
- hour: '2022-04-02T09:00:00+02:00'
price: 3.431
- hour: '2022-04-02T10:00:00+02:00'
price: 3.223
- hour: '2022-04-02T11:00:00+02:00'
price: 3.196
- hour: '2022-04-02T12:00:00+02:00'
price: 3.138
- hour: '2022-04-02T13:00:00+02:00'
price: 2.873
- hour: '2022-04-02T14:00:00+02:00'
price: 2.765
- hour: '2022-04-02T15:00:00+02:00'
price: 2.838
- hour: '2022-04-02T16:00:00+02:00'
price: 2.922
- hour: '2022-04-02T17:00:00+02:00'
price: 3.237
- hour: '2022-04-02T18:00:00+02:00'
price: 3.76
- hour: '2022-04-02T19:00:00+02:00'
price: 4.054
- hour: '2022-04-02T20:00:00+02:00'
price: 3.891
- hour: '2022-04-02T21:00:00+02:00'
price: 3.597
- hour: '2022-04-02T22:00:00+02:00'
price: 3.561
- hour: '2022-04-02T23:00:00+02:00'
price: 3.405
raw_tomorrow:
- hour: '2022-04-03T00:00:00+02:00'
price: 3.495
- hour: '2022-04-03T01:00:00+02:00'
price: 3.439
- hour: '2022-04-03T02:00:00+02:00'
price: 3.464
- hour: '2022-04-03T03:00:00+02:00'
price: 3.452
- hour: '2022-04-03T04:00:00+02:00'
price: 3.462
- hour: '2022-04-03T05:00:00+02:00'
price: 3.446
- hour: '2022-04-03T06:00:00+02:00'
price: 3.419
- hour: '2022-04-03T07:00:00+02:00'
price: 3.435
- hour: '2022-04-03T08:00:00+02:00'
price: 3.478
- hour: '2022-04-03T09:00:00+02:00'
price: 3.337
- hour: '2022-04-03T10:00:00+02:00'
price: 3.325
- hour: '2022-04-03T11:00:00+02:00'
price: 3.31
- hour: '2022-04-03T12:00:00+02:00'
price: 3.264
- hour: '2022-04-03T13:00:00+02:00'
price: 2.756
- hour: '2022-04-03T14:00:00+02:00'
price: 2.547
- hour: '2022-04-03T15:00:00+02:00'
price: 2.611
- hour: '2022-04-03T16:00:00+02:00'
price: 2.773
- hour: '2022-04-03T17:00:00+02:00'
price: 2.192
- hour: '2022-04-03T18:00:00+02:00'
price: 2.283
- hour: '2022-04-03T19:00:00+02:00'
price: 2.482
- hour: '2022-04-03T20:00:00+02:00'
price: 2.295
- hour: '2022-04-03T21:00:00+02:00'
price: 2.245
- hour: '2022-04-03T22:00:00+02:00'
price: 2.177
- hour: '2022-04-03T23:00:00+02:00'
price: 2.079
today_min:
price: 2.686
today_max:
price: 4.054
today_mean: 3.191
tomorrow_min:
price: 2.079
tomorrow_max:
price: 3.495
tomorrow_mean: 2.949
unit_of_measurement: DKK/kWh
device_class: monetary
icon: mdi:flash
friendly_name: Strøm Pris
At night 00:00 the tomorrow_validthe sensor will go false and no data would be for tomorrow. During the day around 13:30-14:00 the sensor tomorrow_valid will go true and data will be available for tomorrow in the attribute raw_tomorrow for sensor sensor.strom_pris however my graph doesn’t show the data as you can see in the first graph screenshot. At 00:00 the data would show in the graph (second graph screenshot) but then it’s missing the previous 2h. Any ideas what i am doing wrong ?
