ApexCharts card - A highly customizable graph card
When having 2 or more curves, is there a way to make the info-box that appears when hovering your mouse over the lines to show ALL curves in the same info-box? Because sometimes it can be hard to select all diffrent curves individually. This way it doesnt matter if all curve’s stats is shown in the box at the same time at the specific time you’re on.
dear all… someone could point me to the right direction on how to solve my problem??
I have a binary_sensor.alarm (with state 0 and 1) but when i create my apexchart card… no values!
I’m trying to create something like the history bar chart (with on or off states) in HA history.
Thanks a lot.
Something like this?
type: custom:apexcharts-card
graph_span: 2w
span:
  end: day
header:
  show: true
  title: Binary
series:
  - entity: binary_sensor.workday_sensor
    transform: 'return x === "on" ? 1 : 0;'
    type: area
    color: grey
    opacity: 0.2
    stroke_width: 0
    curve: stepline
    show:
      legend_value: true
      in_header: false
      name_in_header: false
      datalabels: false
hi! thanks a lot! it works like a charm!!!
so please, just another question:
Could you check this discussion??
I’m using that code for two input_select, the first to select the sensor and the second for select the period… now… how can i use human-readable names insted of sensor name???
Thanks a lot.
hello,
i need some help…
i want to setup a 2nd yaxis on the right for SolarPower, but i always get an error
/// apexcharts-card version 1.10.0 /// Multiple yaxis detected: Some yaxis are missing an 'id'.
  - panel: true
    title: MPPT Tag
    path: mppt-graph
    badges: []
    cards:
      - type: 'custom:apexcharts-card'
        update_interval: 5min
        cache: true
        graph_span: 1d
        span:
          start: day
        header:
          show: false
        series:
          - entity: sensor.solar_output_voltage
            yaxis_id: output_voltage
          - entity: sensor.solar_output_current
            yaxis_id: output_current
          - entity: sensor.solar_input_power
            yaxis_id: input_power
          - entity: sensor.solar_input_voltage
            yaxis_id: input_voltage
          - entity: sensor.solar_input_current
            yaxis_id: input_current
          - entity: sensor.solar_mppt_temp
            yaxis_id: mppt_temp
          - entity: sensor.solar_output_power
            yaxis_id: output_power
        yaxis:
          - id: output_power
          - show: true
            min: 0
            max: 400
            opposite: true
          - id: output_voltage
          - show: true
            min: 0
            max: 16
            opposite: false
          - id: output_current
          - show: true
            min: 0
            max: 30
            opposite: false
          - id: input_voltage
          - show: true
            min: 0
            max: 50
            opposite: false
          - id: input_current
          - show: true
            min: 0
            max: 30
            opposite: false
          - id: input_power
          - show: true
            min: 0
            max: 400
            opposite: true
          - id: mppt_temp
          - show: true
            min: 0
            max: 60
            opposite: false
        all_series_config:
          type: area
          curve: smooth
          extend_to_end: false
        apex_config:
          stroke:
            width: 1
          fill:
            type: gradient
            gradient:
              shadeIntensity: 1
              inverseColors: false
              opacityFrom: 0.45
              opacityTo: 0.05
              stops:
                - 20
                - 40
                - 70
                - 100
what do i do wrong?
Someone can help me?
EDIT: wrong syntax:
          - show: true
should be
            show: true
:slight_smile:
hello! i’m using the zoom function but it works only on my mac… in mobile device nothing to do…
someone could help me??
thanks
Yes it doesn’t work on a mobile
ok man! thanks a lot!
Which zoom function are you referring to on mobile? I can use the pan and zoom functions on mobile if that is what you mean.
hi! no pan icon on my mobile but on my mac yes… mah…
Is it possible to format the x-axis? I see the hours_12 option, but I’d like to convert x-axis values which look like this: 11:00 am to something like this 11am to save space.
Got it working. altroug i dont get it exactly as yours
i also have a selector for the timespan (see screenshot). But when i change it, there is no resfresh on the data like yors.
This is really nicely done, could you share the final code?
Sure, here is the code :slight_smile:
header:
  title: ''
  show: true
  show_states: true
  colorize_states: false
graph_span: 12h
apex_config:
  tooltip:
    enabled: false
  annotations:
    position: back
    yaxis:
      - 'y': 10
        strokeDashArray: 5
        borderColor: '#962626'
        borderWidth: 1
  xaxis:
    axisBorder:
      show: false
    labels:
      style:
        fontSize: 10px
        fontFamily: Segoe UI Light
  chart:
    height: 175
  grid:
    show: false
    borderColor: '#404040'
    strokeDashArray: 10
    position: back
  legend:
    show: false
  dataLabels:
    enabled: false
  stroke:
    width: 1
  fill:
    type: gradient
    gradient:
      type: vertical
      shadeIntensity: 0.8
      opacityFrom: 0.5
      opacityTo: 0
      stops:
        - 0
yaxis:
  - min: 0
    max: ~10
    apex_config:
      forceNiceScale: true
      decimalsInFloat: 0
      labels:
        style:
          fontSize: 10px
series:
  - entity: sensor.marbg_wind_speed
    type: area
    color: 3ca358
    float_precision: 0
    fill_raw: last
  - entity: sensor.marbg_wind_speed_max
    type: area
    curve: smooth
    color: fc7703
    fill_raw: last
    show:
      extremas: true
style: |
  ha-card {
     --ha-card-background: rgba(0, 0, 0, 0);
     box-shadow: none;
     margin: 28px 0px 38px 8px;
     font-size: 15px;
     font-family: 'Segoe UI Light";
     text-align: center
   div#header__title {
     font-size: 20px;
     font-weight: 300;
     font-color: #ff0000
I only see the pan/zoomicons when I first tap on the top right side of the graph
Hope someone can help, I’ve tried many variations and cannot get this to work, not sure if it is even possible.
I want this transform to return the state of an entity (Y) or 0 depending on the state of a binary sensor:
transform: "return x == 'on' ? Y : 0;"
It works fine if just add a number but not a template:
transform: "return x == 'on' ? {{ states('sensor.sensorname', 'number') }} : 0;"
I’ve tried all sorts of quotes variations
Could someone please help me with color_threshold? It looks a bit strange…
(should be gray up to 1500, orange up to 6550 and lime above 6850)
This is my config:
  - type: custom:apexcharts-card
    graph_span: 48h
    span:
      start: day
    experimental:
      color_threshold: true
    apex_config:
      yaxis:
        min: 0
        max: 10000
        tickAmount: 5
    header:
      show: true
      title: Solar Production vs. forecast
      show_states: true
    now:
      show: true
      label: jetzt
    apex_config:
      legend:
        show: false
    series:
      - entity: sensor.el_leistung_pv_ac
        unit: W
        fill_raw: last
        group_by:
          func: avg
          duration: 30min
        color_threshold:
          - value: 0
            color: gray
          - value: 1500
            color: gray
          - value: 2000
            color: darkorange
          - value: 6552
            color: darkorange
          - value: 6852
            color: lime
      - entity: sensor.solcast_forecast_average_30_min
        unit: W
        fill_raw: last
        color: gray
      - entity: sensor.solcast_forecast_rest
        type: line
        unit: W
        show:
          in_header: false
        color_threshold:
          - value: 0
            color: gray
          - value: 1500
            color: gray
          - value: 2000
            color: darkorange
          - value: 6552
            color: darkorange
          - value: 6852
            color: lime
        data_generator: |
          return entity.attributes.forecasts.map((entry) => {
            return [new Date(entry.period_end), entry.pv_estimate*1000];
I had an old setup with only one series that was working as expected:
    experimental:
    graph_span: 48h
    apex_config:
      yaxis:
        min: 0
        max: 10000
        tickAmount: 5
    now:
      show: True
      label: "jetzt"
    span:
      start: hour
    series:
      - entity: sensor.solcast_forecast_chart
        data_generator: | # This is what builds the data
          return entity.attributes.timestamps.map((ts, index) => {
            return [new Date(ts).getTime(), entity.attributes.forecast_values[index]];
        color_threshold:
          - value: 0
            color: gray
          - value: 250
            color: gray
          - value: 500
            color: darkorange
          - value: 6552
            color: darkorange
          - value: 6852
            color: lime
I don’t see the difference in these configs regarding the color_threshold.
Can someone help?
Well… looks like it healed itself over night :man_shrugging:
Hi, Could somebody please help me with getting “extremas” for entity with data_generator modded values? Extremas show on 1st entity but doesn’t on the 2nd.
Thaks!
series:
          - entity: sensor.nordpool
            color: "rgb(255,111,0)"
            transform: "return x * 100;"
            show:
              in_header: true
              extremas: true
            show:
              extremas: true
            data_generator: |
              return entity.attributes.raw_today.map((p) => {
                return [new Date(p.start), (new Date() > new Date(p.start)) ? null : p.value * 100];
Can someone tell me how to show the current values for the hour instead of the last value in the series?
Right now the header shows 3.66 DKK/kWh which is the value from the last hour of the day. It should be 3.25 DKK/kWh.
Here is my code…
  - entity: sensor.nordpool_kwh_dk2_dkk_2_10_025
    float_precision: 2
    color: '#9b59b6'
    type: line
    stroke_width: 2
    data_generator: |
      return entity.attributes.raw_today.map((entry) => {
        return [new Date(entry.start), entry.value];
