I use apex-card to display my EV-charging statistics:
Using Home Assistant and NodeRed to control EV Charging - Share your Projects! - Home Assistant Community (home-assistant.io)
Now I try to make the time span selectable with the config-card-template. Therefore I added this
type: vertical-stack
cards:
- type: entities
entities:
- entity: input_select.wallbox_apex_filter
- type: 'custom:config-template-card'
variables:
- 'states[''input_select.wallbox_apex_filter''].state'
entities:
- input_select.wallbox_apex_filter
card:
type: custom:apexcharts-card
stacked: true
Now the JS seems to broken:
1.) It cuts the first two letters of my data_generator script:
The simple workaround is to add two extra letters → vavar = myInit…
2.) The data_generator ends with: return request();
But now I get this error:
Any ideas how to fix this?
