Apple tv no longer appears in home assistant
For some reason my apple tv stopped appearing in my home assistant. They are on the same network and home sharing is enabled on the apple tv.
555
If you upgraded to tvOS 13, then the integration broke due to Apple deprecating the DMAP-protocol currently only supported. I’m slowly working on fixing this, but it’s gonna take some time.
Good to know. Thank you.
I’m running Home Assistant 0.105.2, has this been integrated yet or can I add this to Hass.Io someway through the Add-Ons?
Recommended way is to add and install it via HACS.
