AppleTV triggered, all automation turned on when I restart Hass.io
Hi there,
I have a little problem about manually restarting Hass.io from Hass.io>Restart Home Assistant menu.
Each time when I restart Hass.io, Apple TV triggered it self and open my Home Theater and TV, at the same time all Automations are turned on (even I’ve put the OFF position)
Hass.io v0.60.1
Is there any suggestion? What should I check?
Thanks in advance.
Belek
Regarding your home system getting turned on is described in the documentation here, scroll down to “MY APPLE TV TURNS ON WHEN I RESTART HOME ASSISTANT”.
Thank you. First problem solved.
