Yes exactly the same. Hope they found the issue (i canāt)
@Remco_van_Geel & @HappyCadaver
It looks like you may be running an unstable beta release that hasnāt been officially released yet. Issues like this are best reported in the beta forum, where they can be addressed before the stable release.
Iām currently running Home Assistant 2025.12.5 (stable), and the blueprint works as expected and responds very quickly.
As a general rule, I donāt update on ?.?.1 or ?.?.2 releases. I usually wait until around .3 or later before making changes or investigating issues.
I also donāt run beta versions⦠thatās simply a time constraint, and there are beta testers better suited to that stage of testing.
Blacky ![]()
Blacky, I wasnāt actually having an issue as I havenāt had to touch your amazing and rock solid blueprint since set up and I donāt create automations/scripts from the UI. I was just trying to point out to Remco_van_Geel that itās not a Blackyās blueprint problem, it was an early beta frontend performance problem (now resolved if Iām not mistaken).
You just keep doing you which you do so well
Yeah, thanks for helping out⦠in fact, you helped me by providing the link to the beta, so thank you. I just tagged you in the conversation since you were part of it.
Thanks for your kind words, glad you like the blueprint and that youāre finding it useful.
Blacky ![]()
Watts your appliance up to, youāre always in the know from start to finish!
New Features
- Notification URL - Opens a specific page or view in Home Assistant when the notification is tapped.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
Running the latest version 3.9 I did set up some service cycle counter helper variable to get reminded of some device cleaning and such. However, it seems that the service cycle counter does not count. I have definitely be running the device monitored a few times after that but the service cycle counter still says ā0ā. Any idea if I am missing something? Thanks!
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on ā</>ā and paste code in there.
Blacky ![]()
Thanks for the reply, hereās one of the two automations YAML. I checked to be certain and the helper still is ā0ā but I was running the device yesterday, so I am certain it does not increase its value.
alias: Verbrauch Waschmaschine
description: ""
use_blueprint:
path: Blackshome/appliance-notifications.yaml
input:
power_sensor: sensor.steckdose_waschmaschine_electric_consumption_w
start_appliance_power: 5
running_dead_zone: 25
end_appliance_power: 4
end_time_delay: 4
start_title: Washing Machine
include_end_notify: enable_end_notify_options
end_notify_device:
- cbc561b2095a352f28d17c65a03e7abd
- 16d3089032a9667c007b5eccda69437e
end_message_title: š„»ššš Waschmaschine fertig šš§¦š©²š§£
include_power_tracking: enable_power_tracking_and_cost
end_message: Die Waschmaschine ist fertig!
end_message_cost: "šø Kosten: "
end_message_kwh: "ā” Verbrauch: "
power_consumption_sensor: sensor.steckdose_waschmaschine_electric_consumption_kwh
cost_per_kwh: input_number.strompreis
include_time: time_enabled
after_time: "07:00:00"
before_time: "22:30:00"
start_power_consumption: input_number.waschmaschine_power_tracking_start
end_power_consumption: input_number.waschmaschine_power_tracking_end
include_custom_actions:
- enable_start_custom_actions
- enable_end_custom_actions
start_custom_actions:
- metadata: {}
value: 21
entity_id: input_number.hauswirtschaftsraum_manual_comfort_temperature
action: input_number.set_value
end_custom_actions:
- metadata: {}
value: 18
end_message_duration_tracking: "ā Laufzeit:"
include_duration_tracking: enable_duration_tracking
include_watchdog: enable_watchdog
watchdog_timeframe:
hours: 4
minutes: 30
seconds: 0
watchdog_title: ā ļø Waschmaschine Laufzeit
watchdog_message: Waschmaschine läuft zu lange, bitte prüfen!
start_notify_data:
- high_priority
- sticky
- icon
start_notify_tag: Waschmaschine
end_notify_tag: waschmaschine
end_notify_data:
- high_priority
- channel
- icon
service_reminder_cycles: 50
service_reminder_end_message: ā ļø Zeit für das Reinigungsprogramm der Waschmaschine
service_reminder_counter_helper: counter.cycle_counter_service_reminder_waschmaschine
watchdog_notify_device:
watchdog_notify_data:
- high_priority
- sticky
- icon
include_device_tracker:
- zone_end
notify_zone: zone.home
run_status_entity: input_select.status_waschmaschine
run_status_start: Waschen
run_status_watchdog: Fehler
run_status_end: Ende
run_status_end_attended: Standby
The helper (Cycle Counter Service Reminder Waschmaschine) is of the type counter, could this be the problem and it should be another type?
Thanks for your YAML.
You need to enable this option as currently it is disabled. You have 2 enable options to choose from, see below.
Blacky ![]()
Thank you for making this!
I noticed that the custom end action doesnāt repeat when end notifications are set to repeat, is there a way to change this? I use the custom actions to do custom alerts, such as through speakers.
Also, Iām using this for a washing machine. Due to the curvature of the door, I canāt use a door/window sensor but the automation requires a binary sensor. Iāve set up a physical button that is linked to a HA switch. When pressed the switch is set to On, and when this automation runs, the switch is set to Off and the switch has a helper binary sensor that the automation uses. Is there a simpler way to link a physical button to this automation?
Thanks for your response⦠I checked multiple times and had it enabled but somewhat there must have been a glitch or something. Sorry for bothering you for nothing. I checked another one (which I should have done first) and that one worked. Of course out of the 50:50 choice I choose the one where I somewhat screwed up or whatever caused me not having enabled this but for the other one⦠![]()
Sometimes all it needs is an outside view. Thanks a bunch for that! ![]()
You need to build it into your custom end action. If you would like it to repeat then you need to build this, hence the name custom
Adding the button is about a simple as it gets. A door sensor is the best most reliable true signal to use. I use my motion sensor so when it is finnished an motion is detected in the laundry you know someone was in there to attend but itās not as good as using a door sensor⦠it works for us.
Blacky ![]()
Iām a bit overwhelmed by the 933 messages in this thread, so havenāt ready everything. I installed the blueprint over the weekend and was successful in getting it working. One thing that I did that may not be necessary was use 5 minute average powers for my washer and drier to try to reduce the chance of false alarms. That has worked well for me with other power monitoring automatons and so far is working well with this blueprint.
Itās good that you got it working. Iāve been using this for years now and have never received a false positive just using the start and end power settings with a time delay.
My son has a new fancy washer and dryer, and his works perfectly too. I have a brand-new Bosch washer and an LG dryer, and I donāt use the built-in smart features because I find this works better every time.
Blacky ![]()
I thought that if I set a custom action to do the custom action on a loop, it would continue even once the appliance has been attended to.
Does the Reminder Notification Entity being set to āonā terminate the whole automation, including a custom action loop?
Not too familiar with this, Iāve built some basic automations with HA, but this is the first template Iāve used for doing something more complex.
