Kinda newbie here , learning the ropes along with the help available over here. Running HassIO 0.90.1 on Rpi3+.
So I , as like some others bought “Aqara” cube (not the “Mi” cube), its part number is MFKZQ01LM
I have a Nortek HUSBZB-1 configured correctly with HassIO and it can see Zwave and Zigbee devices. I was able to pair the Aqara Cube with Nortek via ZHA join functional and can see it device name and details as follows. Somehow it creates three devices (i tried removing and readding it to confirm).
Homeassistant sees it as lumi sensor cube
My objective was to control connected home devices (like smart bulb, switches, onkyo amplifier) by using various states of Aqara cube.
After adding it to Homeassistant ,I dont have any further clue how/where to see its states and how to configure any further automations or actions based on specific cube movement , tapping, flipping, or touching states.
In the ZHA configuration page I can see and choose a lot of options, however its a bit overwhelming to make sense and correlate all of them with real world usage.
Can someone here share a more gradual approach to understanding it and making it work for me, would be helpful for others in the same pursuit. Would be really thankful for the help.
I can, but I dont want to add a Xiaomi Aqara Gateway, just to be able to read the cube states, although I understand it may be a bit more easier with an aqara gateway though, is it correct. I already have a SmartThings V2 Hub integrated with HomeAssistant (as a local lan device , not via cloud - using SmartThings bridge), hence no need to add one more hub to the mix.
