Aqara Curtain Driver E1 (lumi.curtain.agl001) does not work with ZHA on Home Assistant Yellow EZSP radio
I recently received my Home Assistant Yellow and migrated my setup over, all very seamless.
Except for one pesky zigbee device: Aqara Curtain Driver E1 (lumi.curtain.agl001).
My previous coordinator was a Sonoff ZBDongle-P CC2652P (Texas Instruments based). I used the ZHA ‘migrate radio’ tool and every device transferred over, except for the Aqara Curtain Driver E1.
Have tried removing and re-pairing the Aqara Curtain Driver E1 multiple times, but cannot control the device at all. The status of all the device’s entities is Unknown and a while later Unavailable.
Wondering if this might be because Home Assistant Yellow radio type is EZSP? Has anyone else had similar issues? It’s been driving me a bit mad.
Have seen that there’s this repo NabuCasa/silabs-firmware for the Silicon Labs firmware for Yellow and SkyConnect, but there don’t seem to be any device specific issues listed. So not sure whether that’s the best place to enquire? Bit stuck basically!
Diagnostics
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.3.2",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.10",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/London",
    "os_name": "Linux",
    "os_version": "5.15.84-v8",
    "supervisor": "2023.03.1",
    "host_os": "Home Assistant OS 9.5",
    "docker_version": "20.10.22",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "browser_mod": {
      "version": "2.2.0",
      "requirements": []
    "feedparser": {
      "version": "0.1.7",
      "requirements": [
        "feedparser==6.0.8"
    "nuki_ng": {
      "version": "0.2.1",
      "requirements": []
    "pfsense": {
      "version": "0.1.0",
      "requirements": [
        "mac-vendor-lookup>=0.1.11"
    "dukaone": {
      "version": "1.0.6",
      "requirements": [
        "dukaonesdk==1.0.4"
    "hacs": {
      "version": "1.31.0",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "wiser": {
      "version": "3.3.0",
      "requirements": [
        "aioWiserHeatAPI==1.1.0"
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "requirements": [
      "bellows==0.34.9",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.93",
      "zigpy-deconz==0.19.2",
      "zigpy==0.53.2",
      "zigpy-xbee==0.16.2",
      "zigpy-zigate==0.10.3",
      "zigpy-znp==0.9.3"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 37677,
    "manufacturer": "LUMI",
    "model": "lumi.curtain.agl001",
    "name": "LUMI lumi.curtain.agl001",
    "quirk_applied": true,
    "quirk_class": "curtain_e1.E1Curtain",
    "manufacturer_code": 4447,
    "power_source": "Battery or Unknown",
    "lqi": null,
    "rssi": null,
    "last_seen": "2023-03-08T22:20:50",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4447, maximum_buffer_size=127, maximum_incoming_transfer_size=100, server_mask=11264, maximum_outgoing_transfer_size=100, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": 260,
          "device_type": "0x0202",
          "in_clusters": [
            "0x0000",
            "0x0001",
            "0x0003",
            "0x000a",
            "0x0102",
            "0xfcc0"
          "out_clusters": [
            "0x0003",
            "0x000a",
            "0x0019",
            "0xfcc0"
    "active_coordinator": false,
    "entities": [
        "entity_id": "button.bedroom_curtain_identify",
        "entity_id": "cover.bedroom_curtain",
        "entity_id": "sensor.bedroom_curtain_batter_level",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "WINDOW_COVERING_DEVICE"
    "user_given_name": "Bedroom curtain",
    "device_reg_id": "df6da383942e4fd7ba629c542d54d4c3",
    "area_id": "cee9dcbe51864ffb940f792c08941a77",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "WINDOW_COVERING_DEVICE",
          "id": 514
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "LUMI"
              "0x0005": {
                "attribute_name": "model",
                "value": "lumi.curtain.agl001"
            "unsupported_attributes": {}
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {},
              "0x0020": {
                "attribute_name": "battery_voltage"
              "0x0021": {
                "attribute_name": "battery_percentage_remaining"
              "0x0033": {
                "attribute_name": "battery_quantity"
              "0x0031": {
                "attribute_name": "battery_size"
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x000a": {
            "endpoint_attribute": "time",
            "attributes": {},
          "0x0102": {
            "endpoint_attribute": "window_covering",
            "attributes": {},
          "0xfcc0": {
            "endpoint_attribute": "manufacturer_specific",
            "attributes": {},
        "out_clusters": {
          "0x0003": {
            "attributes": {},
          "0x000a": {
            "attributes": {},
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
          "0xfcc0": {
            "attributes": {},
Much as I would love to get this working with ZHA, doesn’t appear that’s going to happening anytime soon.
Ended up purchasing an Aqara E1 hub USB dongle. Now have this working via HomeKit controller in Home Assistant. The Aqara Home app UI isn’t that intuitive, but have set the open and close end points and reversed the opening direction.
I now have a cover entity and battery level working in Home Assistant which was my goal.
This device appears to be supported in ZHA now.
