I’ve got a bunch of THESE Aqara motion sensors. They detect motion and ambient light as well as battery level.
I originally paired them directly with HA Zigbee. They were unstable (kept becoming unavailable) so I added an Aqara M1S Gen 2 Hub (I read the most recent hub didn’t play very nice with HA.
The hub and devices integrate via HomeKit and have stable for the past six months.
In HA, I can see the motion and battery indicators but not the Illuminance as I did with the direct Zigbee integration. I can see it in the Aqara app but not in the integration.
Is there a way to bring in into HA to be used in automations?
I’ve found “sometimes” not all of the attributes come in when setting up the device, so it’s worth removing and re-adding. Alternatively, the poor stability was likely a range issue, which could also be fixed with a cheap repeater from Ikea (or most other powered zigbee devices). Then you could go back to using the original method. If you try a repeater, you will have to remove and re-add it when it’s near the repeater as Aqara devices are known for refusing to change routes.
I had a very similar issue recently, but found that following the instructions below helped avoid the newly connected devices going unavailable. It might be worth giving it a go. I have no idea what the difference connecting to the coordinator makes, but it changed the behaviour for the better!
