Aqara Motion Sensor P1 China version (RTCGQ14LM)
Product name: Aqara Motion Sensor P1
Product model: RTCGQ14LM
Internal model:
Firmware version:
Release date:
Manufacturer: LUMI
Internal model:
Firmware version:
Release date:
Manufacturer: LUMI
Motion sensor detection interval does not update
when i try to change de Detection Interval from 30 to another value, it doesn’t update. Same problem with changing the Motion Sentivity and the LED trigger indicator
Remember, that when changing the sensor parameters you need to press the pair/reset physical button on the sensor at the same time whe you click on “Save Preferences”.
To change those settings, you need to press the button on the device first. You then get (I think) 30 seconds to make those settings changes before they are locked in.
This also happens when you first pair it, so you might have found you could change them when you first installed it, but didnt appear to be able to afterwards.
I installed my new SkyConnect and an Aqara motion sensor P1
ZHA with ha(blank)
Zigbee2Mqtt
My Zigbee2Mqtt shows Temperature sensor for P1. So this is ZHA bug. ZHA does not show this
https://community.home-assistant.io/t/aqara-p1-ms-s02/401796/59?u=msly
