@justint223 I’m looking at my chart history on the Lux values and from what I can see yes the Lux is being reported without having to detect motion first.
Awesome, thanks for checking. Is it something similar to the Hue at ~5 min intervals?
Hmm, I only have 1 and it’s in a room that has the shades pulled shut much of the time and sporadic entrance, it’s my young son’s bedroom. Looking at the history the graph is very much all over the place so it’s hard to tell what the update interval might be
Thanks, appreciate you taking the time.
one thing more, i found out if the device intergrated in a automatisation it´s also doesnt work, swich off the automatisation, wake up the device, change the settings and push the button again! After it works great and keep the setting.
I just bought 5 of these and i’m able to pair them with Z2M but I don’t get a reading (results). Anyone had this problem and found a solution ?
Is there any fix for the unknown battery?
It used to work but stopped after a re-pairing
Hi. How did you get work the P1 sensor? I am on z2m edge with Sonoff 3.0 dongle but did not find any solution to have the sensor in HA. Thank you.
That would be very important to me too:
Does the P1 update its illuminance sensor entity
a. independently of a detected motion and
b. based on a fix interval or once a lux change has been detected (so probably even every few seconds)?
Up to now (in combination with the former RTCGQ11LM) I had to use the GZCGQ01LM which work really great, but well - extra device, extra costs, extra battery, extra maintenance, …
Hi. I just installed the p1 sensor but I’m not getting the configuration sensors. I cant find the option to change the interval period.
I already did some workarounds mentioned here like remove and re-pair but still didn’t get configuration options. any suggestion?
OS version11.2
Core Version: 2023.12.13
thank you
