What is the best way to add this to deconz? Through phoscon? Is it a light/switch/sensor?
I have had this for a while but never found a way to add it in to HA. I have the aqara usb hub that came with it and it is linked to that.
I have tried adding it to deconz but can’t figure out how. Held the button on the bottom for 5+ seconds and the blue light is blinking but doesn’t seem to link to deconz
EDIT: I seem to have found it as light.dimmable_light_7 and “on” moves it to the top and “off” moves it to the bottom. Is there a way to manipulate it and have it as a cover instead so I can move it halfway down etc?
EDIT 2: After a restart the light disappeared and it came up again as cover. All a bit glitchy still it seems but seems to be there at least…
im not able to add the aquara e1 to my deconz in home assitant, the conbee2 stick is up to date and the latest deconz availble in homeassistant is also installed, also newest ha,
is the e1 not avaible atm via the homeassistant deconz???
i tried everything, as a light, sensor, switch everything, can you tell me the exact way to pair it?
like when i must press what on the roller and deconz?
I believe the E1 Curtain Driver is a different product than the original post, which is the E1 Roller Shade Driver. I also can’t get the E1 Curtain Driver to work, and from the Deconz Discord, it looks like it’s not yet supported.
sorry for reopening old thread.
i have 2 of these aqara roller shade driver e1
i have added them on phoscon as lumi.curtain.acn002
i found them on HA via deconz as the light bulb
but i cannot control them via HA
blind as bulb - on off does not work
brightness if i change does not work
how do i control this on HA?
update:
my deconz was on a different machine.
connected conbee2 to pi with HA.
now the deconz identified all the features of blind
Did you ever fix this?
One of my two motors fell off the network (again) but this time when I add it I just get the hex address as in your image. I’ve removed it, reset it, rebooted my host and all the things I can think of but whenever I try and pair it this is what I get. It’s not listed in Phoscon (to be expected I guess). I’ve never had a device behave like this before.
